Home » Eclipse Projects » Eclipse Platform » Alternating colors of a single console stream.
Alternating colors of a single console stream. [message #1042578] Tue, 16 April 2013 15:53 Go to next message
Camilo Bernal is currently offline Camilo BernalFriend
Hi all,
I've created a console view which displays profiling information; each printed line containing detailed metrics. What I'm attempting to do is set the color of each line printed in the console based on the metrics (e.g. set the color of a particular line to green to show performance gain). I started with a MessageConsole, but using setColor on the MessageConsoleStream updates the whole stream, as it should.
At the moment I'm looking at consoleColorProviders extension point, but first want to make sure that this is the right approach or whether there is a better way to achieve what I described above.
Re: Alternating colors of a single console stream. [message #1043283 is a reply to message #1042578] Wed, 17 April 2013 14:04 Go to previous messageGo to next message
A more concise way to put it is: Am I going in the wrong path by attempting to set multiple colors to a single console output stream?
Re: Alternating colors of a single console stream. [message #1092263 is a reply to message #1043283] Thu, 22 August 2013 14:33 Go to previous message
Bernard Sarter is currently offline Bernard SarterFriend
Member
I faced some problems when trying to alternate the colours of a single MessageConsoleStream, so what I did to fix that was to create one MessageConsoleStream per colour:
MessageConsole msgConsole = new MessageConsole("foo", null);
MessageConsoleStream  consoleStreamDefault = msgConsole.newMessageStream();
consoleStreamDefault.setColor(null);
MessageConsoleStream  consoleStreamRed = msgConsole.newMessageStream();
consoleStreamRed.setColor(new Color(null, new RGB(255, 0, 0)));
a switch allows then to select the appropriate MessageConsoleStream for each single message to write.
Hope that helps,
Bernard.
Previous Topic:StatusManager.getManager().handle() does not show dialog
Next Topic:Unable to read workbench state
Current Time: Mon Jan 22 08:35:03 GMT 2018
Powered by FUDForum. Page generated in 0.01565 seconds
