Home » Eclipse Projects » Commercial » [ANN] OrindaBuild Java Development Accelerator for PL/SQL and Oracle
[ANN] OrindaBuild Java Development Accelerator for PL/SQL and Oracle [message #15104] Mon, 31 March 2008 08:25
Originally posted by: os_neo.orindasoft.com
OrindaBuild is now available as a plugin for Eclipse 3.3.
OrindaBuild helps you interact with Oracle by creating a Java service to
call your PL/SQL procedures and SQL statements as well as access tables.
OrindaBuild is a commercial product but an unlimited number of expiring
demo
versions can be downloaded.
OrindaBuild examines your SQL statements and PL/SQL procedures and writes
the Java source files for a service that can be easily integrated with
your environment. Using OrindaBuild involves minimal changes to your SQL
statements and no changes to your PL/SQL.
Unlike alternative approaches, OrindaBuild does not require that you
change your code, your IDE, your development environment, or your database
schema. OrindaBuild does not place limitations of the type or order of
parameters in PL/SQL procedures and happily supports records and arrays.
OrindaBuild also does conventional Object/Relational persistence.
For more information see here:
http://www.orindasoft.com/public/ecfeatures.php4
To download and install from an update site use this URL:
http://www.orindasoft.com/public/ec33/site.xml
The OrindaBuild plugin for Eclipse is 100% new code and follows on from
our successful plugins for Oracle JDeveloper and Oracle SQL Developer.
David Rolfe
Orinda Software
Dublin, Ireland
Previous Topic:test
Next Topic:[ANN] OrindaBuild Java Development Accelerator for PL/SQL and Oracle
Current Time: Thu May 24 12:01:32 GMT 2018
Powered by FUDForum. Page generated in 0.01987 seconds
