Home » Language IDEs » ServerTools (WTP) » eclipse failed to load JNI shared library
eclipse failed to load JNI shared library [message #1092168] Thu, 22 August 2013 12:12 Go to next message
devon devon is currently offline devon devonFriend
Does anybody know why eclipse is failing to load for me. I checked my system and it is a 64 bit and I have both eclipse and java JDK as a 64 bit. It says,
Failed to load the JNI shared library "C:/Program Files/Java/jdk1.7.0_25/bin/../jre/bin/client/jvm.dll".
I will have my eclipse.ini file attached to this message. Please if you can tell me step by step how to fix it. I will still appreciate any help though. Please help! Thank you.
  • Attachment: eclipse.ini
    (Size: 0.45KB, Downloaded 287 times)
Re: eclipse failed to load JNI shared library [message #1092237 is a reply to message #1092168] Thu, 22 August 2013 13:57 Go to previous messageGo to next message
Roberto Sanchez Herrera is currently offline Roberto Sanchez HerreraFriend
Member
Even if you have installed a java JDK 64 bits, you may have another 32 bits JDK/JRE installed, and that one might be the default.
I suggest adding the -vm argument to your eclipse.ini and see if that helps, something like
-vm
path\to\Java\JDK\64\jre\bin\javaw.exe
I usually add this line at the very beginning of the file. And I always add an new line between -vm and the path, as shown above.
Hope this helps.
Re: eclipse failed to load JNI shared library [message #1092451 is a reply to message #1092237] Thu, 22 August 2013 20:20 Go to previous message
Larry Isaacs is currently offline Larry IsaacsFriend
On 8/22/2013 9:57 AM, Roberto Sanchez Herrera wrote:
> Hello, Even if you have installed a java JDK 64 bits, you may have
> another 32 bits JDK/JRE installed, and that one might be the default. I
> helps, something like -vm path\to\Java\JDK\64\jre\bin\javaw.exe
> Hope this helps.
I checked my "Program Files\Java\jdk1.7.0_25" install and there is no
"client" folder under "jre\bin". There is only the "server" folder
containing a "jvm.dll". It appears this JDK doesn't include the
"client" JVM. I'm not sure what is coming up with the non-existent JVM
as the one to try to execute. I think the -vm approach Roberto mentions
is your best workaround.
Larry
Previous Topic:customizing getDoubleClickStrategy for XML editor
Next Topic:Form Creation
Current Time: Sun Apr 22 07:08:14 GMT 2018
Powered by FUDForum. Page generated in 0.01937 seconds
