Home » Modeling » EMF » [cdo] trying to run cdo with hibernate as back end
[cdo] trying to run cdo with hibernate as back end [message #1101333] Wed, 04 September 2013 06:15 Go to next message
saurav singh is currently offline saurav singh
when I am trying to run server following error is comming:
[ERROR] Store factory not found: hibernate
What is the reason for this error?
Re: [cdo] trying to run cdo with hibernate as back end [message #1101339 is a reply to message #1101333] Wed, 04 September 2013 06:23 Go to previous messageGo to next message
Eike Stepper is currently offline Eike Stepper
Am 04.09.2013 12:15, schrieb saurav singh:
Please make sure that you deploy these plugins and all their dependencies:
org.eclipse.emf.cdo.server.hibernate
org.eclipse.emf.cdo.server.hibernate.teneo
Cheers
/Eike
http://www.esc-net.de
Re: [cdo] trying to run cdo with hibernate as back end [message #1101365 is a reply to message #1101339] Wed, 04 September 2013 07:13 Go to previous messageGo to next message
i installed every thing from
For CDO Hibernate Store 3.0 dependencies use these sites:
Hibernate and other 3rd party libs: http://www.elver.org/eclipse/update_1.1.2
Teneo: http://download.eclipse.org/modeling/emf/teneo/updates/1.1.2/interim/
but org.eclipse.emf.cdo.server.hibernate.teneo plug in is not there Sad
what should I do.
Re: [cdo] trying to run cdo with hibernate as back end [message #1101375 is a reply to message #1101365] Wed, 04 September 2013 07:25 Go to previous messageGo to next message
Am 04.09.2013 13:13, schrieb saurav singh:
Where?
You mean you're using CDO 3.0? I strongly recommend to use at least the latest (and only maintained) release, i.e. CDO 4.2.
Cheers
/Eike
> but org.eclipse.emf.cdo.server.hibernate.teneo plug in is not there :(
> what should I do.
Re: [cdo] trying to run cdo with hibernate as back end [message #1101387 is a reply to message #1101375] Wed, 04 September 2013 07:47 Go to previous messageGo to next message
Martin Taal is currently offline Martin Taal
Hi Saurav,
It seems that you are using a quite old version, did you check this page:
http://wiki.eclipse.org/CDO_Hibernate_Store#Dependencies
http://wiki.eclipse.org/CDO/Hibernate_Store/Download_and_Install#Update_site_locations
(I updated the page a few mins back for the 4.2 and 4.3 versions)
gr. Martin
> Where?
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
>> what should I do.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [cdo] trying to run cdo with hibernate as back end [message #1101943 is a reply to message #1101387] Thu, 05 September 2013 02:06 Go to previous messageGo to next message
Thanks Eike & Martin Smile
Now the dependencies problem is solved- but when I am running the server following output is coming-
Configuration location:
file:/home/saurav/workspace/.metadata/.plugins/org.eclipse.pde.core/CDOHibernateServer/
Configuration file:
file:/home/saurav/workspace/.metadata/.plugins/org.eclipse.pde.core/CDOHibernateServer/config.ini loaded
Install location:
file:/home/saurav/eclipse/
Framework located:
file:/home/saurav/eclipse/plugins/org.eclipse.osgi_3.8.2.v20130124-134944.jar
Framework classpath:
Debug options:
file:/home/saurav/eclipse/.options not found
osgi> Time to load bundles: 379
Starting application: 1114
[INFO] CDO server starting
log4j: Trying to find [log4j.xml] using context classloader org.eclipse.core.runtime.internal.adaptor.ContextFinder@4406cef4.
log4j: Trying to find [log4j.xml] using org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader@207ff5b6[org.apache.log4j:1.2.15.v201012070815(id=110)] class loader.
log4j: Trying to find [log4j.xml] using ClassLoader.getSystemResource().
log4j: Trying to find [log4j.properties] using context classloader org.eclipse.core.runtime.internal.adaptor.ContextFinder@4406cef4.
log4j: Trying to find [log4j.properties] using org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader@207ff5b6[org.apache.log4j:1.2.15.v201012070815(id=110)] class loader.
log4j: Trying to find [log4j.properties] using ClassLoader.getSystemResource().
log4j: Could not find resource: [null].
log4j:WARN No appenders could be found for logger (org.jboss.logging).
log4j:WARN Please initialize the log4j system properly.
create table cdo_package_info (
packageURI varchar(255) not null,
parentURI varchar(255),
cdo_package_unit_id varchar(255),
idx integer,
primary key (packageURI)
create table cdo_package_unit (
nsUri varchar(255) not null,
originalType varbinary(255),
timeStamp bigint,
EPackageBlob blob,
primary key (nsUri)
create table cdo_system_information (
id integer generated by default as identity (start with 1),
creationTime bigint,
primary key (id)
create table cdo_system_property (
name varchar(255) not null,
value longvarchar,
primary key (name)
alter table cdo_package_info
add constraint FK5702C978798F06A8
foreign key (cdo_package_unit_id)
references cdo_package_unit
Hibernate: select this_.id as id2_0_, this_.creationTime as creation2_2_0_ from cdo_system_information this_
Hibernate: insert into cdo_system_information (id, creationTime) values (default, ?)
[ERROR] org.eclipse.emf.cdo.common.id.CDOIDUtil.createMap()Ljava/util/Map;
java.lang.NoSuchMethodError: org.eclipse.emf.cdo.common.id.CDOIDUtil.createMap()Ljava/util/Map;
at org.eclipse.emf.cdo.server.internal.hibernate.HibernateRawCommitContext.<init>(HibernateRawCommitContext.java:49)
at org.eclipse.emf.cdo.server.internal.hibernate.HibernateStoreAccessor.<init>(HibernateStoreAccessor.java:129)
at org.eclipse.emf.cdo.server.internal.hibernate.HibernateStore.createWriter(HibernateStore.java:442)
at org.eclipse.emf.cdo.server.internal.hibernate.HibernateStore.createWriter(HibernateStore.java:1)
at org.eclipse.emf.cdo.spi.server.Store.getWriter(Store.java:374)
at org.eclipse.emf.cdo.internal.server.Repository.initSystemPackages(Repository.java:1647)
at org.eclipse.emf.cdo.internal.server.Repository.doActivate(Repository.java:1864)
at org.eclipse.net4j.util.lifecycle.Lifecycle.activate(Lifecycle.java:76)
at org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(LifecycleUtil.java:114)
at org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(LifecycleUtil.java:104)
at org.eclipse.emf.cdo.server.CDOServerUtil.addRepository(CDOServerUtil.java:208)
at org.eclipse.emf.cdo.spi.server.RepositoryConfigurator.configure(RepositoryConfigurator.java:111)
at org.eclipse.emf.cdo.internal.server.bundle.CDOServerApplication.doStart(CDOServerApplication.java:61)
at org.eclipse.net4j.util.om.OSGiApplication.start(OSGiApplication.java:63)
at org.eclipse.equinox.internal.app.AnyThreadAppLauncher.run(AnyThreadAppLauncher.java:26)
at java.lang.Thread.run(Thread.java:679)
I am not getting the error. I changed the VM argument line
-Dlog4j.debug=true
to
-Dlog4j.configuration=file:/home/saurav/git/cdo/plugins/org.eclipse.emf.cdo.examples.hibernate.server/src/log4j.properties
now on running the server console is showing
Configuration file:
Install location:
Framework located:
Debug options:
osgi> Time to load bundles: 375
Starting application: 1110
idx integer,
timeStamp bigint,
EPackageBlob blob,
primary key (nsUri)
primary key (id)
value longvarchar,
primary key (name)
What should I do?
Re: [cdo] trying to run cdo with hibernate as back end [message #1101953 is a reply to message #1101943] Thu, 05 September 2013 02:28 Go to previous messageGo to next message
To me it looks as if your bundle versions don't match together, i.e. org.eclipse.emf.cdo.common is too old for
org.eclipse.emf.cdo.server.hibernate. What versions do you use?
The method org.eclipse.emf.cdo.common.id.CDOIDUtil.createMap() exists @since 4.2.
Cheers
/Eike
Am 05.09.2013 08:06, schrieb saurav singh:
> Thanks Eike & Martin :)
> Configuration file:
> Install location:
> Framework located:
> Debug options:
> mailto:org.eclipse.core.runtime.internal.adaptor.ContextFinder@4406cef4.
> mailto:org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader@207ff5b6[org.apache.log4j:1.2.15.v201012070815(id=110)] class
> loader.
> loader.
> idx integer,
> timeStamp bigint,
> EPackageBlob blob,
> primary key (nsUri)
> primary key (id)
> value longvarchar,
> primary key (name)
> alter table cdo_package_info add constraint FK5702C978798F06A8 foreign key (cdo_package_unit_id)
> at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> -Dlog4j.debug=true
> to
> Configuration file:
> Install location:
> Framework located:
> Debug options:
> idx integer,
> timeStamp bigint,
> EPackageBlob blob,
> primary key (nsUri)
> primary key (id)
> value longvarchar,
> primary key (name)
> What should I do?
> Thanks
Re: [cdo] trying to run cdo with hibernate as back end [message #1102040 is a reply to message #1101953] Thu, 05 September 2013 05:17 Go to previous messageGo to next message
Thanks Eike Smile
I was using 4.1.0 version I updated the version and after making some other changes finally I managed to run the server and its working properly.
Smile Smile
Re: [cdo] trying to run cdo with hibernate as back end [message #1102148 is a reply to message #1102040] Thu, 05 September 2013 08:30 Go to previous messageGo to next message
Now my server is started. I am able to add elements and making hql queries. But there seems a problem. when I stop the server and restart it every thing I added in last session is gone Sad
What is the possible reason for the same?
Re: [cdo] trying to run cdo with hibernate as back end [message #1102222 is a reply to message #1102148] Thu, 05 September 2013 10:26 Go to previous messageGo to next message
Hi Saurav,
Maybe an obvious question (sorry if so).. but are you using an in-memory database?
gr. Martin
> server and restart it every thing I added in last session is gone :(
The Netherlands
Re: [cdo] trying to run cdo with hibernate as back end [message #1102830 is a reply to message #1102222] Fri, 06 September 2013 01:35 Go to previous messageGo to next message
Hello Martin, I am using mysql database.
Re: [cdo] trying to run cdo with hibernate as back end [message #1102923 is a reply to message #1102830] Fri, 06 September 2013 03:47 Go to previous message
Hi Saurav,
Okay, are you sure the actions you do on the client are send to the server? So are you committing the transaction?
gr. Martin
The Netherlands
Previous Topic:Track EMF Objects created
Next Topic:Exporting a default EMF editor as an eclipse product
Current Time: Tue Oct 08 07:44:28 EDT 2013
Powered by FUDForum. Page generated in 0.01871 seconds
