Home » Newcomers » Newcomers » axis2 plugin not loading
axis2 plugin not loading [message #1076435] Wed, 31 July 2013 11:51
David Perra is currently offline David PerraFriend
Hello.
I am trying to install the Axis2 1.6.2 Code Generator Wizard in my Eclipse 4.1.2 but it does not show up.
I tried copying the jar file under the plugins and dropins directories, restarting after that.
I went to the OSGi console and executed the command 'ss', but the plugin does not appear on the list, so I do not know what else to try (I even checked the MD5 checksum just in case the download was corrupted).
Thank you very much.
Previous Topic:JAXB exception in RAD 8 using WAS 8 server
Next Topic:uninstall BIRT framework from eclipse kepler framework
Current Time: Fri Apr 27 02:51:00 GMT 2018
Powered by FUDForum. Page generated in 0.02629 seconds
