Home » Eclipse Projects » Eclipse 4 » Hints on using JFace Wizard with Dependency Injection?
Hints on using JFace Wizard with Dependency Injection? [message #1050147] Fri, 26 April 2013 19:34 Go to next message
Marina Knieling is currently offline Marina KnielingFriend
Member
Hi Community,
I'm trying to inject an OSGi-Service into a JFace Wizard (and WizardPage). My service is started and active and working fine. I know that the JFace Wizards don't get created by the Application model, so I already figured out that I need to use the ContextInjectionFactory.
What I've done so far:
One wizard class that needs OSGi-Services in the performFinish method AND in one of the pages (see constructor).
public class GiveFeedbackWizard extends Wizard implements MyWizard{
	private Feedback feedback;
	@Inject
	DatabaseAccessService dbservice;
	@Inject
	CustomerService custService;
	@Inject
	@Named(IServiceConstants.ACTIVE_SHELL) Shell shell;
	public GiveFeedbackWizard(){
		feedback = TICDModelFactory.eINSTANCE.createFeedback();
		setWindowTitle("Customer Feedback");
// I know the following doesn't work as the fields haven't been injected yet
		addPage(new FeedbackFirstWizardPage(feedback, dbservice));
		addPage(new FeedbackRatingWizardPage(feedback));
		addPage(new FeedbackTextWizardPage(feedback));
	public boolean performFinish() {
		System.out.println(feedback);
		Customer activeCustomer = custService.getActiveCustomer();
		activeCustomer.getFeedbacks().add(feedback);
		dbservice.saveCustomer(activeCustomer);
		return true;
Can I use the CIF to create the WizardPage as well?
The OSGi-Service that creates my Wizards:
public void createWizard(WizardTypes type) {
		IEclipseContext ctx = EclipseContextFactory.getServiceContext(Activator.getContext());
		switch(type){
		case CUSTOMER:
			wizard = ContextInjectionFactory.make(CreateCustomerWizard.class, ctx);
//			wizard.setDBAccessService(dbservice);
//			wizard.setCustomerService(custService);
			break;
		case BOOKING:
			// TODO create and return BookingWizard
			wizard = null;
			break;
		case FEEDBACK:
			// TODO create and return FeedbackWizard
			wizard = ContextInjectionFactory.make(GiveFeedbackWizard.class, ctx);
			break;
		default:
			wizard = null;
			break;
The setter methods show the way I did it before, but I had NullPointerExceptions.
Is my approach in general correct?
I ended up with a
org.eclipse.e4.core.di.InjectionException: Unable to process "GiveFeedbackWizard.shell": no actual value was found for the argument "Shell[@javax.inject.Named(value=activeShell)]". in my last try although the Injection of the Shell worked before (when I still used the setter methods). Any hints on that?
Thanks in advance.
Marina
Re: Hints on using JFace Wizard with Dependency Injection? [message #1050212 is a reply to message #1050147] Fri, 26 April 2013 21:53 Go to previous messageGo to next message
Christoph Keimel is currently offline Christoph KeimelFriend
Hi Marina
There is no Shell in the context on the OSGi layer, only OSGi services. Does your wizard get opened by a handler? If yes, then you should use the IEclipseContext that gets injected into your @Execute method.
You can create instances of any class with CIF. That includes wizard pages.
Hope that helps!
Greetings
Christoph
Re: Hints on using JFace Wizard with Dependency Injection? [message #1050627 is a reply to message #1050212] Sat, 27 April 2013 13:37 Go to previous message
Member
Hi Christoph,
yes my wizard gets opened by a handler. Changes my code and works fine. I even managed to inject my Feedback object by inserting it into a child context before. Thanks for your help.
[Updated on: Sat, 27 April 2013 13:38]
Report message to a moderator
Previous Topic:Weird behaviour with Deletey Key
Next Topic:Remote UI
Current Time: Wed May 23 03:47:58 GMT 2018
Powered by FUDForum. Page generated in 0.02125 seconds
