Home » Archived » Visual Editor (VE) » How to import JDeveloper source code VE ?
Re: How to import JDeveloper source code VE ? [message #15888 is a reply to message #15093] |
Wed, 21 January 2004 01:52 |
Ivan Messages: 149 Registered: July 2009 |
--------------010208010401030107080100
Content-Type: text/plain; charset=us-ascii; format=flowed
Thanks for the repply. Here is JDeveloper 10g generated source code.
It look like JBuilder generated code. They used jbInit() as well.
import javax.swing.JFrame;
import java.awt.Dimension;
import javax.swing.JButton;
import java.awt.Rectangle;
import java.awt.event.ActionListener;
import java.awt.event.ActionEvent;
public class example extends JFrame
private JButton jButton1 = new JButton();
public example()
try
jbInit();
catch(Exception e)
e.printStackTrace();
private void jbInit() throws Exception
this.getContentPane().setLayout(null);
this.setSize(new Dimension(400, 300));
jButton1.setText("jButton1");
jButton1.setBounds(new Rectangle(282, 230, 88, 26));
jButton1.addActionListener(new example_jButton1_actionAdapter(this));
this.getContentPane().add(jButton1, null);
void jButton1_actionPerformed(ActionEvent e)
class example_jButton1_actionAdapter implements ActionListener
example adaptee;
example_jButton1_actionAdapter(example adaptee)
this.adaptee = adaptee;
public void actionPerformed(ActionEvent e)
adaptee.jButton1_actionPerformed(e);
name="example.java"
Content-Disposition: inline;
filename="example.java"
public example()
try
jbInit();
catch(Exception e)
example adaptee;
--------------010208010401030107080100--
Re: How to import JDeveloper source code VE ? [message #16394 is a reply to message #15888] |
Thu, 22 January 2004 14:08 |
--------------060100010605000402070407
The problem is that VA at this time does not support implicit components
(see https://bugs.eclipse.org/bugs/show_bug.cgi?id=48552 )
... i.e., VE will not parse
You will have to do something like:
this.setContenPane(myContentPane_initialized_above) ;
myContentPane_initialized_above.add(jButton1,null);
included is the modified source that will come up on VE
Ivan wrote:
> Thanks
> public example()
> try
> jbInit();
> catch(Exception e)
> example adaptee;
> public example()
> try
> jbInit();
> catch(Exception e)
> example adaptee;
Content-Type: text/java;
name="example.java"
import javax.swing.JPanel;
private JPanel contentPane = new JPanel();
public example()
try
jbInit();
catch(Exception e)
// need an explicity content pane
this.setContentPane(contentPane) ;
contentPane.add(jButton1, null);
example adaptee;
--------------060100010605000402070407--
Re: How to import JDeveloper source code VE ? [message #16818 is a reply to message #16394] |
Sun, 25 January 2004 13:24 |
--------------030300000901060506000307
Thanks! it works!
> components (see https://bugs.eclipse.org/bugs/show_bug.cgi?id=48552 )
> Ivan wrote:
>> Thanks
>> public example()
>> try
>> jbInit();
>> catch(Exception e)
>> example adaptee;
>> public class example extends JFrame {
>> public example()
>> try
>> jbInit();
>> catch(Exception e)
>> class example_jButton1_actionAdapter implements ActionListener {
>> example adaptee;
> public example()
> try
> jbInit();
> catch(Exception e)
> example adaptee;
Content-Type: text/html; charset=us-ascii
<html>
<head>
<title></title>
</head>
<body>
Thanks! it works!<br>
<br>
Gili Mendel wrote:<br>
<blockquote type="cite" cite="midbuoldr$t5u$1@eclipse.org">The problem is
that VA at this time does not support implicit components (see <a class="moz-txt-link-freetext" href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=48552">https://bugs.eclipse.org/bugs/show_bug.cgi?id=48552</a>
) <br>
<br>
... i.e., VE will not parse <br>
this.getContentPane( ).add(jButton1, null); <br>
<br>
You will have to do something like: <br>
this.setContenPane(m yContentPane_initialized_above) ; <br>
myContentPane_initia lized_above.add(jButton1,null); <br>
<br>
included is the modified source that will come up on VE <br>
<br>
Ivan wrote: <br>
<blockquote type="cite">Hi, <br>
<br>
Thanks for the repply. Here is JDeveloper 10g generated source code. <br>
It look like JBuilder generated code. They used jbInit() as well. <br>
<br>
Thanks <br>
<br>
<br>
<br>
import javax.swing.JFrame; <br>
import java.awt.Dimension; <br>
import javax.swing.JButton; <br>
import java.awt.Rectangle; <br>
import java.awt.event.ActionListener; <br>
import java.awt.event.ActionEvent; <br>
<br>
public class example extends JFrame <br>
{ <br>
private JButton jButton1 = new JButton(); <br>
<br>
public example() <br>
{ <br>
try <br>
{ <br>
jbInit(); <br>
} <br>
catch(Exception e) <br>
{ <br>
e.printStackTrace(); <br>
} <br>
<br>
} <br>
<br>
private void jbInit() throws Exception <br>
{ <br>
this.getContentPane().setLayout(null); <br>
this.setSize(new Dimension(400, 300)); <br>
jButton1.setText("jButton1"); <br>
jButton1.setBounds(new Rectangle(282, 230, 88, 26)); <br>
jButton1.addActionListener(new example_jButton1_actionAdapter(this)); <br>
this.getContentPane().add(jButton1, null); <br>
} <br>
<br>
void jButton1_actionPerformed(ActionEvent e) <br>
{ <br>
} <br>
} <br>
class example_jButton1_actionAdapter implements ActionListener <br>
{ <br>
example adaptee; <br>
<br>
example_jButton1_actionAdapter(example adaptee) <br>
{ <br>
this.adaptee = adaptee; <br>
} <br>
<br>
public void actionPerformed(ActionEvent e) <br>
{ <br>
adaptee.jButton1_actionPerformed(e); <br>
} <br>
} <br>
<br>
<br>
<br>
<br>
------------------------------------------------------------ ------------ <br>
<br>
<br>
public class example extends JFrame { <br>
<br>
{ <br>
try <br>
{ <br>
jbInit(); <br>
} <br>
{ <br>
} <br>
<br>
} <br>
<br>
{ <br>
<br>
} <br>
<br>
{ <br>
} <br>
} <br>
class example_jButton1_actionAdapter implements ActionListener { <br>
<br>
{ <br>
} <br>
<br>
{ <br>
} <br>
} <br>
</blockquote>
<br>
<pre wrap="">
<hr width="90%" size="4">
public example()
try
jbInit();
catch(Exception e)
example adaptee;
}</pre>
</blockquote>
<br>
</body>
</html>
--------------030300000901060506000307--
Re: How to import JDeveloper source code VE ? [message #578724 is a reply to message #15093] |
public example()
try
jbInit();
catch(Exception e)
example adaptee;
name="example.java"
public example()
try
jbInit();
catch(Exception e)
example adaptee;
Re: How to import JDeveloper source code VE ? [message #579010 is a reply to message #15888] |
Gili Mendel Messages: 338 Registered: July 2009 |
Ivan wrote:
> Thanks
> public example()
> try
> jbInit();
> catch(Exception e)
> example adaptee;
> public example()
> try
> jbInit();
> catch(Exception e)
> example adaptee;
name="example.java"
public example()
try
jbInit();
catch(Exception e)
example adaptee;
Re: How to import JDeveloper source code VE ? [message #579410 is a reply to message #16394] |
Thanks! it works!
> Ivan wrote:
>> Thanks
>> public example()
>> try
>> jbInit();
>> catch(Exception e)
>> example adaptee;
>> public example()
>> try
>> jbInit();
>> catch(Exception e)
>> example adaptee;
> public example()
> try
> jbInit();
> catch(Exception e)
> example adaptee;
<html>
<head>
<title></title>
</head>
<body>
<br>
) <br>
<br>
<br>
<br>
<br>
Ivan wrote: <br>
<br>
<br>
Thanks <br>
<br>
<br>
<br>
<br>
{ <br>
<br>
{ <br>
try <br>
{ <br>
jbInit(); <br>
} <br>
{ <br>
} <br>
<br>
} <br>
<br>
{ <br>
} <br>
<br>
{ <br>
} <br>
} <br>
{ <br>
<br>
{ <br>
} <br>
<br>
{ <br>
} <br>
} <br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
{ <br>
try <br>
{ <br>
jbInit(); <br>
} <br>
{ <br>
} <br>
<br>
} <br>
<br>
{ <br>
<br>
} <br>
<br>
{ <br>
} <br>
} <br>
<br>
{ <br>
} <br>
<br>
{ <br>
} <br>
} <br>
</blockquote>
<br>
<pre wrap="">
public example()
try
jbInit();
catch(Exception e)
example adaptee;
}</pre>
</blockquote>
<br>
</body>
</html>
Current Time: Sat Apr 20 02:28:13 GMT 2024
Powered by FUDForum. Page generated in 0.03782 seconds
