Home » Newcomers » Newcomers » UML2.0 Plug-in (Can not use the Assembly Connector)
UML2.0 Plug-in [message #1048340] Wed, 24 April 2013 10:24 Go to next message
Yousr CHELLY is currently offline Yousr CHELLYFriend
Hello everyone,
I am using eclipse galileo and i have a problem with the UML2 Tool plugin.
I Have a very simple component diagram:
- 2 components called "Component1" and "Component2"
- "Component1" contains a port called "Port1"
- "Component2" contains a port called "Port2"
I want to make an "Assembly Connector" between "Port1" and "Port2", but I can't drag and drop it from the palette.
Any suggestions to help me doing this??
Thanks in advance Smile
Re: UML2.0 Plug-in [message #1048354 is a reply to message #1048340] Wed, 24 April 2013 10:47 Go to previous messageGo to next message
Sorry, but that's a very old version and the folks that developed it
generally aren't supporting it anymore. It's better to use Papyrus and
ask questions about it on their specific forum.
On 24/04/2013 12:24 PM, Yousr CHELLY wrote:
> Hello everyone,
> plugin.
> Thanks in advance :)
Re: UML2.0 Plug-in [message #1048432 is a reply to message #1048354] Wed, 24 April 2013 13:06 Go to previous message
Well I was working with Papyrus as a plug-in within eclipse juno but in the component diagram's palette there was no "Assembly Connector" available Sad that's why i moved to UML2 Tool plug-in.
Previous Topic:Help with Eclipse/Juno on Ubuntu
Next Topic:jar manifest and classpath
Current Time: Sat Apr 21 02:26:14 GMT 2018
Powered by FUDForum. Page generated in 0.05947 seconds
