Home » Language IDEs » C / C++ IDE (CDT) » Periods in artifact name result in no binaries found(If periods are in the artifact name, or an artifact extension is used, why does nothign show up under the binaries virtual folder?)
icon5.gif  Periods in artifact name result in no binaries found [message #1065192] Mon, 24 June 2013 17:25 Go to next message
Stephen Closson is currently offline Stephen ClossonFriend
Hi Everyone,
After much testing, I have discovered for my project, if I set my executable name under Project Properties->Settings->Build Artifact (tab)->Artifact Name to anything with a '.' (period) in it, the resulting binary (which compiles successfully) will not show up under the binaries virtual folder.
I'm using Juno SR1
Is it just me, or is anyone else seeing this? Any ideas on how I can compile a binary that uses a period in it's artifact name again? It was working before (or so I thought... now I'm starting to wonder!)
Many thanks,
Stephen
Re: Periods in artifact name result in no binaries found [message #1065534 is a reply to message #1065192] Wed, 26 June 2013 11:46 Go to previous message
Axel Mueller is currently offline Axel MuellerFriend
That is a bug. See https://bugs.eclipse.org/bugs/show_bug.cgi?id=364027
Before you ask
- search this forum
- see the FAQ http://wiki.eclipse.org/CDT/User/FAQ
- google
Previous Topic:Compiler Complains About Errors
Next Topic:Warnings being treated as errors in Eclipse
Current Time: Mon Jan 22 02:51:43 GMT 2018
Powered by FUDForum. Page generated in 0.01832 seconds
