Home » Eclipse Projects » Hudson » Launch Sonar plugin before Checkstyle plugin
Launch Sonar plugin before Checkstyle plugin [message #1049803] Fri, 26 April 2013 09:41 Go to next message
Jonathan Dumont is currently offline Jonathan DumontFriend
Member
I want to launch the sonar analysis before Hudson collect the checkstyle results. Like this, the results displayed in Hudson are based on the same files than Sonar.
I've found this issue which seems to be closed :
http://issues.hudson-ci.org/browse/HUDSON-7202
But I don't manage to understand how I can do to launch the Sonar plugin before the Checksyle plugin.
Any idea ?
Re: Launch Sonar plugin before Checkstyle plugin [message #1053149 is a reply to message #1049803] Thu, 02 May 2013 17:16 Go to previous messageGo to next message
Winston Prakash is currently offline Winston PrakashFriend
As per the bug, version 1.6 onwards should have @Extension(ordinal = 1000). Hudson 3 Plugin Central has version 2.0.1 so it should have the right one. What version of Sonar and checkstyle plugins you have installed?
Winston Prakash
Eclipse Hudson team
Re: Launch Sonar plugin before Checkstyle plugin [message #1059088 is a reply to message #1053149] Thu, 16 May 2013 15:21 Go to previous message
Member
Sorry for the delay ...
In fact we have installed and use :
- Maven : v3.0.5
- Hudson : v3.0.1-b2
- Checkstyle (hudson plugin) : v3.35-h-1
- Sonar : v.3.5.1
- Checkstyle (sonar plugin) : v1.2
Thanks in advance for your help.
Previous Topic:Upgrade Hudson 1.386 to latest hudson 3.0
Next Topic:v2.2.1 - FATAL ERROR : Unrecognized constructor parameter: interface com.thoughtworks.xstream.conver
Current Time: Thu Feb 22 23:01:17 GMT 2018
Powered by FUDForum. Page generated in 0.02006 seconds
