Home » Eclipse Projects » e(fx)clipse » ClassNotFoundException when loading Controller via FXML
ClassNotFoundException when loading Controller via FXML [message #1099826] Mon, 02 September 2013 09:10 Go to next message
Daniel Zimmermann is currently offline Daniel ZimmermannFriend
Member
I just stumbled across a tiny inconvenience: When I start building my current ap as a plain JavaFX application, I build the FXGraph and respectivly the FXML with the controller already specified within. This worked fine.
Now I migrated to the OSGi based approach and was confronted with the named Exception. Funny enough within the FXGraph, it was found (and it is there!). So when I change the approach from the FXGraph based approach
component Root controlledby my_package.app.ui.RootController
to the Java internal
FXMLLoader fxmlLoader = new FXMLLoader();
fxmlLoader.setResources(bundle);
RootController controller = new RootController();
fxmlLoader.setController(controller);
this.rootWindow = (BorderPane) fxmlLoader.load(this.getClass().getResource("layout/Root.fxml").openStream());
it works as intended.
This is weird and I currently have no idea at all, why this is happening. Do you?
Thanks and greetings,
Daniel
Re: ClassNotFoundException when loading Controller via FXML [message #1099929 is a reply to message #1099826] Mon, 02 September 2013 12:05 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
It's not wired but expected in OSGi. The problem is that when the the
FXMLLoader is in the javafx bundle whereas your controller is in your
custom bundle which means the classloader of the javafx bundle won't see
your RootController.
You can fix this by:
a) setting the correct classloader on the FXMLLoader instance
b) you use our DI-Support (org.eclipse.fx.ui.di) as seen in the
OSGi-Example
c) use the low-level support below DI-Support named OSGiFXMLLoader and
part of fx.osgi.util
Tom
On 02.09.13 11:10, Daniel Zimmermann wrote:
> worked fine.
> happening. Do you?
> Daniel
Re: ClassNotFoundException when loading Controller via FXML [message #1100036 is a reply to message #1099929] Mon, 02 September 2013 15:10 Go to previous messageGo to next message
Member
Thanks for the tipps! I will do that, when I'm back from my short vacation!
Daniel
Re: ClassNotFoundException when loading Controller via FXML [message #1112999 is a reply to message #1099826] Fri, 20 September 2013 13:51 Go to previous messageGo to next message
Mar Ifla is currently offline Mar IflaFriend
I'm having a similar problem trying to run a JavaFX OSGi application.
My controller class my.fx.test.app.MyNodeController loads its fxml located in layout/MyNode.fxml just fine.
But when I include another custom node object named my.fx.test.app.MyButton (extending Button) into MyNode.fxml, I get a ClassNotFoundException for my.fx.test.app.MyButton.
I'm using
FXMLLoader fxmlLoader = new FXMLLoader(getClass().getClassLoader().getResource("layout/MyNode.fxml"));
to instantiate the loader.
Any idea what's wrong?
[Updated on: Sun, 22 September 2013 07:46]
Report message to a moderator
Re: ClassNotFoundException when loading Controller via FXML [message #1113214 is a reply to message #1112999] Fri, 20 September 2013 20:21 Go to previous messageGo to next message
Did you read the answer I gave to Daniel?
The problem you have has to to with visibility! The FXMLLoader uses the
classloader associated with the javafx-bundle so it will never ever be
able to see your custom class.
Solution:
a) set current bundle class loader on the FXMLLoader
b) use our FXML support
Tom
> My controller class my.package.MyNodeController loads its fxml located
> But when I include another custom node object named my.package.MyRegion
> (extending Region) into MyNode.fxml, I get a ClassNotFoundException for
> my.package.MyRegion.
> I'm usingFXMLLoader fxmlLoader = new
> FXMLLoader(getClass().getClassLoader().getResource("layout/MyNode.fxml"));to
Re: ClassNotFoundException when loading Controller via FXML [message #1114123 is a reply to message #1113214] Sun, 22 September 2013 07:41 Go to previous message
I've read it, but apparantly not carefully enough. Smile
My problem was, that I "passed" the correct ClassLoader in FXMLLoader contructor (to get URL resource), but I didn't give the ClassLoader to the instance itself.
It works now using FXMLLoader.setClassLoader(). Thanks.
Previous Topic:CSS validation problems
Next Topic:e(fx)clipse JNLP creation
Current Time: Sun May 20 21:42:55 GMT 2018
Powered by FUDForum. Page generated in 0.02152 seconds
