Home » Eclipse Projects » GEF » Undo with keyboard
Undo with keyboard [message #158470] Thu, 18 November 2004 14:41 Go to next message
Originally posted by: arnaud.knowesis.fr
I cannot undo in my gef editor with keyboard but I can delete
I create a keyHandler :
keyHandler = new KeyHandler();
keyHandler.put(KeyStroke.getPressed(SWT.DEL, 127, 0),
getActionRegistry().getAction(ActionFactory.DELETE.getId())) ;
keyHandler.put(KeyStroke.getPressed(26, SWT.CTRL),
getActionRegistry().getAction(ActionFactory.UNDO.getId()));
keyHandler.put(KeyStroke.getPressed(25, SWT.CTRL),
getActionRegistry().getAction(ActionFactory.REDO.getId()));
and I reference it in my configureGraphicalViewer method :
GraphicalViewerKeyHandler keyHandler=new
GraphicalViewerKeyHandler(getGraphicalViewer());
keyHandler.setParent(getCommonKeyHandler(getGraphicalViewer( )));
getGraphicalViewer().setKeyHandler(this.keyHandler);
It works fine with the delet command but doesn t seem to run with the
undo/redo
thx
Re: Undo with keyboard [message #158478 is a reply to message #158470] Thu, 18 November 2004 16:19 Go to previous messageGo to next message
I'm not sure if those are the correct keystrokes for undo. Have you put a
breakpoint in handleKeyPressed to see what the event actually is and if it
gets sent at all?
Undo/Redo are global actions with keybindings associated with the menu
entries. The menu entries might be intercepting the keystrokes (although
I've been told that this isn't the case if the action is disabled). Either
way, you'll want to register action handlers for those global actions since
that allows the user to use the menu as well. The same it true for delete.
KeyHandler is intended for stuff that doesn't appear in menus, although for
previous version of eclipse DELETE was not stolen by hte edit menu
"Arnaud" <arnaud@knowesis.fr> wrote in message
news:cnicai$pa8$1@www.eclipse.org...
> undo/redo
> thx
Re: Undo with keyboard [message #159022 is a reply to message #158478] Mon, 22 November 2004 10:32 Go to previous messageGo to next message
I tried some changes :
I don t bind CTRL + Z and DEL key with the KeyHandler
and I create an ActionBarContributor :
protected void buildActions() {
IWorkbenchAction
undo=ActionFactory.UNDO.create(getPage().getWorkbenchWindow( ));
addRetargetAction((RetargetAction) undo);
IWorkbenchAction
redo=ActionFactory.REDO.create(getPage().getWorkbenchWindow( ));
addRetargetAction((RetargetAction) redo);
IWorkbenchAction
delete=ActionFactory.DELETE.create(getPage().getWorkbenchWin dow());
addRetargetAction((RetargetAction) delete);
The actionDefinitionId is correctly set, (the key binding is correctly
shown in my Edit Menu) but the accelerator CTRL + Z or Del doesnt work...
> gets sent at all?
Re: Undo with keyboard [message #159126 is a reply to message #159022] Mon, 22 November 2004 21:25 Go to previous messageGo to next message
Pratik Shah is currently offline Pratik ShahFriend
Are you saying it works from the menu and not via the keyboard? I'm
assuming you've registered the ActionBarContributor properly in the
plugin.xml.
news:cnsf79$c7m$1@www.eclipse.org...
> IWorkbenchAction
> IWorkbenchAction
> IWorkbenchAction
a
it
> > gets sent at all?
Either
since
delete.
for
Re: Undo with keyboard [message #159367 is a reply to message #159126] Thu, 25 November 2004 14:03 Go to previous message
I found the problem ...
the undo action wasn t correctly registered in the workbenchadvisor class
> plugin.xml.
>> IWorkbenchAction
>> IWorkbenchAction
>> IWorkbenchAction
> a
> it
>>>gets sent at all?
> Either
> since
> delete.
> for
Previous Topic:where to store customized palette?
Next Topic:GEF examples.text selection
Current Time: Wed May 23 08:43:33 GMT 2018
Powered by FUDForum. Page generated in 0.02336 seconds
