Home » Eclipse Projects » Lua Development Tools » LDT with luabind
LDT with luabind [message #1042413] Tue, 16 April 2013 11:56 Go to next message
Graham Westlake is currently offline Graham WestlakeFriend
I'm building a scriptable application and trying to use LDT as an IDE for script development. My application exposes its C++ object model to Lua using luabind.
When stepping through scripts in Eclipse and trying to view the variables I see an error in the debugger console - "Command context_get caused: (998) No such operator defined" and get no variable display.
This doesn't seem to be an inherent problem with C++ bindings. I can build a simple app that binds a class using luaL_newmetatable, luaL_register etc. and everything works - the object is shown as a table.
But binding with luabind obviously requires something extra. It's not the tostring method.
Has anyone come across this before?
Thanks.
Re: LDT with luabind [message #1049189 is a reply to message #1042413] Thu, 25 April 2013 13:42 Go to previous message
Simon Bernard is currently offline Simon BernardFriend
I never test LDT with luabind, I don't know if it works.
Perhaps, Julien Desgats could have an idea.
If you think LDT should support Lua binding you could open a enhancement.
[Updated on: Thu, 25 April 2013 13:42]
Report message to a moderator
Previous Topic:Documenting a Function That Returns an Array
Next Topic:Can LDT debug Lua in a C app?
Current Time: Wed Feb 21 11:53:04 GMT 2018
Powered by FUDForum. Page generated in 0.01671 seconds
