Home » Modeling » OCL » [OCLinEcore] Load complete OCL resource not always working as expected
[OCLinEcore] Load complete OCL resource not always working as expected [message #1060328] Fri, 24 May 2013 07:36 Go to next message
Cedric Moonen is currently offline Cedric MoonenFriend
I have an EMF domain model (written with the OCLinEcore editor) and a OCL file containing additional validation rules for the model.
In my runtime Eclipse, I create an instance of my domain model (via a GMF based editor) and wants to validate it using the external OCL file. When I right-click on the diagram, the "Load Complete OCL Resource" action appears correctly but it doesn't seem to do anything (my validation rules are not invoked, since I added a rule that always fails but no error shows up).
I installed version 4.1.0.RC1.
This seems to fail on Kepler but I've been able to have it working on Juno. However, I tried now again with a fresh install of Juno and I have the same problem. I can't say what exactly triggers the problem unfortunately...
Did you experience something similar or have any idea what might be the problem ?
Thanks for the help,
Cédric
Re: [OCLinEcore] Load complete OCL resource not always working as expected [message #1060341 is a reply to message #1060328] Fri, 24 May 2013 08:26 Go to previous messageGo to next message
Ed Willink is currently offline Ed WillinkFriend
Does the error log show anything.
RC1 has an improved PopUP diagnostic if Load fails, buit othewuse little
change.
Can you provide a Zipped project that fails?
Ed Willink
On 24/05/2013 08:36, Cedric Moonen wrote:
> Hello,
> OCL file containing additional validation rules for the model. In my
> unfortunately...
> the problem ?
> Cédric
Re: [OCLinEcore] Load complete OCL resource not always working as expected [message #1060345 is a reply to message #1060341] Fri, 24 May 2013 08:44 Go to previous messageGo to next message
Hi Ed,
No, the error log doesn't show anything.
I don't think that sending you the project will solve anything, since it was working properly for me with another eclipse installation (I had to reinstall Eclipse and since then I experienced the problem). So, I guess this is a tooling issue (some plug-ins that are not installed and that should be installed maybe).
Anyway, I'll send you the files via mail (for confidentiality reasons).
Cédric
Re: [OCLinEcore] Load complete OCL resource not always working as expected [message #1060475 is a reply to message #1060345] Sat, 25 May 2013 06:20 Go to previous messageGo to next message
Thanks. I see the problem. It looks as if the Complete OCL tutorial
should fail too, which begs the question as to why no JUnit test fails....
Ed Willink
Re: [OCLinEcore] Load complete OCL resource not always working as expected [message #1060678 is a reply to message #1060475] Mon, 27 May 2013 16:53 Go to previous message
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=409169 for details.
Hopefully it's fixed now (in Kepler RC2).
Ed Willink
On 25/05/2013 07:20, Ed Willink wrote:
> Hi
> fails....
> Regards
> Ed Willink
Previous Topic:Load Complete OCL Resource Automatically
Next Topic:[Announce] Eclipse OCL 4.1.0 (Kepler) RC2 is available.
Current Time: Sun Apr 22 03:15:35 GMT 2018
Powered by FUDForum. Page generated in 0.01672 seconds
