Home » Eclipse Projects » e(fx)clipse » Cannot make off-line installation
Cannot make off-line installation [message #1105866] Tue, 10 September 2013 11:28 Go to next message
Jesper Skov is currently offline Jesper SkovFriend
I just tried downloading the SR1-RC2 Kepler JEE image (for 64bit Windows).
Having installed that, I tried installing e(fx)clipse from the site_assembly.zip downloaded today (site.xml contains the version string 0.9.0.201309100707).
I (only) selected the Kepler feature, and _disabled_ the ability for the installer to check online sources.
It then failed with:
Cannot complete the install because one or more required items could not be found.
  Software being installed: e(fx)clipse - IDE - Kepler 0.9.0.201309100707 (org.eclipse.fx.ide.all.kepler.feature.feature.group 0.9.0.201309100707)
  Missing requirement: Guice integration for FXML 0.9.0.201309100602 (org.eclipse.fx.core.guice 0.9.0.201309100602) requires 'bundle com.google.inject 2.0.0' but it could not be found
  Cannot satisfy dependency:
    From: e(fx)clipse - IDE - Kepler 0.9.0.201309100707 (org.eclipse.fx.ide.all.kepler.feature.feature.group 0.9.0.201309100707)
    To: org.eclipse.fx.ide.basic.feature.feature.group [0.9.0.201309100707]
    From: e(fx)clipse - IDE - Basic 0.9.0.201309100707 (org.eclipse.fx.ide.basic.feature.feature.group 0.9.0.201309100707)
    To: org.eclipse.fx.core.guice [0.9.0.201309100602]
I had hoped it was possible to Just Install(tm) while offline.
This may be due to the xtend dependency, which is not part of the JEE profile?!?
At least that shows up to be installed after letting Eclipse using on-line repos.
What is the best way to get around this - without letting the Installer go online?
Jesper
Re: Cannot make off-line installation [message #1105879 is a reply to message #1105866] Tue, 10 September 2013 11:44 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
Yes - the problem is that we are requireing com.google.inject which is
not part of our repo but from the orbit one (or the main kepler).
Our upstream requirements are:
* EMF
* Xtext/Xtend (which also requires guice)
* MWE
* WST
Tom
> be found.
> profile?!?
> on-line repos.
> go online?
> Jesper
Re: Cannot make off-line installation [message #1106003 is a reply to message #1105879] Tue, 10 September 2013 14:51 Go to previous message
I made a mirror of the repository at http://download.eclipse.org/modeling/tmf/xtext/updates/composite/releases/
including only:
<iu id="org.eclipse.xtext.sdk.feature.group" />
With this mirror, I'm able to install e(fx)clipse off-line.
Thanks!
Jesper
Previous Topic:Exporting an OSGi Application Project
Next Topic:Dialoge
Current Time: Wed Apr 25 14:46:23 GMT 2018
Powered by FUDForum. Page generated in 0.02086 seconds
