Home » Language IDEs » Java Development Tools (JDT) » Does the Eclipse debugger have a way to display a method's return value?
Does the Eclipse debugger have a way to display a method's return value? [message #154435] Thu, 15 April 2004 16:19 Go to next message
Russell Gonsalves is currently offline Russell GonsalvesFriend
In a previous life I used a windowing debugger which also accepted commands,
the output of which was shown in a "log" window. As one stepped out of a
method the debugger would stop at the "epliog hook" and issuing a print
command (typically used with arguments to print (display) the value of a
variable) without arguments would print out the return value (if the method
returned a value as opposed to a "void" method). Does the Eclipse debugger
let one inspect return values? There are times when the value of an
expression involving method calls is returned, and that return value used in
another expression in the calling context so there's no variable to
inspect - at such times how would I display the return value? Often the
code is not mine, so modifying it is not an option.
Russell
Re: Does the Eclipse debugger have a way to display a method's return value? [message #154501 is a reply to message #154435] Thu, 15 April 2004 19:17 Go to previous messageGo to next message
I believe there is a feature request or this in Bugzilla - try searching
for it or creating a new one if you can't find it.
HTH,
Eric
The wages of sin are death; but after taxes are taken out, it's just a
tired feeling.
Re: Does the Eclipse debugger have a way to display a method's return value? [message #154568 is a reply to message #154501] Fri, 16 April 2004 02:04 Go to previous messageGo to next message
>> commands,
>> method
>> debugger
>> in another expression in the calling context so there's no variable to
I've been told (might have been in a bug report) that the JVM debugger
"framework" doesn't support this. :(
David
Re: Does the Eclipse debugger have a way to display a method's return value? [message #156394 is a reply to message #154568] Wed, 28 April 2004 22:10 Go to previous message
Originally posted by: neil.neil.swingler.name
"David Corbin" <dcorbin@machturtle.com> wrote in message
news:c5nenu$lv0$1@eclipse.org...
> >> commands,
a
a
> >> method
> >> debugger
used
the
Which is a shame for anybody who follows Martin Fowler's recomendations to
replace temporary variables with query methods. Although if the method has
no side effects, you can just evaluate it in the debugger and examine the
result that way.
Neil Swingler
Previous Topic:Getting IResource from DebugPlugin
Next Topic:Launch configurations should be stored in projects
Current Time: Sun May 27 14:10:03 GMT 2018
Powered by FUDForum. Page generated in 0.03014 seconds
