Home » Language IDEs » Java Development Tools (JDT) » Programmatically close a Java file?
Programmatically close a Java file? [message #1065168] Mon, 24 June 2013 14:55 Go to next message
Eclipse Explorer is currently offline Eclipse ExplorerFriend
When several java files are open in the Java editor and a user deletes one of these files in the Package Explorer, "Eclipse" removes the deleted java file from the java editor. How can I do this programmatically?
Thank you for your help.
(P.S. I posted a similar question the Newcomers forum. I hope that it is not too redundant to ask again here.)
Re: Programmatically close a Java file? [message #1065173 is a reply to message #1065168] Mon, 24 June 2013 15:12 Go to previous messageGo to next message
Do you want an editor you've implemented yourself to behave this way?
It's generally done by using a workspace listener in your editor:
ResourcesPlugin.getWorkspace().addResourceChangeListener(resourceChangeListener,
IResourceChangeEvent.POST_CHANGE);
> programmatically?
Re: Programmatically close a Java file? [message #1065177 is a reply to message #1065173] Mon, 24 June 2013 15:25 Go to previous messageGo to next message
Hi Ed,
Yes, I've extended org.eclipse.ui.editors.text.TextEditor.
Re: Programmatically close a Java file? [message #1065257 is a reply to message #1065177] Tue, 25 June 2013 06:46 Go to previous message
In EMF's generated editors we use a listener. You could look at the
source code:
http://git.eclipse.org/c/emf/org.eclipse.emf.git/tree/plugins/org.eclipse.emf.ecore.editor/src/org/eclipse/emf/ecore/presentation/EcoreEditor.java
On 24/06/2013 5:25 PM, Eclipse Explorer wrote:
> Hi Ed,
Previous Topic:Getting compilation errors for a project over JDT markers produces wrong result initially
Next Topic:Java Content Assist in a Wizard
Current Time: Sat Apr 21 10:12:48 GMT 2018
Powered by FUDForum. Page generated in 0.01889 seconds
