Home » Modeling » BPEL Designer » Complex type in BPEL Designer
Complex type in BPEL Designer [message #1048251] Wed, 24 April 2013 08:15
sams good is currently offline sams goodFriend
hello
I'm trying to invoke an external web service providing a java database search method find(). The find(id) parameter id is an object which represents a composed primary key.
you can see below the find() request
index.php/fa/14493/0/
and the response variable
index.php/fa/14494/0/
the request in an object, composed by two string which represent the primary key PK
the response is an object which represent the composed primary key, and a string value.
I've tried definig a new complex type composed by two strings and assign it to the request xs:anyType but it did not work.
any suggestions ?
thank you
  • Attachment: input.JPG
    (Size: 89.80KB, Downloaded 642 times)
  • Attachment: output.JPG
    (Size: 41.11KB, Downloaded 610 times)
Previous Topic:Web Service Orchestration
Next Topic:Create BPEL Process from java program
Current Time: Sun Feb 25 13:57:40 GMT 2018
Powered by FUDForum. Page generated in 0.02152 seconds
