Home » Eclipse Projects » GEF » GEF examples.text selection
GEF examples.text selection [message #158508] Thu, 18 November 2004 11:46 Go to next message
Rob Grzywinski is currently offline Rob Grzywinski
While selecting text in the TextEditor example if you move the mouse outside
of the editor or outside of where there is an EditPart selection does not
continue. For example if you begin selection on the "C" in "Copyright" (in
the example) but move the mouse to the left and then around below the
paragraph none of the text is selected (but one would expect that it would).
I have traced this back to SelectionRangeDragTracker's
handleDragInProgress(). Specifically, getCurrentTextLocation(). Its
getCurrentViewer().findObjectAt(getLocation()) is too limiting. Rather than
using the default "findObjectAt()" it would appear that an suped up version
is needed that would find the object that is "closest" (where that is not
the Euclidean distance).
Should I open an RFE for this?
Rob Grzywinski
Re: GEF examples.text selection [message #158596 is a reply to message #158508] Thu, 18 November 2004 15:48 Go to previous message
Eclipse User
Yes, we obviously need a closest location algorithm. For example, you can't
click on the blank space after a short line of text. This is work in
progress and many features are obviously missing or incomplete. Feel free
to open bugzillas, but this wasn't something we were going to forget about.
If you have the solution, even better!
"Rob Grzywinski" <rgrzywinski@realityinteractive.com> wrote in message
news:cnijkb$8qo$1@www.eclipse.org...
outside
(in
would).
than
version
> Rob Grzywinski
Previous Topic:How to get information from user in the getCreateCommand(CreateRequest request)
Next Topic:Non-resizable movable nodes
Current Time: Fri May 24 02:03:30 EDT 2013
Powered by FUDForum. Page generated in 0.01922 seconds
