Home » Eclipse Projects » XML Schema Definition (XSD) » Repititive elements in Schema: Help!
Repititive elements in Schema: Help! [message #15392] Fri, 28 March 2003 09:27 Go to next message
kaunteya bhattacharya is currently offline kaunteya bhattacharyaFriend
I am curious as to learn how would I go about defining repititive elements
in the schema. I have defined a number of XSDComplexTypeDefinition
elements. But I cant seem to define their multiple occurences in the
schema. For e.g.
<xsd:complexType name="Bank_Operation_Code">
<xsd:element fixed="3!a15d" name="Constraint" type="xsd:string"/>
<xsd:element name="_26T" type="xsd:string"/>
</xsd:complexType>
This element occurs multiple times in my XML document. How do I define
that?
This is quite urgent to me. Any help would be much appreciated.
thanks
kaunteya
Re: Repititive elements in Schema: Help! [message #15428 is a reply to message #15392] Fri, 28 March 2003 10:27 Go to previous messageGo to next message
--------------EE197CEE0215E8A9C42A12C8
Content-Type: text/plain; charset=us-ascii
Kaunteya,
Are you trying to write something like this?
<xsd:schema xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<xsd:sequence>
<xsd:element maxOccurs="unbounded" fixed="3!a15d"
<xsd:element maxOccurs="unbounded" name="_26T"
type="xsd:string"/>
</xsd:sequence>
</xsd:complexType>
</xsd:schema>
kaunteya bhattacharya wrote:
> Hello,
> schema. For e.g.
> </xsd:complexType>
> that?
> thanks
> kaunteya
Content-Type: text/html; charset=us-ascii
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
Kaunteya,
<p>Are you trying to write something like this?
<blockquote>&lt;?xml version="1.0" encoding="UTF-8"?>
<br>&lt;xsd:schema xmlns:xsd="<A HREF="http://www.w3.org/2001/XMLSchema">http://www.w3.org/2001/XMLSchema</A>">
<br>&nbsp; &lt;xsd:complexType name="Bank_Operation_Code">
<br>&nbsp;&nbsp;&nbsp; &lt;xsd:sequence>
<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;xsd:element <b>maxOccurs="unbounded"</b>
<br>&nbsp;&nbsp;&nbsp; &lt;/xsd:sequence>
<br>&nbsp; &lt;/xsd:complexType>
<br>&lt;/xsd:schema></blockquote>
<blockquote TYPE=CITE>Hello,
<br>I am curious as to learn how would I go about defining repititive elements
<br>in the schema. I have defined a number of XSDComplexTypeDefinition
<br>elements. But I cant seem to define their multiple occurences in the
<br>schema. For e.g.
<p>&lt;xsd:complexType name="Bank_Operation_Code">
<br>&nbsp; &lt;xsd:element fixed="3!a15d" name="Constraint" type="xsd:string"/>
<br>&nbsp; &lt;xsd:element name="_26T" type="xsd:string"/>
<br>&lt;/xsd:complexType>
<p>This element occurs multiple times in my XML document. How do I define
<br>that?
<br>This is quite urgent to me. Any help would be much appreciated.
<p>thanks
<p>kaunteya</blockquote>
</html>
--------------EE197CEE0215E8A9C42A12C8--
Re: Repititive elements in Schema: Help! [message #15461 is a reply to message #15428] Fri, 28 March 2003 12:33 Go to previous messageGo to next message
Hello Ed,
Yes, I am sorry I missed out on the <sequence> element. But I realized
that I cant do the following things with the complexTypeDefinition.
1. I cant seem to add it in a group. Basically clump a number of complex
types in a ModelGroupDefinition. Because XSDParticle content does not take
in XSDComplexType objects.
2. I cant seem to define the cardinality of these complex types..
Essentially what if there are more than one occurence of complex types
within the XML instance document. I know you can do that with maxOccur and
minOccur on XSDParticleContent or elements but not with complexType. But
ElementDeclaration cannot seem to have children.
What is the best design.
thanks for your help
kauntea
> Kaunteya,
> <xsd:sequence>
> type="xsd:string"/>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
> > Hello,
> > schema. For e.g.
> > </xsd:complexType>
> > that?
> > thanks
> > kaunteya
> <html>
> Kaunteya,
> <blockquote><?xml version="1.0" encoding="UTF-8"?>
> <br><xsd:schema xmlns:xsd="<A
> <br>  <xsd:complexType name="Bank_Operation_Code">
> <br>    <xsd:sequence>
> <br>      <xsd:element <b>maxOccurs="unbounded"</b>
> <br>    </xsd:sequence>
> <br>  </xsd:complexType>
> <br></xsd:schema></blockquote>
elements
> <p><xsd:complexType name="Bank_Operation_Code">
> <br>  <xsd:element fixed="3!a15d" name="Constraint" type="xsd:string"/>
> <br>  <xsd:element name="_26T" type="xsd:string"/>
> <br></xsd:complexType>
> <br>that?
> <p>thanks
> </html>
Re: Repititive elements in Schema: Help! [message #15493 is a reply to message #15461] Fri, 28 March 2003 12:40 Go to previous messageGo to next message
I forgot to mention the schema has other elements and declarations apart
from the specified complex type. So its more like
<xsd:complexType name="Swift_Operation_Code">
<xsd:sequence>
<xsd:element maxOccurs="unbounded" fixed="3!b234"
<xsd:element maxOccurs="unbounded" name="_28T"
type="xsd:string"/>
</xsd:sequence>
</xsd:complexType>
<xsd:sequence>
type="xsd:string"/>
</xsd:sequence>
</xsd:complexType>
</xsd:schema>
would like to to clump the two complex types in one group.
thanks
kaunteya
> Hello Ed,
> kauntea
> > Kaunteya,
> > <xsd:sequence>
> > type="xsd:string"/>
> > </xsd:sequence>
> > </xsd:complexType>
> > </xsd:schema>
> > > Hello,
elements
> > > schema. For e.g.
> > > </xsd:complexType>
> > > that?
> > > thanks
> > > kaunteya
> > <html>
> > Kaunteya,
> > <br>    <xsd:sequence>
> elements
> > <br>that?
> > <p>thanks
> > </html>
Re: Repititive elements in Schema: Help! [message #15526 is a reply to message #15461] Fri, 28 March 2003 13:45 Go to previous messageGo to next message
--------------0969DB8C731F55222437D473
Kaunteya,
No, you can't add a complex type definition to a group. A complex type definition
can only be contained by a schema or by an element. So if you want a complex type
definition to be "contained" by a model group you have to create an XSDParticle,
that contains (i.e., setContent()) an XSDElementDeclaration that either contains a
complex type (i.e., setAnonymousTypeDefinitition), or refers to a complex type
(i.e., setTypeDefinition); the particle can be added to any model group (i.e.,
getContents().add()) and the particle can have its maxOccurs set (e.g.,
setMaxOccurs(-1)).
For example:
<xsd:complexType name="x">
<xsd:sequence>
<xsd:element minOccurs="0" maxOccurs="unbounded" name="y">
<xsd:complexType> <!-- can't have a name="Bank_Operation_Code"
<xsd:sequence>
<xsd:element minOccurs="1" maxOccurs="1" name="_26T"
type="xsd:string"/>
</xsd:sequence>
</xsd:complexType>
</xsd:element>
<xsd:element minOccurs="0" maxOccurs="unbounded" name="z"
type="x"/>
</xsd:sequence>
</xsd:complexType>
</xsd:schema>
> Hello Ed,
> kauntea
> > Kaunteya,
> > <xsd:sequence>
> > type="xsd:string"/>
> > </xsd:sequence>
> > </xsd:complexType>
> > </xsd:schema>
> > > Hello,
> > > schema. For e.g.
> > > </xsd:complexType>
> > > that?
> > > thanks
> > > kaunteya
> > <html>
> > Kaunteya,
> > <br> <xsd:sequence>
> elements
> > <br>that?
> > <p>thanks
> > </html>
<html>
Kaunteya,
<p>No, you can't add a complex type definition to a group.&nbsp; A complex
type definition can only be contained by a schema or by an element.&nbsp;
So if you want a complex type definition to be "contained" by a model group
you have to create an XSDParticle, that contains (i.e., setContent()) an
XSDElementDeclaration that either contains a complex type (i.e., setAnonymousTypeDefinitition),
or refers to a complex type (i.e., setTypeDefinition); the particle can
be added to any model group (i.e., getContents().add()) and the particle
can have its maxOccurs set (e.g., setMaxOccurs(-1)).
<p>For example:
<br>&nbsp; &lt;xsd:complexType name="x">
<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;xsd:element minOccurs="0" maxOccurs="unbounded"
name="y">
<br> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; &lt;xsd:complexType> &lt;!--
can't have a name="Bank_Operation_Code" -->
<br> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &lt;xsd:sequence>
<br> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;
&lt;xsd:element minOccurs="0" maxOccurs="unbounded" fixed="3!a15d" name="Constraint"
type="xsd:string"/>
&lt;xsd:element minOccurs="1" maxOccurs="1" name="_26T" type="xsd:string"/>
<br> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &lt;/xsd:sequence>
<br> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; &lt;/xsd:complexType>
<br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;/xsd:element>
name="z" type="x"/>
<br>&nbsp;
<p>kaunteya bhattacharya wrote:
<blockquote TYPE=CITE>Hello Ed,
<p>Yes, I am sorry I missed out on the &lt;sequence> element. But I realized
<br>that I cant do the following things with the complexTypeDefinition.
<p>1. I cant seem to add it in a group. Basically clump a number of complex
<br>types in a ModelGroupDefinition. Because XSDParticle content does not
take
<br>in XSDComplexType objects.
<p>2. I cant seem to define the cardinality of these complex types..
<br>Essentially what if there are more than one occurence of complex types
<br>within the XML instance document. I know you can do that with maxOccur
and
<br>minOccur on XSDParticleContent or elements but not with complexType.
But
<br>ElementDeclaration cannot seem to have children.
<p>What is the best design.
<p>thanks for your help
<br>kauntea
<br>&nbsp;
<p>Ed Merks wrote:
<p>> --------------EE197CEE0215E8A9C42A12C8
<br>> Content-Type: text/plain; charset=us-ascii
<br>> Content-Transfer-Encoding: 7bit
<p>> Kaunteya,
<p>> Are you trying to write something like this?
<p>>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;?xml version="1.0" encoding="UTF-8"?>
<br>>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;xsd:schema xmlns:xsd="<a href="http://www.w3.org/2001/XMLSchema">http://www.w3.org/2001/XMLSchema</a>">
<br>> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; &lt;xsd:complexType name="Bank_Operation_Code">
<br>> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &lt;xsd:sequence>
<br>> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;
&lt;xsd:element maxOccurs="unbounded" fixed="3!a15d"
<br>>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; name="Constraint" type="xsd:string"/>
&lt;xsd:element maxOccurs="unbounded" name="_26T"
<br>>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; type="xsd:string"/>
<br>> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &lt;/xsd:sequence>
<br>> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; &lt;/xsd:complexType>
<br>>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;/xsd:schema>
<p>> kaunteya bhattacharya wrote:
<p>> > Hello,
<br>> > I am curious as to learn how would I go about defining repititive
elements
<br>> > in the schema. I have defined a number of XSDComplexTypeDefinition
<br>> > elements. But I cant seem to define their multiple occurences in
the
<br>> > schema. For e.g.
<br>> >
<br>> > &lt;xsd:complexType name="Bank_Operation_Code">
<br>> >&nbsp;&nbsp; &lt;xsd:element fixed="3!a15d" name="Constraint" type="xsd:string"/>
<br>> >&nbsp;&nbsp; &lt;xsd:element name="_26T" type="xsd:string"/>
<br>> > &lt;/xsd:complexType>
<br>> >
<br>> > This element occurs multiple times in my XML document. How do I
define
<br>> > that?
<br>> > This is quite urgent to me. Any help would be much appreciated.
<br>> >
<br>> > thanks
<br>> >
<br>> > kaunteya
<br>> Content-Type: text/html; charset=us-ascii
<p>> &lt;!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<br>> &lt;html>
<br>> Kaunteya,
<br>> &lt;p>Are you trying to write something like this?
<br>> &lt;blockquote>&lt;?xml version="1.0" encoding="UTF-8"?>
<br>> &lt;br>&lt;xsd:schema xmlns:xsd="&lt;A
<br>HREF="<a href="http://www.w3.org/2001/XMLSchema">http://www.w3.org/2001/XMLSchema</a>"><a href="http://www.w3.org/2001/XMLSchema">http://www.w3.org/2001/XMLSchema</a>&lt;/A>">
<br>> &lt;br>&nbsp; &lt;xsd:complexType name="Bank_Operation_Code">
<br>> &lt;br>&nbsp;&nbsp;&nbsp; &lt;xsd:sequence>
<br>> &lt;br>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;xsd:element &lt;b>maxOccurs="unbounded"&lt;/b>
<br>> fixed="3!a15d" name="Constraint" type="xsd:string"/>
<br>> name="_26T" type="xsd:string"/>
<br>> &lt;br>&nbsp;&nbsp;&nbsp; &lt;/xsd:sequence>
<br>> &lt;br>&nbsp; &lt;/xsd:complexType>
<br>> &lt;br>&lt;/xsd:schema>&lt;/blockquote>
<br>> kaunteya bhattacharya wrote:
<br>> &lt;blockquote TYPE=CITE>Hello,
<br>> &lt;br>I am curious as to learn how would I go about defining repititive
<br>elements
<br>> &lt;br>in the schema. I have defined a number of XSDComplexTypeDefinition
<br>> &lt;br>elements. But I cant seem to define their multiple occurences
in the
<br>> &lt;br>schema. For e.g.
<br>> &lt;p>&lt;xsd:complexType name="Bank_Operation_Code">
<br>> &lt;br>&nbsp; &lt;xsd:element fixed="3!a15d" name="Constraint" type="xsd:string"/>
<br>> &lt;br>&nbsp; &lt;xsd:element name="_26T" type="xsd:string"/>
<br>> &lt;br>&lt;/xsd:complexType>
<br>> &lt;p>This element occurs multiple times in my XML document. How
do I define
<br>> &lt;br>that?
<br>> &lt;br>This is quite urgent to me. Any help would be much appreciated.
<br>> &lt;p>thanks
<br>> &lt;p>kaunteya&lt;/blockquote>
<br>> &lt;/html>
<p>> --------------EE197CEE0215E8A9C42A12C8--</blockquote>
</html>
--------------0969DB8C731F55222437D473--
Re: Repititive elements in Schema: Help! [message #15558 is a reply to message #15526] Fri, 28 March 2003 15:37 Go to previous messageGo to next message
thanks,
appreciate your help
> Kaunteya,
> No, you can\'t add a complex type definition to a group. A complex type
definition
complex type
> definition to be \"contained\" by a model group you have to create an
XSDParticle,
contains a
type
(i.e.,
> setMaxOccurs(-1)).
> For example:
> <?xml version=\"1.0\" encoding=\"UTF-8\"?>
> <xsd:schema xmlns:xsd=\"http://www.w3.org/2001/XMLSchema\">
> <xsd:complexType name=\"x\">
> <xsd:sequence>
> <xsd:element minOccurs=\"0\" maxOccurs=\"unbounded\" name=\"y\">
> <xsd:complexType> <!-- can\'t have a
name=\"Bank_Operation_Code\"
> <xsd:sequence>
> fixed=\"3!a15d\" name=\"Constraint\" type=\"xsd:string\"/>
> <xsd:element minOccurs=\"1\" maxOccurs=\"1\" name=\"_26T\"
> </xsd:sequence>
> </xsd:complexType>
> </xsd:element>
> <xsd:element minOccurs=\"0\" maxOccurs=\"unbounded\" name=\"z\"
> type=\"x\"/>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
> > Hello Ed,
> > kauntea
> > > Kaunteya,
> > > <xsd:complexType name=\"Bank_Operation_Code\">
> > > <xsd:sequence>
> > > <xsd:element maxOccurs=\"unbounded\" fixed=\"3!a15d\"
> > > <xsd:element maxOccurs=\"unbounded\" name=\"_26T\"
> > > </xsd:sequence>
> > > </xsd:complexType>
> > > </xsd:schema>
> > > > Hello,
elements
> > > > schema. For e.g.
> > > > <xsd:element fixed=\"3!a15d\" name=\"Constraint\"
> > > > <xsd:element name=\"_26T\" type=\"xsd:string\"/>
> > > > </xsd:complexType>
> > > > that?
> > > > thanks
> > > > kaunteya
> > > <!doctype html public \"-//w3c//dtd html 4.0 transitional//en\">
> > > <html>
> > > Kaunteya,
> > > <blockquote><?xml version=\"1.0\" encoding=\"UTF-8\"?>
> > > <br><xsd:schema xmlns:xsd=\"<A
HREF=\"http://www.w3.org/2001/XMLSchema\">http://www.w3.org/2001/XMLSchema</A>\">
> > > <br> <xsd:complexType name=\"Bank_Operation_Code\">
> > > <br> <xsd:sequence>
> > > <br> <xsd:element <b>maxOccurs=\"unbounded\"</b>
> > elements
> > > <p><xsd:complexType name=\"Bank_Operation_Code\">
> > > <br> <xsd:element fixed=\"3!a15d\" name=\"Constraint\"
> > > <br> <xsd:element name=\"_26T\" type=\"xsd:string\"/>
> > > <br>that?
> > > <p>thanks
> > > </html>
> <html>
> Kaunteya,
> <p>No, you can\'t add a complex type definition to a group.  A complex
> So if you want a complex type definition to be \"contained\" by a model group
> <p>For example:
> <br>  <xsd:complexType name=\"x\">
> <br>    <xsd:sequence>
> <br>      <xsd:element minOccurs=\"0\" maxOccurs=\"unbounded\"
> name=\"y\">
> <br>        <xsd:complexType> <!--
> can\'t have a name=\"Bank_Operation_Code\" -->
> <br>          <xsd:sequence>
> <br>
> <xsd:element minOccurs=\"0\" maxOccurs=\"unbounded\" fixed=\"3!a15d\"
name=\"Constraint\"
> <br>
> <br>      </xsd:element>
> name=\"z\" type=\"x\"/>
> <br>
> <p>Yes, I am sorry I missed out on the <sequence> element. But I realized
> take
> and
> But
> <br>kauntea
> <br>
> <p>> Kaunteya,
> <p>>      <?xml version=\"1.0\" encoding=\"UTF-8\"?>
> <br>>      <xsd:schema xmlns:xsd=\"<a
href=\"http://www.w3.org/2001/XMLSchema\">http://www.w3.org/2001/XMLSchema</a>\">
> <br>>        <xsd:complexType name=\"Bank_Operation_Code\">
> <br>>          <xsd:sequence>
> <br>>
> <br>>      name=\"Constraint\" type=\"xsd:string\"/>
> <br>>
> <br>>      type=\"xsd:string\"/>
> <br>>          </xsd:sequence>
> <br>>        </xsd:complexType>
> <br>>      </xsd:schema>
> <p>> > Hello,
> elements
> the
> <br>> >
> <br>> > <xsd:complexType name=\"Bank_Operation_Code\">
> <br>> >   <xsd:element fixed=\"3!a15d\" name=\"Constraint\"
> <br>> >   <xsd:element name=\"_26T\" type=\"xsd:string\"/>
> <br>> > </xsd:complexType>
> <br>> >
> define
> <br>> > that?
> <br>> >
> <br>> > thanks
> <br>> >
> <br>> > kaunteya
> <p>> <!doctype html public \"-//w3c//dtd html 4.0 transitional//en\">
> <br>> <html>
> <br>> Kaunteya,
> <br>> <p>Are you trying to write something like this?
> <br>> <blockquote><?xml version=\"1.0\" encoding=\"UTF-8\"?>
> <br>> <br><xsd:schema xmlns:xsd=\"<A
> <br>HREF=\"<a
href=\"http://www.w3.org/2001/XMLSchema\">http://www.w3.org/2001/XMLSchema</a>\"><a
href=\"http://www.w3.org/2001/XMLSchema\">http://www.w3.org/2001/XMLSchema</a></A>\">
> <br>> <br>  <xsd:complexType name=\"Bank_Operation_Code\">
> <br>> <br>    <xsd:sequence>
> <br>> <br>      <xsd:element <b>maxOccurs=\"unbounded\"</b>
> <br>> fixed=\"3!a15d\" name=\"Constraint\" type=\"xsd:string\"/>
> <br>> name=\"_26T\" type=\"xsd:string\"/>
> <br>> <br>    </xsd:sequence>
> <br>> <br>  </xsd:complexType>
> <br>> <br></xsd:schema></blockquote>
> <br>> <blockquote TYPE=CITE>Hello,
> <br>> <br>I am curious as to learn how would I go about defining repititive
> <br>elements
> <br>> <br>in the schema. I have defined a number of XSDComplexTypeDefinition
> <br>> <br>elements. But I cant seem to define their multiple occurences
> in the
> <br>> <br>schema. For e.g.
> <br>> <p><xsd:complexType name=\"Bank_Operation_Code\">
> <br>> <br>  <xsd:element fixed=\"3!a15d\" name=\"Constraint\"
> <br>> <br>  <xsd:element name=\"_26T\" type=\"xsd:string\"/>
> <br>> <br></xsd:complexType>
> <br>> <p>This element occurs multiple times in my XML document. How
> do I define
> <br>> <br>that?
> <br>> <br>This is quite urgent to me. Any help would be much appreciated.
> <br>> <p>thanks
> <br>> <p>kaunteya</blockquote>
> <br>> </html>
> </html>
Re: Repititive elements in Schema: Help! [message #15592 is a reply to message #15558] Sun, 30 March 2003 21:05 Go to previous message
Dave Spriet is currently offline Dave SprietFriend
Another great place to find out what objects can be added to what is to look
at the XML Schema Part 1: Structures Spec
http://www.w3.org/TR/xmlschema-1/
and the concrete containment diagram
http://dev.eclipse.org/viewcvs/indextech.cgi/~checkout~/xsd- home/docs/javado
c/org/eclipse/xsd/package-summary.html#details
Dave
email: spriet@ca.ibm.com
"kaunteya bhattacharya" <bhatta98@hotmail.com> wrote in message
news:b61q7f$s61$1@rogue.oti.com...
> thanks,
> > Kaunteya,
> definition
> complex type
> XSDParticle,
> contains a
complex
> type
> (i.e.,
> > setMaxOccurs(-1)).
> > For example:
> > <xsd:sequence>
name=\"y\">
> > <xsd:sequence>
name=\"_26T\"
> > </xsd:sequence>
> > </xsd:complexType>
> > </xsd:element>
name=\"z\"
> > type=\"x\"/>
> > </xsd:sequence>
> > </xsd:complexType>
> > </xsd:schema>
> > > Hello Ed,
complex
take
and
But
> > > kauntea
> > > > Kaunteya,
> > > > <xsd:sequence>
> > > > </xsd:sequence>
> > > > </xsd:complexType>
> > > > </xsd:schema>
> > > > > Hello,
> elements
the
> > > > > schema. For e.g.
> > > > > </xsd:complexType>
define
> > > > > that?
> > > > > thanks
> > > > > kaunteya
> > > > <html>
> > > > Kaunteya,
A>\">
> > > > <br> <xsd:sequence>
repititive
> > > elements
the
define
> > > > <br>that?
> > > > <p>thanks
> > > > </html>
> > <html>
> > Kaunteya,
group
> > <p>For example:
A>\">
> > <br> <xsd:sequence>
> > name=\"y\">
> > <br> <xsd:sequence>
> > <br>
> name=\"Constraint\"
> > <br>
> > <br> </xsd:element>
> > <br>
realized
complex
not
> > take
types
maxOccur
> > and
> > But
> > <br>kauntea
> > <br>
> > <p>> Kaunteya,
a>\">
> > <br>>
> > <br>>
> > <br>> </xsd:schema>
> > <p>> > Hello,
repititive
> > elements
> > the
> > <br>> >
> > <br>> >
> > define
> > <br>> > that?
> > <br>> >
> > <br>> > thanks
> > <br>> >
> > <br>> > kaunteya
> > <br>> <html>
> > <br>> Kaunteya,
> > <br>HREF=\"<a
a>\"><a
a></A>\">
repititive
> > <br>elements
> > in the
> > do I define
> > <br>> <br>that?
appreciated.
> > <br>> <p>thanks
> > <br>> </html>
> > </html>
Re: Repititive elements in Schema: Help! [message #566692 is a reply to message #15392] Fri, 28 March 2003 10:27 Go to previous message
Kaunteya,
<xsd:sequence>
type="xsd:string"/>
</xsd:sequence>
</xsd:complexType>
</xsd:schema>
> Hello,
> schema. For e.g.
> </xsd:complexType>
> that?
> thanks
> kaunteya
<html>
Kaunteya,
<br>that?
<p>thanks
</html>
Re: Repititive elements in Schema: Help! [message #566729 is a reply to message #15428] Fri, 28 March 2003 12:33 Go to previous message
Hello Ed,
kauntea
> Kaunteya,
> <xsd:sequence>
> type="xsd:string"/>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
> > Hello,
> > schema. For e.g.
> > </xsd:complexType>
> > that?
> > thanks
> > kaunteya
> <html>
> Kaunteya,
> <br>    <xsd:sequence>
elements
> <br>that?
> <p>thanks
> </html>
Re: Repititive elements in Schema: Help! [message #566739 is a reply to message #15461] Fri, 28 March 2003 12:40 Go to previous message
<xsd:sequence>
type="xsd:string"/>
</xsd:sequence>
</xsd:complexType>
<xsd:sequence>
type="xsd:string"/>
</xsd:sequence>
</xsd:complexType>
</xsd:schema>
thanks
kaunteya
> Hello Ed,
> kauntea
> > Kaunteya,
> > <xsd:sequence>
> > type="xsd:string"/>
> > </xsd:sequence>
> > </xsd:complexType>
> > </xsd:schema>
> > > Hello,
elements
> > > schema. For e.g.
> > > </xsd:complexType>
> > > that?
> > > thanks
> > > kaunteya
> > <html>
> > Kaunteya,
> > <br>    <xsd:sequence>
> elements
> > <br>that?
> > <p>thanks
> > </html>
Re: Repititive elements in Schema: Help! [message #566775 is a reply to message #15461] Fri, 28 March 2003 13:45 Go to previous message
Kaunteya,
setMaxOccurs(-1)).
For example:
<xsd:sequence>
<xsd:sequence>
type="xsd:string"/>
</xsd:sequence>
</xsd:complexType>
</xsd:element>
type="x"/>
</xsd:sequence>
</xsd:complexType>
</xsd:schema>
> Hello Ed,
> kauntea
> > Kaunteya,
> > <xsd:sequence>
> > type="xsd:string"/>
> > </xsd:sequence>
> > </xsd:complexType>
> > </xsd:schema>
> > > Hello,
> > > schema. For e.g.
> > > </xsd:complexType>
> > > that?
> > > thanks
> > > kaunteya
> > <html>
> > Kaunteya,
> > <br> <xsd:sequence>
> elements
> > <br>that?
> > <p>thanks
> > </html>
<html>
Kaunteya,
<p>For example:
name="y">
type="xsd:string"/>
name="z" type="x"/>
<br>&nbsp;
take
and
But
<br>kauntea
<br>&nbsp;
<p>> Kaunteya,
<p>> > Hello,
elements
the
<br>> >
<br>> >
define
<br>> > that?
<br>> >
<br>> > thanks
<br>> >
<br>> > kaunteya
<br>> &lt;html>
<br>> Kaunteya,
<br>elements
in the
do I define
<br>> &lt;br>that?
<br>> &lt;p>thanks
<br>> &lt;/html>
</html>
Re: Repititive elements in Schema: Help! [message #566796 is a reply to message #15526] Fri, 28 March 2003 15:37 Go to previous message
thanks,
> Kaunteya,
definition
complex type
XSDParticle,
contains a
type
(i.e.,
> setMaxOccurs(-1)).
> For example:
> <xsd:sequence>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:element>
> type=\"x\"/>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
> > Hello Ed,
> > kauntea
> > > Kaunteya,
> > > <xsd:sequence>
> > > </xsd:sequence>
> > > </xsd:complexType>
> > > </xsd:schema>
> > > > Hello,
elements
> > > > schema. For e.g.
> > > > </xsd:complexType>
> > > > that?
> > > > thanks
> > > > kaunteya
> > > <html>
> > > Kaunteya,
> > > <br> <xsd:sequence>
> > elements
> > > <br>that?
> > > <p>thanks
> > > </html>
> <html>
> Kaunteya,
> <p>For example:
> <br>    <xsd:sequence>
> name=\"y\">
> <br>          <xsd:sequence>
> <br>
name=\"Constraint\"
> <br>
> <br>      </xsd:element>
> <br>
> take
> and
> But
> <br>kauntea
> <br>
> <p>> Kaunteya,
> <br>>
> <br>>
> <br>>      </xsd:schema>
> <p>> > Hello,
> elements
> the
> <br>> >
> <br>> >
> define
> <br>> > that?
> <br>> >
> <br>> > thanks
> <br>> >
> <br>> > kaunteya
> <br>> <html>
> <br>> Kaunteya,
> <br>HREF=\"<a
> <br>elements
> in the
> do I define
> <br>> <br>that?
> <br>> <p>thanks
> <br>> </html>
> </html>
Re: Repititive elements in Schema: Help! [message #566821 is a reply to message #15558] Sun, 30 March 2003 21:05 Go to previous message
Dave
> thanks,
> > Kaunteya,
> definition
> complex type
> XSDParticle,
> contains a
complex
> type
> (i.e.,
> > setMaxOccurs(-1)).
> > For example:
> > <xsd:sequence>
name=\"y\">
> > <xsd:sequence>
name=\"_26T\"
> > </xsd:sequence>
> > </xsd:complexType>
> > </xsd:element>
name=\"z\"
> > type=\"x\"/>
> > </xsd:sequence>
> > </xsd:complexType>
> > </xsd:schema>
> > > Hello Ed,
complex
take
and
But
> > > kauntea
> > > > Kaunteya,
> > > > <xsd:sequence>
> > > > </xsd:sequence>
> > > > </xsd:complexType>
> > > > </xsd:schema>
> > > > > Hello,
> elements
the
> > > > > schema. For e.g.
> > > > > </xsd:complexType>
define
> > > > > that?
> > > > > thanks
> > > > > kaunteya
> > > > <html>
> > > > Kaunteya,
A>\">
> > > > <br> <xsd:sequence>
repititive
> > > elements
the
define
> > > > <br>that?
> > > > <p>thanks
> > > > </html>
> > <html>
> > Kaunteya,
group
> > <p>For example:
A>\">
> > <br> <xsd:sequence>
> > name=\"y\">
> > <br> <xsd:sequence>
> > <br>
> name=\"Constraint\"
> > <br>
> > <br> </xsd:element>
> > <br>
realized
complex
not
> > take
types
maxOccur
> > and
> > But
> > <br>kauntea
> > <br>
> > <p>> Kaunteya,
a>\">
> > <br>>
> > <br>>
> > <br>> </xsd:schema>
> > <p>> > Hello,
repititive
> > elements
> > the
> > <br>> >
> > <br>> >
> > define
> > <br>> > that?
> > <br>> >
> > <br>> > thanks
> > <br>> >
> > <br>> > kaunteya
> > <br>> <html>
> > <br>> Kaunteya,
> > <br>HREF=\"<a
a>\"><a
a></A>\">
repititive
> > <br>elements
> > in the
> > do I define
> > <br>> <br>that?
appreciated.
> > <br>> <p>thanks
> > <br>> </html>
> > </html>
Previous Topic:Repititive elements in Schema: Help!
Next Topic:Why XSDElementDeclaration doesnt have Min/Max Occur?
Current Time: Tue Feb 20 19:48:29 GMT 2018
Powered by FUDForum. Page generated in 0.03107 seconds
