Home » Modeling » EMF » Missing XML namespace declaration(Missing XML namespace declaration when XMLResource is serialized)
Missing XML namespace declaration [message #1044931] Fri, 19 April 2013 14:21 Go to next message
Charles Bonneau is currently offline Charles BonneauFriend
Member
Here is my set-up:
I have two Ecore models, one that references the other: B->A
I uses XML serialization of models (instances of Ecores).
I've generated the XSDs for the two Ecore models.
As expected the schema of the Ecore model B imports the schema A:
<xsd:schema xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
	xmlns:A_prefix="http://A.nsURI"
	xmlns:B_prefix="http://B.nsURI"
	xmlns:xsd="http://www.w3.org/2001/XMLSchema"
        ecore:nsPrefix="B_prefix"
	ecore:package="BPackage"
	targetNamespace="http://B.nsURI">
 <xsd:import namespace = "http://A.nsURI" schemaLocation="platform:/plugin/where/the/schema/A/is"/>
</xsd:schema>
The problem is that when I try to create an instance of my model B and serialize it using XMLResource, the namespace of the referenced ecore(schema) is missing :
I only get the xmlns of the Ecore model B and its schemaLocation value.
<B_prefix:rootNode
	xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:B_prefix="http://B.nsURI"
	xsi:schemaLocation="http://B.nsURI java://BPackage"
	id="test.component12" version="1.0.0" />
I fear that is because no instance of Ecore model A has been created yet.
How can I force the XML resource to add all the needed namespace declaration even on an empty instance ?
While debugging I found that the XMLHelper of the XMLSave has a package list, I though may be I should try to add the missing package here. But I haven't find a way to do it.
One other thing, I would like to avoid touching the generated code i.e. BResource.java
Any idea ?
I hope it clear enough.
Charles
[Updated on: Fri, 19 April 2013 14:35]
Report message to a moderator
Re: Missing XML namespace declaration [message #1045349 is a reply to message #1044931] Sat, 20 April 2013 05:16 Go to previous messageGo to next message
Charles,
Comments below.
On 19/04/2013 4:21 PM, Charles Bonneau wrote:
> Hello,
> Here is my set-up:
> As expected the schema of the Ecore model (B) that references the
> other one contains imports of the schema of the other one (A):
> <xsd:schema [...]
> xmlns:A_prefix="http://A.nsURI">
> </xsd:schema>
It seems to me this comment is self contradictory. Why would an empty
instance need anything other than the namespace of the root element?
> i.e. BResource.java
> Any idea ?
If there is a DocumentRoot involved, (if this is a schema-derived model,
but it doesn't sound like that) you can populate namespaces via that.
No really. What makes you think you need a namespace? Serialization
generally produces the namespace you actually need and not any you don't
need, so the fact there's something missing implies to me it's not needed...
> Best regards,
> Charles
Re: Missing XML namespace declaration [message #1046661 is a reply to message #1045349] Mon, 22 April 2013 07:46 Go to previous messageGo to next message
Member
Thank you for your answer, I'll try to declare the namespaces via the DocumentRoot.
Let me explain a bit more my situation :
The problem is that some of our users prefer to use the default XML editor to edit models Confused .
To do so, they were using the default "New XML File" wizard which creates a XML file with all the needed XML Namespace declaration and schema locations, which provides a content assistant based on XML Schemas.
We are providing a wizard to create models. This wizard creates a empty model using Java and serialize it in XML, but our users (the ones whose prefer XML) complain that some XML Namespace declaration and schema locations are missing and that the content assistant isn't providing the result they were expecting.
If I understand correctly, the problem is that for the XMLResource, the XML Schema namespace and location of the imported schema are not needed at serialization time, because there isn't any instance of that schema yet.
That why I wanted to compute and declare all the XML schema before the serialization of the model.
Charles
Re: Missing XML namespace declaration [message #1046677 is a reply to message #1046661] Mon, 22 April 2013 08:12 Go to previous messageGo to next message
Charles,
What's the relation between the schemas? I.e., does the schema of the
root element import the schema of the "missing" namespaces? If so, I'd
expect content assist to know about both schemas. Also, I'd imagine
that most XML editors don't require explicit schema locations but allow
configuration so that one can specify the location associated with a
namespace so that documents with only namespaces can be nicely edited;
certainly WTP's editor supports that.
On 22/04/2013 9:46 AM, Charles Bonneau wrote:
> Hello,
> DocumentRoot.
> editor to edit models :? .
> Schemas.
> schema yet.
> Best regards,
> Charles
Re: Missing XML namespace declaration [message #1046692 is a reply to message #1046677] Mon, 22 April 2013 08:39 Go to previous messageGo to next message
Member
Ed,
Indeed schema of the root element import the schema of the "missing" namespaces :
</xsd:schema>
And the content assistant provides results, but without the namespace declaration, the results are wrong :
<B_prefix:rootNode
	id="test.component12" version="1.0.0" >
        <node xsi:type="<!-- when calling content assist here, the result is : "ANode", instead of "A_prefix:ANode" and the editor marks it as an error:
        "Cannot resolve 'ANode' to a type definition for element 'node'."-->
<!-- it is because the namespace declaration is missing :  xmlns:A_prefix="http://A.nsURI"-->
</B_prefix:rootNode>
My bad, only the xml namespace declaration is needed, not the schema location.
I tried to add the missing declaration manually and everything worked as expected.
BR,
Charles
Re: Missing XML namespace declaration [message #1046697 is a reply to message #1046692] Mon, 22 April 2013 08:43 Go to previous messageGo to next message
Charles,
But even that sounds like a bug (shortcoming) in the XML editor. Content
assist should be able to know all the schemas imported by any schema
whose namespace appears in the document. It should be able to suggest
things from namespaces not already in the document and should be able to
add the namespace as needed. I.e., it should be able to do as good a
job as the EMF editor itself does...
On 22/04/2013 10:39 AM, Charles Bonneau wrote:
> Ed,
> namespaces :
> </xsd:schema>
> <B_prefix:rootNode
> it as an error:
> 'node'."-->
> xmlns:A_prefix="http://A.nsURI"--> </B_prefix:rootNode>
> location.
> as expected.
> BR,
> Charles
Re: Missing XML namespace declaration [message #1046701 is a reply to message #1046697] Mon, 22 April 2013 08:49 Go to previous messageGo to next message
Member
OK, so I guess I'll have to check WTP's forum.
Thanks a lot for your time.
BR,
Charles
Re: Missing XML namespace declaration [message #1046848 is a reply to message #1046701] Mon, 22 April 2013 13:07 Go to previous messageGo to next message
Member
I looked at WTP's forum and it seems that there is a bug related to the content assistant.
On the EMF side is there some kind of Flag to set to the XMLSave, to say "declare all the namespace of the package that might be used even though they aren't used yet" ?
The goal would be to have an empty model serialized this way :
<B_prefix:rootNode
Charles
Re: Missing XML namespace declaration [message #1046965 is a reply to message #1046848] Mon, 22 April 2013 15:57 Go to previous message
Charles,
Comments below.
On 22/04/2013 3:07 PM, Charles Bonneau wrote:
> Hello,
No. That's generally even unbounded if you consider that any other
schema can extend the complex types or contribute to substitution groups
heads, i.e., elements.
> <B_prefix:rootNode
If there is a document root (if it's an XML Schema-based model) you can
control all such things explicitly.
> Best regards,
> Charles
Previous Topic:[CDO] Migrate Repository when Ecore changes
Next Topic:Eclipse e4 not running directly from product configuration file
Current Time: Sun Jun 24 00:06:54 GMT 2018
Powered by FUDForum. Page generated in 0.01985 seconds
