Home » Eclipse Projects » Equinox » BundleException: Activator for bundle is invalid, but everything appears to be in place.(org.osgi.framework.BundleException due to ClassNotFoundException)
BundleException: Activator for bundle is invalid, but everything appears to be in place. [message #1061569] |
Mon, 03 June 2013 02:45 |
Erwin Hogeweg Messages: 37 Registered: July 2009 |
Member |
I am not sure if this should be in the OSGi mailing list or in this forum so I post it in both locations. Please ignore if you feel this is the wrong location.
In an OSGi Framework application, that has been working for months, I, all of a sudden, get the BundleExceptions below. I have cleaned projects, cleared the configuration area, restarted the machine, reverted back all changes to a known working revision, created a completely new Activator from scratch. All to no avail.
If I inspect the bundle jar (after exporting as pluging) everything appears to be there, and in the right location.
It appears to me that either Eclipse (4.2) is truly confused, or something is seriously broken. I have no idea how to fix it though. I mucked around with Bundle-Classpath in the manifest, but that didn't seem to have an effect either. Again, this project used to work just fine.
Does anyone have an idea what is going on here, and how to fix this?
I have included the relevant parts of the project below.
Your help is greatly appreciated.
Kind Regards,
Erwin
----- The Exception -----
!ENTRY com.acme.north.web 4 0 2013-06-02 21:29:18.791
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: The activator com.acme.north.web.internal.NewActivator for bundle com.acme.north.web is invalid
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadBundleActivator(AbstractBundle.java:172)
Caused by: java.lang.ClassNotFoundException: com.acme.north.web.internal.NewActivator
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:501)
... 12 more
Root exception:
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
------- build.properties -------
source.. = src/main/java/,\
src/main/resources
bin.includes = META-INF/,\
src/main/resources/,\
src/main/java/,\
OSGI-INF/
src.excludes = src/test/java/
bin.excludes = target/classes/.svn/
----- MANIFEST.MF -----
Manifest-Version: 1.0
Bundle-Version: 1.0.1.qualifier
Bundle-Name: Acme Web
Bundle-ManifestVersion: 2
Bundle-SymbolicName: com.acme.north.web;singleton:=true
Bundle-Classpath: .
Bundle-Activator: com.acme.north.web.internal.NewActivator
Import-Package: com.acme.north.model.entities,
com.acme.north.model.entities.auth,
com.acme.north.model.entities.common,
com.acme.north.model.entities.community,
com.acme.north.model.entities.profile,
com.acme.north.model.exceptions,
com.acme.north.service.interfaces,
javax.persistence,
org.apache.commons.logging,
org.eclipse.jface.dialogs,
org.osgi.framework;version="[1.5,2)",
org.osgi.service.component;version="1.1.0",
org.osgi.service.http;version="[1.2,2)",
org.osgi.util.tracker;version="[1.4,2)"
Bundle-RequiredExecutionEnvironment: JavaSE-1.6
Export-Package: com.acme.north.web
Require-Bundle: org.eclipse.rap.rwt;bundle-version="2.0.0",
org.eclipse.rap.jface;bundle-version="2.0.0",
javax.servlet;bundle-version="2.5.0",
----- NewActivator -----
package com.acme.north.web.internal;
import org.osgi.framework.BundleActivator;
import org.osgi.framework.BundleContext;
public class NewActivator implements BundleActivator {
public void start(BundleContext bundleContext) throws Exception {
System.out.println("Starting the bundle...");
public void stop(BundleContext bundleContext) throws Exception {
System.out.println("Stopping now...");
Current Time: Thu Apr 18 05:58:43 GMT 2024
Powered by FUDForum. Page generated in 0.01831 seconds
