Home » Newcomers » Newcomers » Formatter - Feature Request
Formatter - Feature Request [message #1069193] Mon, 15 July 2013 11:38 Go to next message
Tony Herstell is currently offline Tony HerstellFriend
Hi Guys,
From my old Ada days we always force the code through the formatter before checking it in.
I still enforce this "good habit" myself... well the formatter needs a fixup... for Java anyhow.
If you use it you will see what I mean!!!!
This is what I suggest it does to REALLY rock:
All below in alphabetic order unless specified
AND... if possible... all below in folding areas unless specified
Static logging stuff at the top. e.g.
private final Logger logger = Logger.getLogger(GroupingManagementActionController.class.getName());
Scan for the word log?
Next "contextual" stuff like:
@Inject
private Conversation conversation;
@PersistenceContext(type = PersistenceContextType.EXTENDED)
private EntityManager em;
Next "contextual" Event stuff like:
// Events
@Inject
@GroupingCreateEvent
private Event<Grouping> createEvent;
The other @injects...
@Inject
GroupingManagementActionController groupingManagementActionController;
Next "leading" (Cruffy) stuff like ID and Version for Entities
@XmlAttribute
@XmlID
@XmlJavaTypeAdapter(IdAdapter.class)
@Id
@GeneratedValue
private Long id;
@NotNull
@Version
@Column(name = "version4OptLock")
private long optlock;
Next the "simple" private members
@XmlElement(name = "nots")
@Column(name = "notes", length = 1000)
@Length(max = 1000)
private String notes;
Next the Lists/Sets ...
1..*
@XmlElement(name = "tasks")
@OneToMany(fetch = FetchType.LAZY, cascade = { CascadeType.PERSIST, CascadeType.MERGE, CascadeType.REFRESH }, mappedBy = "grouping")
private Set<GroupingTask> tasks;
@NotNull
@ManyToMany(fetch = FetchType.LAZY, cascade = { CascadeType.PERSIST, CascadeType.MERGE, CascadeType.REFRESH })
private Set<OrganisationRole> organisationRoles;
*..1 (generally backlinks)
@XmlElement(name = "parent_organisation")
@XmlIDREF
@NotNull
@ManyToOne(fetch = FetchType.EAGER)
// -> DO NOT ADD IN AS BREAKS CREATE!// , cascade = { CascadeType.MERGE, CascadeType.PERSIST, CascadeType.REFRESH }
private Organisation parentOrganisation;
Next Constructors
Next @Overridden methods from parent classes
Next methods with names like init, create etc. (that logically would come first)
Next the putters/getters that match the members by public/private
Next other putters/getter for non members by public/private
Next the public methods (followed by any truly private methods they (or their neighbours) completely "own")
Next the private methods (followed by any truly other private methods they (or their neighbours) completely "own")
Finally methods life @Destroy, cancel, done or similar.
I am sure you can think of more!
Cheers.
Re: Formatter - Feature Request [message #1069336 is a reply to message #1069193] Mon, 15 July 2013 17:32 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
Feature requests belong in Bugzilla with a Severity of Enhancement. This all reads like enhanced member sorting rather than formatting, though.
https://bugs.eclipse.org/bugs/enter_bug.cgi
_
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: Formatter - Feature Request [message #1069415 is a reply to message #1069336] Mon, 15 July 2013 21:01 Go to previous message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=413009
Previous Topic:Changing Access Modifier with shortcut?
Next Topic:EPIC Perl Debugging: An internal error occurred during: "child count update"
Current Time: Thu Apr 25 20:42:35 GMT 2024
Powered by FUDForum. Page generated in 0.08477 seconds
