Re: rotate a text inside a table cell ? [message #813985 is a reply to message #813792] |
Mon, 05 March 2012 22:49 |
BIRT has an example extension project that does rotated text. It does
this by converting the text to an image. If you do not want to build
the plugin let me know what version you need it for and I will show you
where to get it.
Jason
On 3/5/2012 1:07 PM, Jesh Stha wrote:
> Can anyone please help with this problem?
> I am trying to rotate the text in table cell vertical orientation.
> Please help.
Re: rotate a text inside a table cell ? [message #855460 is a reply to message #813985] |
Tue, 24 April 2012 21:05 |
Devin Wilson Messages: 1 Registered: April 2012 |
Junior Member |
Hey I'm really hoping to get some help with this. I went through the 3rd Edition 'Integrating and Extending BIRT' instructions for creating a rotated text element. However, I'm developing in BIRT 3.7 and after I integrate the plugin and run a test report with a single rotated text element, I receive this:
org.eclipse.birt.report.service.api.ReportServiceException: Error happened while running the report.
at org.eclipse.birt.report.service.ReportEngineService.throwDummyException(ReportEngineService.java:1107)
at org.eclipse.birt.report.service.ReportEngineService.runAndRenderReport(ReportEngineService.java:935)
at org.eclipse.birt.report.service.BirtViewerReportService.runAndRenderReport(BirtViewerReportService.java:973)
at org.eclipse.birt.report.service.actionhandler.BirtGetPageAllActionHandler.__execute(BirtGetPageAllActionHandler.java:131)
at org.eclipse.birt.report.service.actionhandler.AbstractBaseActionHandler.execute(AbstractBaseActionHandler.java:90)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseDocumentProcessor.__executeAction(AbstractBaseDocumentProcessor.java:47)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.executeAction(AbstractBaseComponentProcessor.java:143)
at org.eclipse.birt.report.soapengine.processor.BirtDocumentProcessor.handleGetPageAll(BirtDocumentProcessor.java:183)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.process(AbstractBaseComponentProcessor.java:112)
at org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingImpl.getUpdatedObjects(BirtSoapBindingImpl.java:66)
at org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCProvider.java:397)
at org.apache.axis.providers.java.RPCProvider.processMessage(RPCProvider.java:186)
at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvider.java:323)
at org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrategy.java:32)
at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService.java:454)
at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281)
at org.apache.axis.transport.http.AxisServlet.doPost(AxisServlet.java:699)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.doPost(BirtSoapMessageDispatcherServlet.java:265)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.service(BirtSoapMessageDispatcherServlet.java:122)
at org.eclipse.equinox.http.registry.internal.ServletManager$ServletWrapper.service(ServletManager.java:180)
at org.eclipse.equinox.http.servlet.internal.ServletRegistration.service(ServletRegistration.java:61)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.processAlias(ProxyServlet.java:126)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.service(ProxyServlet.java:60)
at org.eclipse.equinox.http.jetty.internal.HttpServerManager$InternalHttpServiceServlet.service(HttpServerManager.java:317)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:511)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:390)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:182)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:765)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:322)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:542)
at org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:939)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:756)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:218)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:404)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:409)
at org.mortbay.thread.QueuedThreadPool$PoolThread.run(QueuedThreadPool.java:582)
Caused by: org.eclipse.birt.report.engine.api.EngineException: Error happened while running the report.
at org.eclipse.birt.report.engine.api.impl.EngineTask.handleFatalExceptions(EngineTask.java:2265)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:190)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRenderTask.java:77)
at org.eclipse.birt.report.service.ReportEngineService.runAndRenderReport(ReportEngineService.java:929)
... 49 more
Caused by: org.eclipse.swt.SWTError: Not implemented [multiple displays]
at org.eclipse.swt.SWT.error(SWT.java:4308)
at org.eclipse.swt.widgets.Display.checkDisplay(Display.java:760)
at org.eclipse.swt.widgets.Display.create(Display.java:896)
at org.eclipse.swt.graphics.Device.(Device.java:157)
at org.eclipse.swt.widgets.Display.(Display.java:500)
at org.eclipse.swt.widgets.Display.(Display.java:491)
at org.eclipse.birt.sample.reportitem.rotatedlabel.util.GraphicsUtil.(GraphicsUtil.java:37)
at org.eclipse.birt.sample.reportitem.rotatedlabel.RotatedLabelPresentationImpl.onRowSets(RotatedLabelPresentationImpl.java:76)
at org.eclipse.birt.report.engine.extension.ReportItemPresentationBase.onRowSets(ReportItemPresentationBase.java:197)
at org.eclipse.birt.report.engine.presentation.LocalizedContentVisitor.processExtendedContent(LocalizedContentVisitor.java:1022)
at org.eclipse.birt.report.engine.presentation.LocalizedContentVisitor.localizeForeign(LocalizedContentVisitor.java:578)
Can you point me in the direction of a plugin that will work with BIRT and Indigo 3.7? Is rotated text even possible in BIRT 3.7? Anywhere I find a plugin or hear something about rotating text it's in reference to 2.X versions. If it is possible and I am doing something wrong, do you have any insight into what the issue is with my configuration?
[Updated on: Tue, 24 April 2012 21:08] Report message to a moderator
Re: rotate a text inside a table cell ? [message #856379 is a reply to message #855460] |
Wed, 25 April 2012 15:59 |
Devin,
Can you try the attached example. I recompiled in 3.7.1, changed the ui
plugin dependencies to optional and exported the jar. The jar and the
project are in the zip.
BTW when I export the jar using the manifest editor, I just copy the
created jar to the web-inf/lib of the 3.7.1 viewer.
Jason
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 49 more
> at
> at
> at
> at
> at
> 2.X versions. If not, do you have any insight into what the issue is
FUDForum. Page generated in 0.03720 seconds
