Java RMI - Eclipse Plugins [message #1091415] |
Wed, 21 August 2013 13:21 |
Markus Riedl Messages: 20 Registered: November 2012 |
Junior Member |
Greetings,
I know this question gets asked a lot, but I pretty much searched and tried everything (at least thats how it feels) and can not come up with a solution.
So any help would be greatly appreciated.
The situation, packages on the left:
data: java/eclipse project with manifest.mf file, that contains the interfaces
RMI server: normal java program (but with a manifest.mf)
RMI client: eclipse plugin
Connection to the server from the client is working and i get the shared instance.
But as soon as i call methods, where i should get an object implementing an interface from data, i get the exception:
java.rmi.UnmarshalException: error unmarshalling return; nested exception is:
java.lang.ClassNotFoundException:
Curiously enough it does find the interface, rather it does not find the implementation class (contained in the server).
In short: the eclipse plugin wants to load the implementation class from the server.
Obviously i then tried to set the codebase property, so that the eclipse plugin does not try to load the class, but instead downloads it from the server.
-Djava.rmi.server.codebase=file:${workspace_loc}\...\lib\trmi.jar (trmi should create all the necessary stubs and I'm working on a single pc, even when i set it to \bin\ it does not find the class)
Another try was then to run a small (but java program only) client executing the same call, this setup works!
So could you give me a hint what is wrong with this setup?!?
Greetings Markus
[Updated on: Wed, 21 August 2013 13:51] Report message to a moderator
FUDForum. Page generated in 0.01848 seconds
