Home » Language IDEs » C / C++ IDE (CDT) » Installing CDT on ubuntu(CDT )
Installing CDT on ubuntu [message #1068173] Fri, 12 July 2013 14:14 Go to next message
iliya tzukerman is currently offline iliya tzukermanFriend
Hello
I have just installed eclipse indigo from ubuntu software store but it seams it dose not have any option for c/c++.
So i downloaded from http://www.eclipse.org/downloads/download.php?file=/technology/epp/downloads/release/indigo/SR2/eclipse-cpp-indigo-SR2-incubation-linux-gtk-x86_64.tar.gz
CDT .MY quastions is how to install it now.
I amvery new to linux pls help!
Re: Installing CDT on ubuntu [message #1068197 is a reply to message #1068173] Fri, 12 July 2013 15:59 Go to previous message
David Wegener is currently offline David WegenerFriend
You untar it to a directory on your file system. There is no formal install procedure.
You need to have a Java JDK/JRE installed to run Eclipse. You specify the location of the JDK/JRE using the procedures documented here:
http://wiki.eclipse.org/Eclipse.ini
Previous Topic:Problems when programmatically adding macros
Next Topic:Eclipse SDK 3.72 with plugin C/C++ windows 7 32bit
Current Time: Sun Feb 18 07:28:07 GMT 2018
Powered by FUDForum. Page generated in 0.01922 seconds
