Home » Modeling » TMF (Xtext) » ENUM DATA TYPE
ENUM DATA TYPE [message #1043230] Wed, 17 April 2013 12:53 Go to next message
junior developer is currently offline junior developerFriend
Hi All,
I define A enum rule in my grammar this rule is below , EXT is optional but PNG is shows in the ecore by default.I want to dont show PNG(First index).How can I provide shows empty value for EXT.(EXT dont receive First value ) I load Screenshot about ecore property
File returns File:
'File' name=ID (
('location' '=' location=STRING )?
&('date' '=' date=STRING )?
&('ext' '=' ext = EXT )?
enum EXT :
PNG|TXT |JPG |JAVA | C | BAT |BMP |EXE |COM |DOC |PDF|DOCX|XLS|XLSX
Best Regards
Re: ENUM DATA TYPE [message #1043241 is a reply to message #1043230] Wed, 17 April 2013 13:09 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
http://www.eclipse.org/forums/index.php/t/263086/
Need professional support for Xtext, Xpand, EMF?
Go to: http://xtext.itemis.com
Twitter : @chrdietrich
Blog : christiandietrich.wordpress.com
Re: ENUM DATA TYPE [message #1043276 is a reply to message #1043241] Wed, 17 April 2013 13:53 Go to previous messageGo to next message
Hi Christian,
Thank you for shared.
Best Regards
Re: ENUM DATA TYPE [message #1043846 is a reply to message #1043241] Thu, 18 April 2013 07:27 Go to previous messageGo to next message
Claudio Heeg is currently offline Claudio HeegFriend
Member
Christian Dietrich wrote on Wed, 17 April 2013 15:09
Regarding this, I was wondering whether this is a specific design choice (for default values, specifically, but lacking documentation) or is just like this because the workaround is that easy?
Maybe someone with deeper insight could enlighten me.
[Updated on: Thu, 18 April 2013 07:28]
Report message to a moderator
Re: ENUM DATA TYPE [message #1043976 is a reply to message #1043846] Thu, 18 April 2013 10:38 Go to previous message
From the docs
When generating the EPackage (src) from your grammar this will be the first literal you define. As a workaround you could introduce a dedicated none-value or order the enums accordingly.
Previous Topic:JDT dependencies in Xtext 2.4?
Next Topic:Runtime exceptions thrown from the model inferrer
Current Time: Tue Feb 20 04:24:57 GMT 2018
Powered by FUDForum. Page generated in 0.02194 seconds
