Home » Eclipse Projects » Jubula » Problem with executing external command on remote machine with 'Local' parameter set on false
Problem with executing external command on remote machine with 'Local' parameter set on false [message #1058838] Wed, 15 May 2013 11:26
Miroslav Jankovic is currently offline Miroslav JankovicFriend
I'm trying to execute script on remote machine with external command. It is about powershell script which write to excel file.
In case when is 'Local' parameter set to false (script and file are on remote machine where is agent to), error occurred: "Timeout received before confirming the posted event".
It is important to mention, that the job will be well done, script would write desirable result in file, but test step will be failed (and test to)!
In case that parameter is set to 'true', everything work fine, test step pass.
Previous Topic:Left shortcuts after uninstalling the plugin
Next Topic:aut hungs when start it
Current Time: Sat Apr 21 00:30:04 GMT 2018
Powered by FUDForum. Page generated in 0.01578 seconds
