Home » Language IDEs » C / C++ IDE (CDT) » Eclipse sees source code error
Eclipse sees source code error [message #1058069] Fri, 10 May 2013 18:59 Go to next message
Jim Bentley is currently offline Jim BentleyFriend
I recently started on a project with a huge amount of existing code. They use #defines to flag whether certain areas are to be put into SRAM or DRAM.
ex:
#define SECTION_SRAM
void MyFunction(int x) SECTION_SRAM;
Eclipse flags this as a syntax error, saying that I'm missing a ; after the function declaration - it doesn't recognize that SECTION_SRAM is defined as nothing, and so shouldn't affect the line.
The ARM compiler does recognize this and knows how to handle it. I can't change this method - is there a way to get Eclipse to work with this?
Re: Eclipse sees source code error [message #1058099 is a reply to message #1058069] Sat, 11 May 2013 07:57 Go to previous message
Nobody Mising name is currently offline Nobody Mising nameFriend
Member
Jim Bentley wrote on Fri, 10 May 2013 14:59
Works for me:
http://i42.tinypic.com/ab6kif.png
Previous Topic:Retrieving Problem Messages from C Compiler
Next Topic:newcomer problems in getting started
Current Time: Mon May 21 17:15:32 GMT 2018
Powered by FUDForum. Page generated in 0.01534 seconds
