Home » Modeling » TMF (Xtext) » UI model validation
UI model validation [message #1052937] Wed, 01 May 2013 13:32 Go to next message
David Apltauer is currently offline David ApltauerFriend
Currently I have some validation in the main project which the UI project interprets as markers. I would like move that validation from the main project to the UI project, so that the parser is not concerned about it. Also I would like to add validations which need some data from preferences, so these have to be in the UI project as well, aimed to enrich the UI experience. What is the best way to plug in several model validations (preferably separate) which would get the marker-displaying support of Xtext?
David
Re: UI model validation [message #1052939 is a reply to message #1052937] Wed, 01 May 2013 13:40 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
simply adding a binding similar to the one in the runtimemodule to the ui module doesnt work?
Need professional support for Xtext, Xpand, EMF?
Go to: https://xtext.itemis.com
Twitter : @chrdietrich
Blog : https://www.dietrich-it.de
Re: UI model validation [message #1052957 is a reply to message #1052939] Wed, 01 May 2013 14:49 Go to previous messageGo to next message
Thank you, it does! I didn't hope for it to ba that easy. It is not possible to bind multiple validators though. Also is there way to set when or how often the validation should be performed?
Re: UI model validation [message #1052971 is a reply to message #1052957] Wed, 01 May 2013 16:11 Go to previous messageGo to next message
@Check(CheckType)
Re: UI model validation [message #1053027 is a reply to message #1052957] Thu, 02 May 2013 06:15 Go to previous message
Alexander Nittka is currently offline Alexander NittkaFriend
as to multiple validators. You can let your UI-Validator extend the regular one and you can use the ComposedCheck annotation for "registering" further validator classes.
Alex
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext@itemis.de
Previous Topic:data binding beteen xtext and swt
Next Topic:How to limit content assist according to scoping
Current Time: Fri Jun 22 21:22:17 GMT 2018
Powered by FUDForum. Page generated in 0.02003 seconds
