Home » Newcomers » Newcomers » getting "BUILD FAILED: java.lang.NoClassDefFoundError:org/apache/commons/net/ftp
getting "BUILD FAILED: java.lang.NoClassDefFoundError:org/apache/commons/net/ftp [message #152706] Tue, 16 May 2006 03:22 Go to next message
Originally posted by: prakash.sada.gmail.com
When I am running the build file (build.ant) from eclipse I got the
following error.
org/apache/commons/net/ftp/FTPClient"
The following is the xml descroptor.
<target name="ftp-del">
<ftp server="${ftp.server}"
remotedir="${ftp.remotedir}"
userid="${ftp.userid}" action="delete"
password="${ftp.password}"
verbose="yes">
<fileset>
<include name="filename.jar"/>
</fileset>
</ftp>
</target>
Pls provide me some help.
Thanks in advanse,
Prakash
Re: getting "BUILD FAILED: java.lang.NoClassDefFoundError:org/apache/commons/net/ftp [message #152712 is a reply to message #152706] Tue, 16 May 2006 04:04 Go to previous message
Darin Swanson is currently offline Darin SwansonFriend
As with any Ant buildfile that uses ftp, you need the commons-net.jar on
your Ant runtime classpath.
See http://ant.apache.org/manual/install.html#librarydependencie s
In Eclipse you can easily add to the Ant runtime classpath via:
Window>Preferences>Ant>Runtime>Classpath>Global Entries>Add External JARs
HTH
Darins
"Prakash rao .Sadha" <prakash.sada@gmail.com> wrote in message
news:872324ca9223599a1b8c09496a7cae79$1@www.eclipse.org...
> following error.
> verbose="yes">
> <fileset>
> </fileset> </ftp>
> </target>
> Thanks in advanse,
> Prakash
Previous Topic:(CGI-Target)Could not connect to CGI-Proxy
Next Topic:Update - different in 3.01 than in 3.1.2?
Current Time: Sun Jun 24 17:14:03 GMT 2018
Powered by FUDForum. Page generated in 0.02652 seconds
