Home » Modeling » GMF (Graphical Modeling Framework) » User operation is waiting for background work to complete
User operation is waiting for background work to complete [message #155617] Tue, 16 October 2007 07:12 Go to next message
Eclipse User
Originally posted by: awm_abu.yahoo.com
We are currently putting read access to our shared models into runExclusives
which run on our EditingDomain.
This is to prevent lazy initialisation exceptions whereby someone starts to
load a model and someone else
tries to read it before it is fully loaded.
The problem is that now a dialog pops up entitled "User operation is
waiting"
The text on it is what you see in the title of this message.
What I am wondering is where it is coming from ?
More specifically can I stop it appearing when using runExclusive or at the
very least
how do I go about internationalising it ?
Thanks in advance.
Re: User operation is waiting for background work to complete [message #155993 is a reply to message #155617] Wed, 17 October 2007 07:09 Go to previous messageGo to next message
Nicolai Kamenzky is currently offline Nicolai Kamenzky
Member
Hi Alan,
I stumbled across this problem as well and luckily it got
already fixed but the bugfix might not yet be integrated.
So for now you have to manually apply a patch to the EMF
Transaction runtime.
I am sure you have the same problem as I had but If you want
to check if this is actually the case read here:
< http://dev.eclipse.org/newslists/news.eclipse.tools.emf/msg2 7062.htm
l>
To get to know how to fix your problem read this bugreport:
<https://bugs.eclipse.org/bugs/show_bug.cgi?id=205857>
I think the EMF team will appreciate if you report them if
your problem got solved as well as mine.
Nicolai
I'm using an evaluation license of nemo since 44 days.
You should really try it!
http://www.malcom-mac.com/nemo
Re: User operation is waiting for background work to complete [message #156349 is a reply to message #155993] Thu, 18 October 2007 13:11 Go to previous message
Member
Christian W. Damus just announced on the EMF newsgroup the
new release of the EMF Transaction runtime entitled:
[Announce] EMF TRANSACTION 1.2.0 I200710171604 is available
Install this and run your code again. Your problem may be
gone with the new version.
Nicolai
I'm using an evaluation license of nemo since 45 days.
Previous Topic:Write Transaction Error
Next Topic:get ResourceSet
Current Time: Thu May 23 19:53:54 EDT 2013
Powered by FUDForum. Page generated in 0.01487 seconds
