Missing templates in exported Eclipse [message #1041541] |
Mon, 15 April 2013 08:22 |
Carlo Gimondi Messages: 1 Registered: April 2013 |
Junior Member |
Hi All,
I'm creating my Eclipse product from an Eclipse 4.2.2. When i try to export it everything is fine and my custom plugins work as expected.
Only one issue: when i click on "Preference -> General -> Appearance" i get this error:
"The currently displayed page contains invalid value" and in the log i have this:
!ENTRY org.eclipse.jface 4 2 2013-04-15 09:31:08.619
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.jface".
!STACK 0
at org.eclipse.ui.internal.dialogs.ViewsPreferencePage.createContents(ViewsPreferencePage.java:74)
at org.eclipse.jface.preference.PreferencePage.createControl(PreferencePage.java:232)
at org.eclipse.jface.preference.PreferenceDialog.createPageControl(PreferenceDialog.java:1502)
at org.eclipse.jface.preference.PreferenceDialog$14.run(PreferenceDialog.java:1259)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
at org.eclipse.jface.preference.PreferenceDialog.showPage(PreferenceDialog.java:1253)
at org.eclipse.ui.internal.dialogs.FilteredPreferenceDialog.showPage(FilteredPreferenceDialog.java:675)
at org.eclipse.jface.preference.PreferenceDialog$10.run(PreferenceDialog.java:709)
at org.eclipse.jface.preference.PreferenceDialog$9.selectionChanged(PreferenceDialog.java:705)
at org.eclipse.jface.viewers.StructuredViewer$3.run(StructuredViewer.java:888)
at org.eclipse.jface.viewers.StructuredViewer.firePostSelectionChanged(StructuredViewer.java:886)
at org.eclipse.jface.viewers.StructuredViewer.handlePostSelect(StructuredViewer.java:1226)
at org.eclipse.jface.viewers.StructuredViewer$5.widgetSelected(StructuredViewer.java:1251)
at org.eclipse.jface.util.OpenStrategy.firePostSelectionEvent(OpenStrategy.java:262)
at org.eclipse.jface.util.OpenStrategy.access$5(OpenStrategy.java:256)
at org.eclipse.jface.util.OpenStrategy$3.run(OpenStrategy.java:433)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4144)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3761)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
I insert in the product configuration all the org.eclipse.e4.ui.css.* plugins and also i try to insert "org.eclipse.e4.ui.css.swt.theme/themeid=org.eclipse.e4.ui.css.theme.e4_default6.1" in plugin.configuration.in but it doesn't work
Any idea?
FUDForum. Page generated in 0.02021 seconds
