Home » Eclipse Projects » GEF » Sharing zoom action between different editors
Sharing zoom action between different editors [message #151907] Fri, 24 September 2004 09:28 Go to next message
kiril mitov is currently offline kiril mitovFriend
I have made a MultiPageEditor and one of it`s page is a GEF editor. This
page supports the zoomIn and zoomOut actions. When I open the editor this
actions are added to the toolBar of the workbench, and there isn`t any
problem to use them.
The problem is that when I open a second file with the same editor (the
two files are now opened) the second editor adds another zoomIn and
zoomOut aciton to the toolBar. And now I have two zoomIn actions and two
zoomOut actions. The first ones are working with the first opened file and
the second ones are working with the second file.
I want to have only one zoomIn action and one zoomOut action and to share
them acrossed the opened files. I now that maybe I can put them az
globalActions, but zoom actions are constructed az follows
IAction zoomIn = new ZoomInAction(root.getZoomManager());
and here root is the rootEditPart. So if they are globalActions I must
somehow get them from the toolBar and change their zoomManagers. But I
can`t see a way to set the zoomManager of an zoomAction. The only way to
do this is to construct a new instance of the zoomAction, to remove the
old action and to put the new one. But this operations must be done not
only when I open a new file with my editor but even more - when I switch
between the open files.
The problem gets bigger becouse my editor isn`t a GraphicalEditor and
there isn`t such a thing like ActionRegistry. My editor is a MultiPage
Editor and only one of its pages is a GEF page.
I don`t know whether this is a good solution but I thought that I could
"add" the ActionRegistry to the MultiPageEditor myself but it seems to be
not so simple, and I am not sure if this will work.
Could somebody help me find a way to solve my problem, and to share the
actions between opend files.
Thank you.
Kiril Mitov
Re: Sharing zoom action between different editors [message #151988 is a reply to message #151907] Fri, 24 September 2004 22:40 Go to previous messageGo to next message
Pratik Shah is currently offline Pratik ShahFriend
You need to use retarget actions (ZoomInRetargetAction and
ZoomOutRetargetAction in this case).
"kiril mitov" <kiril_mitov@abv.bg> wrote in message
news:cj0pc9$q1r$1@eclipse.org...
> Thank you.
> Kiril Mitov
Re: Sharing zoom action between different editors [message #152228 is a reply to message #151988] Mon, 27 September 2004 21:38 Go to previous message
Thanks for the hint Pratik.
I will try it.
kiril
> > Hi,
> > Thank you.
> > Kiril Mitov
Previous Topic:Text filing
Next Topic:Dificulties using scroll bar
Current Time: Thu Apr 26 02:23:53 GMT 2018
Powered by FUDForum. Page generated in 0.01873 seconds
