Home » Eclipse Projects » Jubula » Variable change in event handler has no effect on variable value in parent test case
Variable change in event handler has no effect on variable value in parent test case [message #1060003] Wed, 22 May 2013 13:56 Go to next message
Alexander Kolesov is currently offline Alexander KolesovFriend
Member
Hello Jubula team,
Could you please evaluate the following problem with Jubula 2.0 x64
Have test case T1:
- assign variable Var value 'false'
- check $Var to be equal 'true'
Test case T1 has event handler EH1 with retry attempt on Check Failed
EH1:
- assign variable Var value 'true'
Step by step testcase T1 execution:
1. Var is assigned value 'false'
2. Compare $Var and 'true'. Var != true. Call event handler EH1.
3. EH1 assigns Var value 'true'
4. Retry comparison of $Var and 'true'
Expected: Retry passed
Problem: retry failed since variable $Var is still equal 'false'
This problem is not reproduced in Jubula 1.3 and has a great impact (actually stops from migration to Jubula 2.0) since the most of existing testcases and framework use such logic
Thanks, Alex.
Re: Variable change in event handler has no effect on variable value in parent test case [message #1060097 is a reply to message #1060003] Thu, 23 May 2013 06:34 Go to previous messageGo to next message
Alexandra Schladebeck is currently offline Alexandra SchladebeckFriend
The situation you are describing is a planned change. It was documented in the release notes on page 8. The old way of resolving parameters was wrong (see this bug) and the behaviour has been noted and explained on this ticket. There is also an example project attached with a workaround for any projects that were using this way of working.
HTH,
Alex
Re: Variable change in event handler has no effect on variable value in parent test case [message #1060352 is a reply to message #1060097] Fri, 24 May 2013 08:56 Go to previous messageGo to next message
Member
Thank you for response.
Tricky thing ... Smile
Thanks, Alex.
Re: Variable change in event handler has no effect on variable value in parent test case [message #1060361 is a reply to message #1060352] Fri, 24 May 2013 09:55 Go to previous message
Definitely tricky! It seems to be one of those bugs that got used as a feature Wink
Previous Topic:How to use the System Enviorment Variables of AUT configuration?
Next Topic:How to handle popup in jubula?
Current Time: Wed May 23 17:06:35 GMT 2018
Powered by FUDForum. Page generated in 0.02147 seconds
