Home » Modeling » ATL » No output file (or model) after execution
No output file (or model) after execution [message #1065710] Thu, 27 June 2013 08:41 Go to next message
Félix SILINOU KAMDEM is currently offline Félix SILINOU KAMDEMFriend
Member
I don't have any output file (or model) after running my module whose contains:
rule DocumentRoot {
	from
		m : UML!Model
	to
		dr : XsdEcore!DocumentRoot
rule Package {
	from
		c : UML!Package
	to
		ct : XsdEcore!PackageType
But when I used only one each rule in the code above, the output file is generate.
Does anyone why sometimes I generated output file and sometimes not?
[Updated on: Thu, 27 June 2013 08:42]
Report message to a moderator
Re: No output file (or model) after execution [message #1065718 is a reply to message #1065710] Thu, 27 June 2013 09:04 Go to previous messageGo to next message
Hugo Bruneliere is currently offline Hugo BruneliereFriend
There is no reason why such a transformation would not run correctly.
If your output model is not generated, this means that you have an error during the transformation execution: please, take a look to the ATL console to see what is actually happening.
Also, make sure that your ATL launch configuration is set properly.
Hugo Bruneliere - R&D Engineer
AtlanMod research team (Inria, EMN & LINA)
Ecole des Mines de Nantes
Nantes - France
Re: No output file (or model) after execution [message #1065726 is a reply to message #1065718] Thu, 27 June 2013 09:38 Go to previous messageGo to next message
Member
here is an error:
org.eclipse.m2m.atl.engine.emfvm.VMException: Trying to register several rules as default for element org.eclipse.uml2.uml.internal.impl.ModelImpl@3393fa (name: Rose model, visibility: <unset>) (URI: null) (viewpoint: <unset>) : DocumentRoot and Package
Re: No output file (or model) after execution [message #1065736 is a reply to message #1065726] Thu, 27 June 2013 10:14 Go to previous messageGo to next message
Sylvain EVEILLARD is currently offline Sylvain EVEILLARDFriend
Model inherits from Package thus a model is matched by two rules : DocumentRoot and Package which is not possible in ATL.
You have to add a filter on your Package rule in order to transform only Packages and not the Model here. oclIsTypeOf should do it.
Re: No output file (or model) after execution [message #1065896 is a reply to message #1065736] Fri, 28 June 2013 07:55 Go to previous messageGo to next message
Member
It works perfectly now.
Re: No output file (or model) after execution [message #1688980 is a reply to message #1065896] Sun, 22 March 2015 09:55 Go to previous message
FSM ISFSM is currently offline FSM ISFSMFriend
Hello everybody,
I have the same problem.
I'm working on some issues I'm meeting trying to make transformation rules from MetaSysml to MetaAcme.
Here are 3 very simple rules:
rule Bddiagram2Family {
	from s: MetaSysml!BDDiagram
	to
	     t : MetaAcme!Family (
		    name        <- s.name )
rule   Bddiagram2System {
      to
	     t : MetaAcme!System (
		  name     <- 'System' ,
		  family   <- s.extend
The problem is that I get this error when executed:
org.eclipse.m2m.atl.engine.emfvm.VMException: Trying to register several rules as default for element org.eclipse.emf.ecore.impl.DynamicEObjectImpl@25303 (eClass: org.eclipse.emf.ecore.impl.EClassImpl@1e0025d (name: BDDiagram) (instanceClassName: null) (abstract: false, interface: false)) : Bddiagram2Family and Bddiagram2System
Do I need to modify the metamodel? or maybe some other solutions exists...
Thank you very much.
Previous Topic:SWRL in model transformation
Next Topic:MetaSysml to MetaAcme simple rules transformation problem
Current Time: Fri Feb 23 09:00:55 GMT 2018
Powered by FUDForum. Page generated in 0.02161 seconds
