Home » Newcomers » Newcomers » File differences after importing?
File differences after importing? [message #1065455] Tue, 25 June 2013 18:40 Go to next message
karmen watson is currently offline karmen watsonFriend
I'm a relatively new coder, I started with a basic intro class at college. I created a final project in that class and had it working completely. I imported it to my personal laptop and for some reason the midi playback feature won't work. I have all the libraries that are needed. This is the error that it is giving me:
java.io.FileNotFoundException: src\calvin\edu\kaw37\FinalProject\yourSong (The system cannot find the path specified)
at java.io.FileInputStream.open(Native Method)
at java.io.FileInputStream.<init>(Unknown Source)
at java.util.Scanner.<init>(Unknown Source)
at edu.calvin.kaw37.FinalProject.ComposerPart.<init>(ComposerPart.java:39)
at edu.calvin.kaw37.FinalProject.PianoPanel.playYourSong(PianoPanel.java:609)
at edu.calvin.kaw37.FinalProject.ComposerController$PlayRecordingListener.actionPerformed(ComposerController.java:156)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$200(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$4.run(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
Will you help me out please?
Re: File differences after importing? [message #1065510 is a reply to message #1065455] Wed, 26 June 2013 08:50 Go to previous message
It's not clear how this question is Eclipse related. We can't know
what's at line
"edu.calvin.kaw37.FinalProject.ComposerPart.<init>(ComposerPart.java:39)".
On 25/06/2013 8:44 PM, karmen watson wrote:
> Hello,
> path specified)
> at
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> at
> at
> Source)
> Source)
Previous Topic:[Compare] Where did class MatchService go in EMF Compare 2.1?
Next Topic:USE ONE INSTANCE FOR MULTIPPEL MUSERS
Current Time: Tue Jan 23 12:20:47 GMT 2018
Powered by FUDForum. Page generated in 0.02540 seconds
