Home » Eclipse Projects » P2 » Update error
Update error [message #1057955] Fri, 10 May 2013 01:32 Go to next message
Enrico R. is currently offline Enrico R.
Member
trying to update Kepler (4.3.0 I20130314-1330) to M7 but i always get an error dialog saying:
An error occurred while uninstalling
session context was:(profile=SDKProfile, phase=org.eclipse.equinox.internal.p2.engine.phases.Uninstall, operand=[R]org.eclipse.sdk.ide.executable.win32.win32.x86_64 4.3.0.I20130314-1330 --> null, action=org.eclipse.equinox.internal.p2.touchpoint.natives.actions.CleanupzipAction).
Backup of file D:\installed\Eclipse\E_4.3_x64\eclipse.exe failed.
Can not remove : D:\installed\Eclipse\E_4.3_x64\eclipse.exe
My eclipse.ini:
-startup
plugins/org.eclipse.equinox.launcher_1.3.0.v20130225-1645.jar
-vm
D:/installed/Java/JDK_1.7_64bit/bin/javaw.exe
--launcher.library
plugins/org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.200.v20130228-0336
-showsplash
org.eclipse.platform
--launcher.XXMaxPermSize
256m
--launcher.defaultAction
openFile
-vmargs
-XX:+UnlockExperimentalVMOptions
-Xms128m
-Xmx1024m
Running Win7 64Bit with 64Bit JDK7u21 as administrator and i'm using updatesite "http://download.eclipse.org/eclipse/updates/4.3milestones".
My anti-virus has an exception for my hole eclipse folder.
I checked all handles (processes) using 'eclipse.exe' and there 'eclipse.exe' itself, 'java.exe' and 'csrss.exe' (Client/Server Runtime Subsystem from Windows, its used for the console and threading under Windows).
I found a bugreport https://bugs.eclipse.org/bugs/show_bug.cgi?id=333355 with the same issue but no solution for my case.
Has anybody an idea ho to solve this except of make a clean eclipse installation?
Thanks!
Re: Update error [message #1058194 is a reply to message #1057955] Mon, 13 May 2013 03:49 Go to previous messageGo to next message
Sopot Cela is currently offline Sopot Cela
You may have more luck asking in the P2 forums because you can see P2 complaining it can not remove a file. Initially looks like a permission issue but as you state it is not the case.
Re: Update error [message #1127916 is a reply to message #1057955] Mon, 07 October 2013 02:23 Go to previous message
Premysl Fiala is currently offline Premysl Fiala
I had same issue with updating Kepler. W7 with admin.
How to solve:
  1. Run eclipse
  2. Rename eclipse exe to eclipse.exe.back
  3. Run updates
  4. Updates executed successfully
Previous Topic:Hide features on update-site from showing up in a older version of Eclipse
Current Time: Tue Oct 08 07:48:52 EDT 2013
Powered by FUDForum. Page generated in 0.02829 seconds
