Home » Eclipse Projects » BIRT » List of Jars needed for generating a PDF document using BIRT
List of Jars needed for generating a PDF document using BIRT [message #1067491] Tue, 09 July 2013 05:25 Go to next message
Vinoth Mahalakshmi is currently offline Vinoth MahalakshmiFriend
We are using BIRT for PDF generation.
Report is designed using BIRT perspective in eclipse and it is rendered as PDF insde java code using RE API.
As of now, we are adding all 80 jar files which are there inside BIRT-Runtime/ReportEngine/lib to build path.
In production, we would like to reduce the unused jar files. We are using XML as datasource and output option is PDF always.
it will be helpful if we get the list of jar files which are mandatory for this, so that we can discard remaining jar files.
Vinoth.
Re: List of Jars needed for generating a PDF document using BIRT [message #1067662 is a reply to message #1067491] Tue, 09 July 2013 20:42 Go to previous message
Kristopher Clark is currently offline Kristopher ClarkFriend
These are the import I've used to generate PDF's
import org.eclipse.birt.core.framework.Platform;
import org.eclipse.birt.report.engine.api.EngineConfig;
import org.eclipse.birt.report.engine.api.EngineException;
import org.eclipse.birt.report.engine.api.PDFRenderOption;
import org.eclipse.birt.report.engine.api.IReportEngine;
import org.eclipse.birt.report.engine.api.IReportEngineFactory;
import org.eclipse.birt.report.engine.api.IReportRunnable;
import org.eclipse.birt.report.engine.api.IRunAndRenderTask;
import org.eclipse.core.internal.registry.RegistryProviderFactory;
Previous Topic:Problem with the export of a report with the Birt RE API
Next Topic:BIRT as separate module
Current Time: Sat May 26 00:47:11 GMT 2018
Powered by FUDForum. Page generated in 0.02342 seconds
