Home » Eclipse Projects » Plugin Development Environment (PDE) » PDE doesn't recognize dropins folder in 3.4 target (p2)
PDE doesn't recognize dropins folder in 3.4 target (p2) [message #14828] |
Fri, 01 August 2008 19:25 |
Originally posted by: none.ibm.com
I've created a custom target using the dropins folder. I launched the
custom target directly once, and it started up fine with all of the plugins
and features recognized that I unzipped into the $eclipse_root$/dropins
folder. But when I try to use it as my PDE target from another R3.4 IDE,
only the plug-ins in eclipse/plugins are recognized.
Does the PDE support p2 yet? What about using links?
Re: PDE doesn't recognize dropins folder in 3.4 target (p2) [message #14858 is a reply to message #14828] |
Sat, 02 August 2008 03:03 |
We support p2 and the old Update system. Are you aware of how the new
target platform preference works?
http://mea-bloga.blogspot.com/2008/04/new-target-platform-pr eference.html
If checked, we will attempt to read the p2 configuration (or update
configuration) and build the target platform based off of that. If not,
we will revert to just scanning the directory for plug-ins.
~ Chris
Re: PDE doesn't recognize dropins folder in 3.4 target (p2) [message #14911 is a reply to message #14858] |
Mon, 04 August 2008 18:08 |
Todd E. Williams Messages: 54 Registered: July 2009 |
Member |
Randy,
I believe the 'new target platform preference' is non-functional in Eclipse
3.4 based on what's documented in these bug reports
https://bugs.eclipse.org/bugs/show_bug.cgi?id=233670 ,
https://bugs.eclipse.org/bugs/show_bug.cgi?id=238949 and in particular this
comment https://bugs.eclipse.org/bugs/show_bug.cgi?id=238949#c14
Chris, please correct this assertion if you believe it to be in err.
Todd
"Chris Aniszczyk" <zx@code9.com> wrote in message
news:g70ipb$bks$1@build.eclipse.org...
>> plugins and features recognized that I unzipped into the
>> $eclipse_root$/dropins folder. But when I try to use it as my PDE target
>> from another R3.4 IDE, only the plug-ins in eclipse/plugins are
>> recognized.
> configuration) and build the target platform based off of that. If not, we
> Cheers,
> ~ Chris
Re: PDE doesn't recognize dropins folder in 3.4 target (p2) [message #15227 is a reply to message #14911] |
Mon, 04 August 2008 19:55 |
Thanks Chris. Todd, it seems to work for me. I think there are still
issues or differences between what PDE detects and what gets auto-detected
when launching the target (233670 seemed along this line). For example,
simply unzipping plugins in the "plugins" folder will be detected by both
the launched target and the PDE. But unzipping plugins into the "dropins"
folder will not get detected by the PDE until the target is launched and
updates the installation. I think these differences are acceptible, but not
easy to understand in the current tooling. Also, there should be a way to
invoke the p2 auto-install via the PDE without having to launch the target
manually and then reloading the target from the PDE pref pages. Also, when
PDE launches a p2 target, it should somehow ask p2 whether or not any
auto-install tasks need to be done. If yes, it should prompt the user to
either:
1) Continue launch and prevent auto-install from doing anything
2) Abort launch, run auto-install, reload PDE target, recompile workspace,
relaunch
--Randy
"Todd Williams" <todd@genuitec.com> wrote in message
news:g77gis$l7d$1@build.eclipse.org...
> Randy,
> Eclipse 3.4 based on what's documented in these bug reports
> this comment https://bugs.eclipse.org/bugs/show_bug.cgi?id=238949#c14
> Todd
Re: PDE doesn't recognize dropins folder in 3.4 target (p2) [message #15291 is a reply to message #15227] |
Mon, 04 August 2008 20:12 |
> either:
> relaunch
Randy, it's my hope to wean people off the target platform page and get
more people using target definition. With some additional enhancements
to the target definition file, we should have a solid story for building
and shared target platforms.
It's hard for PDE to figure out whether something you unzipped onto a
target install is something that we should poke p2 to install. We had
this exact same problem before with platform.xml files... if you
unzipped a fresh Ecilpse, started it... closed it. Downloaded EMF and
GEF, installed it by unzipping into plug-ins directory... PDE would
still miss EMF/GEF from the target platform because before 3.4, PDE
would find the platform.xml file and notice that it didn't contain
EMF/GEF yet since the target hasn't been launched.
Thanks for your feedback and I appreciate your patience.
~ Chris
Re: PDE doesn't recognize dropins folder in 3.4 target (p2) [message #15323 is a reply to message #15291] |
Mon, 04 August 2008 22:21 |
Originally posted by: ekkehard.gentz-software.de
>> auto-detected when launching the target (233670 seemed along this
>> line). For example, simply unzipping plugins in the "plugins" folder
>> will be detected by both the launched target and the PDE. But
>> unzipping plugins into the "dropins" folder will not get detected by
>> the PDE until the target is launched and updates the installation. I
>> think these differences are acceptible, but not easy to understand in
>> the current tooling. Also, there should be a way to invoke the p2
>> auto-install via the PDE without having to launch the target manually
>> and then reloading the target from the PDE pref pages. Also, when PDE
>> to either:
>> workspace, relaunch
this is also my experience. I'm using target definition and it works great.
if one can work with multiple versions / locations of bundles in target
definition files this would be a great help. (bugzilla 233095) at the
moment I have to manage my different locations for a target definition
file that theres only a unique set of bundles over all
ekke
> Cheers,
> ~ Chris
Re: PDE doesn't recognize dropins folder in 3.4 target (p2) [message #15356 is a reply to message #15291] |
Tue, 05 August 2008 14:41 |
> more people using target definition. With some additional enhancements to
> the target definition file, we should have a solid story for building and
If this is similar to sharing launch definitions, the real problem with
launch definitions is that they are negatives rather than positives (I've
reported bugzilla already). Please make targets additive rather than
subtractive.
It would also be nice if I could have two targets simultaneously available,
and I could simply run one launch profile or the other to determine not only
my workspace plug-ins, but my target plug-ins as well. This would be tricky
since recompilation is sometimes necessary (or maintaining multiple "./bin"
folders per active PDE target).
As an example use case, Rational Team Concert ships on eclipse 3.3, but
unofficially tolerates eclipse 3.4. Testing and maintaining this 3.4
compatibility is a challenge.
If launching the target would install it, then PDE should poke p2 to install
it.
> this exact same problem before with platform.xml files... if you unzipped
> a fresh Ecilpse, started it... closed it. Downloaded EMF and GEF,
> installed it by unzipping into plug-ins directory... PDE would still miss
> EMF/GEF from the target platform because before 3.4, PDE would find the
> platform.xml file and notice that it didn't contain EMF/GEF yet since the
Really? That's not my experience. Maybe you mean if the new option is
turned on, then PDE would miss EMF/GEF because it doesn't simulate the
discovery?
Re: PDE doesn't recognize dropins folder in 3.4 target (p2) [message #16227 is a reply to message #15194] |
Tue, 12 August 2008 07:45 |
sorry chris,
it took some days to find the time to test
and you know it always consumes much time
so i tested my scenarios from bugzilla 238950 (duplicate of 235336)
using 3.5.M1 and it works:
I made two shared installations,
then put someting in the dropins folder of one installation
and now PDE - TargetPlatform 'knows' the plugins from bundle pool
in both installations and from the dropins in one installation
ciao
ekke
> ekke wrote:
>> good news :-)
> Ekke, can you help out with testing a bit? I'm curious if this problem
> was fixed with this bug:
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=235336
> Can you grab an Eclipse 3.5M1 build after 7/30?
> Like
> http://download.eclipse.org/eclipse/downloads/drops/I2008080 3-2135/index.php
> Thanks, I hope to track this guy down before 3.5M1 and 3.4.1 but
> reproducing this guy takes awhile.
> Cheers,
> ~ Chris
Re: PDE doesn't recognize dropins folder in 3.4 target (p2) [message #575116 is a reply to message #14858] |
Member |
Randy,
Todd
>> recognized.
> Cheers,
> ~ Chris
Re: PDE doesn't recognize dropins folder in 3.4 target (p2) [message #575343 is a reply to message #14911] |
Randy Hudson Messages: 123 Registered: July 2009 |
either:
relaunch
--Randy
> Randy,
> Todd
Re: PDE doesn't recognize dropins folder in 3.4 target (p2) [message #575406 is a reply to message #15227] |
Chris Aniszczyk Messages: 674 Registered: July 2009 |
> either:
> relaunch
~ Chris
Re: PDE doesn't recognize dropins folder in 3.4 target (p2) [message #575443 is a reply to message #15291] |
>> to either:
>> workspace, relaunch
ekke
> Cheers,
> ~ Chris
Re: PDE doesn't recognize dropins folder in 3.4 target (p2) [message #575475 is a reply to message #15291] |
subtractive.
it.
discovery?
Re: PDE doesn't recognize dropins folder in 3.4 target (p2) [message #576123 is a reply to message #15194] |
sorry chris,
ciao
ekke
> ekke wrote:
>> good news :-)
> Like
> Cheers,
> ~ Chris
Current Time: Thu Apr 25 10:55:16 GMT 2024
Powered by FUDForum. Page generated in 0.40272 seconds
