Home » Eclipse Projects » SWTBot » swtBot UI tests execution using maven tycho
swtBot UI tests execution using maven tycho [message #1064453] Wed, 19 June 2013 07:08 Go to next message
Deepak Malhotra is currently offline Deepak Malhotra
I have a swtBot test project which has automated tests for my custom eclipse plugin. I was looking for ways to run the tests headlessly and found it can be done with maven tycho.
I configured my swtBot test project with maven tycho to run the swtBot tests headlessly. Refer to the pom.xml which is attached. The maven tycho build was successful for the project but on running the tests I'm seeing the below exception.
Running com.ebay.soa.service.automation.firstTestCase Tests run: 2, Failures: 0, Errors: 2, Skipped: 0, Time elapsed: 0.141 sec <<< FA ILURE! com.ebay.soa.service.automation.firstTestCase Time elapsed: 0 sec <<< ERROR! java.lang.IllegalStateException: Could not find a display at org.eclipse.swtbot.swt.finder.utils.SWTUtils.display(SWTUtils.java:25 0) at org.eclipse.swtbot.swt.finder.finders.ControlFinder.(ControlFin der.java:82) at org.eclipse.swtbot.swt.finder.finders.ControlFinder.(ControlFin der.java:72) at org.eclipse.swtbot.swt.finder.SWTBot.(SWTBot.java:115) at org.eclipse.swtbot.eclipse.finder.SWTWorkbenchBot.(SWTWorkbench Bot.java:58) at com.ebay.soa.service.automation.firstTestCase.beforeClass(firstTestCa se.java:52) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl. java:60) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces sorImpl.java:37) at java.lang.reflect.Method.invoke(Method.java:611) at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(Framework Method.java:45) at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCal lable.java:15) at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMe thod.java:42) at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores. java:27) at org.junit.internal.runners.statements.RunAfters.evaluate(RunAfters.ja va:30) at org.junit.runners.ParentRunner.run(ParentRunner.java:300) at org.apache.maven.surefire.junit4.JUnit4TestSet.execute(JUnit4TestSet. java:62) at org.apache.maven.surefire.suite.AbstractDirectoryTestSuite.executeTes tSet(AbstractDirectoryTestSuite.java:140) at org.apache.maven.surefire.suite.AbstractDirectoryTestSuite.execute(Ab stractDirectoryTestSuite.java:127) at org.apache.maven.surefire.Surefire.run(Surefire.java:177) at org.eclipse.tycho.surefire.osgibooter.OsgiSurefireBooter.run(OsgiSure fireBooter.java:72) at org.eclipse.tycho.surefire.osgibooter.HeadlessTestApplication.run(Hea dlessTestApplication.java:21) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl. java:60) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces sorImpl.java:37) at java.lang.reflect.Method.invoke(Method.java:611) at org.eclipse.equinox.internal.app.EclipseAppContainer.callMethodWithEx ception(EclipseAppContainer.java:587) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandl e.java:198) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runAppli cation(EclipseAppLauncher.java:110) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(Ec lipseAppLauncher.java:79) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.ja va:353) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.ja va:180) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl. java:60) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces sorImpl.java:37) at java.lang.reflect.Method.invoke(Method.java:611) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584) at org.eclipse.equinox.launcher.Main.run(Main.java:1438) at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
I'm encountering : java.lang.IllegalStateException: Could not find a display exception while test execution. Anybody who encountered this or knows a workaround for the same?
Please let me know if u need more information on tycho configuration or project structure.
  • Attachment: pom.xml.txt
    (Size: 1.27KB, Downloaded 16 times)
[Updated on: Wed, 19 June 2013 07:09]
Report message to a moderator
Re: swtBot UI tests execution using maven tycho [message #1064465 is a reply to message #1064453] Wed, 19 June 2013 08:11 Go to previous message
Mickael Istria is currently offline Mickael Istria
Did you have a look at
http://wiki.eclipse.org/SWTBot/Automate_test_execution#With_Maven_and_Tycho
The value of the useUIHarness and useUIThread parameters are critical
for SWTBot usage.
HTH
Mickael Istria
JBoss, by Red Hat
My blog: http://mickaelistria.wordpress.com
My Tweets: http://twitter.com/mickaelistria
Previous Topic:Running SWTbot test heedlessly
Next Topic:How to click a button under a CTabFolder?
Current Time: Tue Oct 08 07:47:46 EDT 2013
Powered by FUDForum. Page generated in 0.07946 seconds
