Cannot Install New Tomcat 7 Server After Removing It [message #1067761] |
Wed, 10 July 2013 13:23 |
Kevin Schulke Messages: 4 Registered: July 2013 |
Junior Member |
I am experiencing a problem with adding a New Tomcat 7 Server with Eclipse Kepler after removing a Tomcat 7 Server instance. I am using Kepler Build:20130614-0229 running on Fedora 18. I executed these steps to create new Server in Eclipse after removing a prior instance:
1. Click Server tab
2. Click link to create new server
3. Highlight Tomcat v7.0 Server
Server host name is set to localhost
Server name is blank
Next> button is not active. Only Cancel button is available.
If I selected Tomcat v6.0 Server, the server host name is localhost and server name is populated. Next> button is active.
I was able to add the Tomcat 6 instance successfully using these steps. However, I noticed that cannot add a second instance of Tomcat 6. I experience the same issue when trying to add a Tomcat 7 instance.
I attempted to correct this issue by applying a fix that worked in Juno:
1. Close Eclipse
2. In {workspace-directory}/.metadata/.plugins/org.eclipse.core.runtime/.settings delete the following two files:
org.eclipse.wst.server.core.prefs
org.eclipse.jst.server.tomcat.core.prefs
3. Restart Eclipse
But, this fix did not work.
Any suggestions on how to get this working again properly?
Kevin Schulke
Re: Cannot Install New Tomcat 7 Server After Removing It [message #1069311 is a reply to message #1068066] |
Mon, 15 July 2013 16:39 |
Junior Member |
Larry Isaacs wrote on Thu, 11 July 2013 17:45On 7/10/2013 9:23 AM, Kevin Schulke wrote:
> 1. Click Server tab
> 1. Close Eclipse
> 2. In
> 3. Restart Eclipse
Is the Tomcat 7 being used a Tomcat installed by Fedora or a binary
download from tomcat.apache.org? If installed by Fedora, do you
encounter this behavior with a binary download of Tomcat?
Also, is there anything related in the Error Log view?
Larry
I am using the binary downloaded from Apache. I installed both version 6 and 7 into the /opt directory.
Kevin
Kevin Schulke
FUDForum. Page generated in 0.02038 seconds
