Home » Language IDEs » Java Development Tools (JDT) » Eclipse Kepler 64-bit is crashing
Eclipse Kepler 64-bit is crashing [message #1083360] Fri, 09 August 2013 21:25 Go to next message
Franco Blaser is currently offline Franco BlaserFriend
I have been trying to fix this issue for a few days now.
I have Eclipse Kepler 64-bit installed on Program Files (x86), JDK 1.7 (64 bit) on Program Files. I did change the `eclipse.ini` to account for
`-vm C:\Program Files\Java\jdk1.7.0_25\bin\javaw.exe`
Eclipse works, but when I do certain changes as for example deleting a Document Type from an xhtml page it goes immediately in (Not responding) and get the following exit code, which still points to `-os win32`. Any suggestions at this point would be greatly appreciated:
Java was started but returned `exit code=-805306369`
C:\Program Files\Java\jdk1.7.0_25\bin\javaw.exe here is the full eclipse dump
As background info this is a Maven web project using Srping, Spring WebFlow, JSF, mySql db, hibernate...
As soon as I go to delete the -
<!DOCTYPE composition PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN">
from any .xhtml file w/o even saving it goes into Not Responding...then upon Task Manager kill I get the dump above (it also says Java(TM) Platform SE binary is not responding... uninstalled and re-installed a few times...no change. Help help!!
Re: Eclipse Kepler 64-bit is crashing [message #1084241 is a reply to message #1083360] Sun, 11 August 2013 07:02 Go to previous message
Franco,
The information in this wiki page should help you determine the cause of
the deadlock: http://wiki.eclipse.org/How_to_report_a_deadlock
From your description, it doesn't sound like a JDT error but more
likely and error from the tool that provides the editor for *.xhtml
documents, perhaps WTP or some other tool you've installed that
processes such files; JDT doesn't.
Previous Topic:Eclipse Kepler still slow
Next Topic:Realize Objects.hashCode() and Objects.equals(...) implementation of Java 7 within eclipse
Current Time: Sun Apr 22 16:51:22 GMT 2018
Powered by FUDForum. Page generated in 0.01420 seconds
