Home » Modeling » UML2 Tools » MDT UML2TOOLS SDK (Incubation) 0.9.1 (build 2010-07-08)(Where can I get it from?)
icon5.gif  MDT UML2TOOLS SDK (Incubation) 0.9.1 (build 2010-07-08) [message #1079991] Mon, 05 August 2013 10:30 Go to next message
Christian Balzer is currently offline Christian BalzerFriend
Hi everybody,
I'm trying to locate a zipped update site (or a link I can use with the command line tools to create my own) for "MDT UML2TOOLS SDK (Incubation) 0.9.1 (build 2010-07-08)", which is a dependency for a tool I want to use (Borland Together 12.5). Apparently there once was a download for this version, but all download paths on the server seem to have changed since then: http://www.eclipse.org/forums/index.php/t/169482/
Where I work we can't just use Eclipse's install manager to go online itself, we have to get the plugin packages and take it form there...
I'd appreciate if you could help me find the version I'm after.
Christian
P.S.: This will run on Eclipse 4.2.2
P.P.S.S.: Build 2009-07-24 fails to install due to the OCL problem. I suppose I could fix that, but I'm not sure there are any other differences between the builds?
Re: MDT UML2TOOLS SDK (Incubation) 0.9.1 (build 2010-07-08) [message #1080071 is a reply to message #1079991] Mon, 05 August 2013 12:31 Go to previous messageGo to next message
Ed Willink is currently offline Ed WillinkFriend
The most recent working URLs that I can see are
http://download.eclipse.org/modeling/mdt/uml2tools/downloads/drops/0.9.0/R200906190654/
http://download.eclipse.org/modeling/mdt/uml2tools/downloads/drops/0.9.1/I200907241018/
http://download.eclipse.org/modeling/mdt/uml2tools/downloads/drops/0.10.0/I201103290512/mdt-uml2tools-Update-incubation-I201103290512.zip
[The referred posts mentioning http://modeling.eclipse.org are typos.]
Ed Willink
On 05/08/2013 13:11, Christian Balzer wrote:
> Hi everybody,
> Best regards,
> Christian
> http://wiki.eclipse.org/MDT/OCL/FAQ#How_do_I_workaround_org.eclipse.emf.ocl_deprecation_in_Helios_and_later.3F.
Re: MDT UML2TOOLS SDK (Incubation) 0.9.1 (build 2010-07-08) [message #1080078 is a reply to message #1080071] Mon, 05 August 2013 12:45 Go to previous messageGo to next message
Hi Ed,
Thank you for the links and clarification.
Any idea what happened to the builds Christian Waniek mentioned here: http://www.eclipse.org/forums/index.php/mv/msg/169482/549341/#msg_549341
Christian
Re: MDT UML2TOOLS SDK (Incubation) 0.9.1 (build 2010-07-08) [message #1080116 is a reply to message #1080078] Mon, 05 August 2013 13:39 Go to previous message
No idea, but UML2Tools is dead, so unless you want to participate in a
reactivation, I strongly recommend that you move on and try to help make
Papyrus a really good tool.
Ed Willink
On 05/08/2013 13:45, Christian Balzer wrote:
> Hi Ed,
> Best regards,
> Christian
Previous Topic:need help installing UML2 Tools
Next Topic:Topcased: missing required/provided interface
Current Time: Thu May 24 16:09:54 GMT 2018
Powered by FUDForum. Page generated in 0.02199 seconds
