Home » Eclipse Projects » GEF » Up to date eclipse 3.0 GEF/EMF Example?
Up to date eclipse 3.0 GEF/EMF Example? [message #151610] Tue, 21 September 2004 17:28 Go to next message
Steve Jones is currently offline Steve JonesFriend
Member
The Redbook examples will not build with eclipse-3.0.0, GEF-3.0.0 and
EMF-2.0.0.
Anyone know of any recent/updated GEF/EMF examples that drop straight in?
Cheers, Steve.
Re: Up to date eclipse 3.0 GEF/EMF Example? [message #151662 is a reply to message #151610] Wed, 22 September 2004 02:18 Go to previous messageGo to next message
Pratik Shah is currently offline Pratik ShahFriend
We're working on an EMF example, but it's far from done. There are no other
EMF examples that I know of. However, having an EMF model does not really
affect how you utilize GEF. GEF/EMF integration should not be a problem if
you're roughly familiar with GEF and EMF. Keep in mind that I am talking
about EMF and not EMF.Edit.
Pratik Shah
"Steve Jones" <steve@istech.demon.co.uk> wrote in message
news:cipnvc$dm1$1@eclipse.org...
> EMF-2.0.0.
> Cheers, Steve.
Re: Up to date eclipse 3.0 GEF/EMF Example? [message #151676 is a reply to message #151610] Wed, 22 September 2004 14:12 Go to previous messageGo to next message
Can you post the compile errors? They should be really simple to fix, there
have not been any major changes in GEF 3.0.0, and there is a workbench
migration guide for going from 2.1 to 3.0
> EMF-2.0.0.
> Cheers, Steve.
Re: Up to date eclipse 3.0 GEF/EMF Example? [message #151833 is a reply to message #151676] Thu, 23 September 2004 14:18 Go to previous messageGo to next message
Member
Hi Randy,
I've not investigated any of these errors in any depth. I'm still getting up
to speed with GEF & EMF as individual frameworks.
My worry was/is that since the Redbook is now a year old and both GEF/EMF
and Eclipse have moved on that these examples may be "old stock" and
consiquently not a true reflection of current GEF/EMF thinking.
If your saying that the examples are current then I'll put some effort into
resolving the build problems.
How about putting the redbook examples in the eclipse://home/tools CVS
repository?
Cheers Steve.
ERRORS/WARNINGS for SAL330RWorkflowModel
Severity Description Resource In Folder Location Creation Time
2 The method openEditor(IEditorInput, String) in the type IWorkbenchPage is
not applicable for the arguments (IFile) WorkflowModelWizard.java
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow line 174 20
September 2004 13:47:45
1 The method FBESpec.newMethod() does not override the inherited method from
FBElementImpl since it is private to a different package. FBESpec.java
fbdk/src/fb/model line 145 10 August 2004 16:22:16
1 The static field FBEditPanel.XML should be accessed in a static way
FBEditor.java fbdk/src/fb/tools/awt/editor line 446 21 September 2004
11:16:36
1 The static field FBEditPanel.Source should be accessed in a static way
FBEditor.java fbdk/src/fb/tools/awt/editor line 448 21 September 2004
11:16:36
1 The constructor StringBufferInputStream(String) is deprecated
Sax2LibrarySource.java fbdk/src/fb/xml line 72 10 August 2004 16:22:12
1 The type StringBufferInputStream is deprecated Sax2LibrarySource.java
XMLReaderTest01.java fbdk/src/fb/xml line 137 10 August 2004 16:22:12
1 The type StringBufferInputStream is deprecated XMLReaderTest01.java
1 The type StringBufferInputStream is deprecated XMLReaderTest02.java
fbdk/src/fb/xml line 62 10 August 2004 16:22:12
1 The method reset() from the type StringBufferInputStream is deprecated
XMLReaderTest02.java fbdk/src/fb/xml line 74 10 August 2004 16:22:12
XMLReaderTest02.java fbdk/src/fb/xml line 77 10 August 2004 16:22:12
fbdk/src/fb/xml line 133 10 August 2004 16:22:12
XMLReaderTest02.java fbdk/src/fb/xml line 191 10 August 2004 16:22:12
1 The type IPluginDescriptor is deprecated NetworkEditorPlugin.java
NetworkEditor/src/com/ibm/itso/sal330r/network line 101 23 September 2004
14:41:08
1 The constructor AbstractUIPlugin(IPluginDescriptor) is deprecated
NetworkEditorPlugin.java NetworkEditor/src/com/ibm/itso/sal330r/network
line 103 23 September 2004 14:41:08
1 The method shutdown() from the type AbstractUIPlugin is deprecated
line 112 23 September 2004 14:41:08
1 The field IWorkbenchActionConstants.PRINT is deprecated
NetworkEditorActionBarContributor.java
NetworkEditor/src/com/ibm/itso/sal330r/network/actions line 58 23 September
2004 14:41:08
1 The field IWorkbenchActionConstants.UNDO is deprecated
NetworkEditor/src/com/ibm/itso/sal330r/network/actions line 83 23 September
2004 14:41:08
1 The field IWorkbenchActionConstants.REDO is deprecated
NetworkEditor/src/com/ibm/itso/sal330r/network/actions line 84 23 September
2004 14:41:08
1 The method setTitle(String) from the type WorkbenchPart is deprecated
AbstractEditorPage.java
NetworkEditor/src/com/ibm/itso/sal330r/network/editor line 101 23 September
2004 14:41:08
1 The field IWorkbenchActionConstants.DELETE is deprecated
NetworkEditor.java NetworkEditor/src/com/ibm/itso/sal330r/network/editor
line 723 23 September 2004 14:41:08
line 916 23 September 2004 14:41:08
1 The method initEReference(EReference, EClassifier, EReference, String,
String, int, int, boolean, boolean, boolean, boolean, boolean, boolean,
boolean) from the type EPackageImpl is deprecated WorkflowPackageImpl.java
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 728 20
September 2004 13:37:07
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 729 20
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 730 20
1 The method initEAttribute(EAttribute, EClassifier, String, String, int,
int, boolean, boolean, boolean, boolean, boolean, boolean) from the type
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 733 20
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 734 20
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 735 20
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 736 20
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 737 20
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 740 20
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 741 20
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 742 20
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 745 20
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 746 20
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 749 20
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 750 20
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 755 20
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 760 20
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 765 20
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 768 20
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 769 20
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 770 20
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 771 20
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 772 20
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 773 20
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 774 20
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 777 20
SAL330RWorkflowModel/src/com/ibm/itso/sal330r/workflow/impl line 780 20
ERRORS/WARNINGS for SAL330RGEFDemoApplication
2 The method getWorkflow() is undefined for the type WorkflowEditor
SAL330RGEFDemoApplication/src/com/ibm/itso/sal330r/gefdemo/e ditor line 282
23 September 2004 14:49:18
2 IFileEditorInput cannot be resolved or is not a type WorkflowEditor.java
SAL330RGEFDemoApplication/src/com/ibm/itso/sal330r/gefdemo/e ditor line 165
2 FileEditorInput cannot be resolved or is not a type WorkflowEditor.java
SAL330RGEFDemoApplication/src/com/ibm/itso/sal330r/gefdemo/e ditor line 189
2 Workflow cannot be resolved (or is not a valid type) for the field
WorkflowEditor.workflow WorkflowEditor.java
SAL330RGEFDemoApplication/src/com/ibm/itso/sal330r/gefdemo/e ditor line 263
2 The method addEditorAction(EditorPartAction) in the type WorkflowEditor is
not applicable for the arguments (PrintAction) WorkflowEditor.java
SAL330RGEFDemoApplication/src/com/ibm/itso/sal330r/gefdemo/e ditor line 356
SAL330RGEFDemoApplication/src/com/ibm/itso/sal330r/gefdemo/e ditor line 441
2 SaveAsDialog cannot be resolved or is not a type WorkflowEditor.java
SAL330RGEFDemoApplication/src/com/ibm/itso/sal330r/gefdemo/e ditor line 469
SAL330RGEFDemoApplication/src/com/ibm/itso/sal330r/gefdemo/e ditor line 470
2 Workflow cannot be resolved (or is not a valid return type) for the method
getWorkflow WorkflowEditor.java
SAL330RGEFDemoApplication/src/com/ibm/itso/sal330r/gefdemo/e ditor line 734
2 workflow cannot be resolved WorkflowEditor.java
SAL330RGEFDemoApplication/src/com/ibm/itso/sal330r/gefdemo/e ditor line 736
2 The method gotoMarker(IMarker) is undefined for the type IEditorPart
WorkflowEditor.java
SAL330RGEFDemoApplication/src/com/ibm/itso/sal330r/gefdemo/e ditor line 777
SAL330RGEFDemoApplication/src/com/ibm/itso/sal330r/gefdemo/e ditor line 791
2 The method create(IFile) is undefined for the type WorkflowEditor
WorkflowEditor.java
SAL330RGEFDemoApplication/src/com/ibm/itso/sal330r/gefdemo/e ditor line 792
WorkflowEditor.java
SAL330RGEFDemoApplication/src/com/ibm/itso/sal330r/gefdemo/e ditor line 795
SAL330RGEFDemoApplication/src/com/ibm/itso/sal330r/gefdemo/e ditor line 905
SAL330RGEFDemoApplication/src/com/ibm/itso/sal330r/gefdemo/e ditor line 914
2 WorkflowModelManager cannot be resolved (or is not a valid type) for the
field WorkflowEditor.modelManager WorkflowEditor.java
SAL330RGEFDemoApplication/src/com/ibm/itso/sal330r/gefdemo/e ditor line 937
create WorkflowEditor.java
SAL330RGEFDemoApplication/src/com/ibm/itso/sal330r/gefdemo/e ditor line 945
2 Workflow cannot be resolved or is not a type WorkflowEditor.java
SAL330RGEFDemoApplication/src/com/ibm/itso/sal330r/gefdemo/e ditor line 947
2 modelManager cannot be resolved WorkflowEditor.java
SAL330RGEFDemoApplication/src/com/ibm/itso/sal330r/gefdemo/e ditor line 948
2 WorkflowModelManager cannot be resolved or is not a type
WorkflowEditor.java
SAL330RGEFDemoApplication/src/com/ibm/itso/sal330r/gefdemo/e ditor line 954
SAL330RGEFDemoApplication/src/com/ibm/itso/sal330r/gefdemo/e ditor line 958
SAL330RGEFDemoApplication/src/com/ibm/itso/sal330r/gefdemo/e ditor line 961
SAL330RGEFDemoApplication/src/com/ibm/itso/sal330r/gefdemo/e ditor line 992
SAL330RGEFDemoApplication/src/com/ibm/itso/sal330r/gefdemo/e ditor line 1007
Re: Up to date eclipse 3.0 GEF/EMF Example? [message #151974 is a reply to message #151833] Fri, 24 September 2004 18:09 Go to previous messageGo to next message
The authors of the example would have to do that, but we don't have
resources to maintain so many examples.
For GEF 3.1, we already have 5 different examples planned.
news:ciulif$862$1@eclipse.org...
> Hi Randy,
up
into
> repository?
> Cheers Steve.
Re: Up to date eclipse 3.0 GEF/EMF Example? [message #152582 is a reply to message #151610] Sat, 02 October 2004 10:53 Go to previous messageGo to next message
Andreas Voss is currently offline Andreas VossFriend
Member
--------------070308020904050704040104
Content-Type: text/plain; charset=us-ascii; format=flowed
Attached a working version of the Workflow example. It still uses a lot
of deprecated functions ...
Steve Jones wrote:
> EMF-2.0.0.
> Cheers, Steve.
Content-Type: application/x-gunzip;
name="SAL330R.tar.gz"
Content-Disposition: inline;
filename="SAL330R.tar.gz"
H4sIADOIXkEAA+xde2xcVXof23HwODGBQHgGcjJ57Dg4dx6eGQebZOP4ERz8 Ih4CFGi4nrm2
L7lz7+TeO3ZcZBqQoEDRVqvdagUtfcBWYlXUBboV6v7RXQGqgNKCoPsPFSBR URBqJVpUEAJK
v3POfT9m7njGk7id84ftmXvOued8j9/5vu9853hmcLy3N3786MjoMFeQBotF gc+xKi+JsVDd
Sjyeivel0/A7Hu/LpMjvRIr+1kooEY+nk32ZeCYO9RKpvmQ6hNL1G4J/KSkq KyMUYsW8zLFK
mXqc7P903ZYZX/7P8vWSgWD8TyT70vHeTDoJ/E+n+pr8b0jx578i5xrKf13/ Cf/TiUST/40o
5fmfkwp1kIHq+Z9JZvqa/G9Eqcx/frZWGaie/32wEDT534gSjP+8qkirF4Kq +Z/Ez5v8b0Sp
gv8KK0BVuXo5qJ7/iWS8t8n/RpRV8H+em8tD3eByUBX/wfCLJ5OZpv3XmFID //NiPpgMVMd/
rP+9vemm/deQwsSY2OFxSZwf58VTa/QOncc+v8Hd67PJQjwB38RDaHyNxmMr Ov9lSVLL1av0
fJ2WGvX/Vkk+NSdIS1muUBRYlcvKrKjMcfKwLBWzrDzPqeO8onIiJzP3sIvs uZ5tszhLA/gP
+hyPZzS898D/3iTW/76+RCbTl0qlMiH4JtML+h9vBAH+n+N/bN++rk60D43k BL6ocAgEAclc
flaSTiGFBaZyiDWFglTdPSOV5BzXj2IlRY4JUo4VYrlFBQNkrLFw0rOIdtMh HecWeQVe048S
TEL7kvyI5rrRkFRclvn5BRWNHZmAT3KRwc/I80FBQOSZAtMGFi9yeQZlF3gF FWVpXmYLCAQD
qQtAhhwMv8iKy7w4jwowOJlnBYW+hZU5+CoPlRZZXmBngWolMc/JpCHULChI miMfhqRCQRLR
dGkWKIPG+RwnAtUXE0yc9rS0wOcWjHfxnAKtYDB5mLbMz5YwKXvIkOBL82Ws ShovqGqxPxZb
WlpiOMpPRpLnYwI3j1lUFPYvJuLMgloQTPoMSSLtWJKVfvINLkdLoghacSs7 z4mnRC4HpNuP
eJFXYcoopzfRBQL/iHV1FtncKWgAzwsMcJnBXGY0LjMalxng8kBXZ1cnXyhK sopgeMZQoQoz
kufVaVZWT/DcEicP+NaDbpjKQuLfXuZOlzhFVZghUHo8kVE2ByRYto6t7DwK Up4TmAn806sL
Xa2IJPEKYX0exocEbWhoTgLp0GaAVG0KCpqTpQKpXWQFTlU5IqnoVg5JorCM RI4DYZQQjxWz
wIkqqXpDDoZxCOatjeCGGPkCFTh1QcozJrMPsyX4RvZgr85CKpY5gVUUFFwZ oTUU7gx8yCso
SP17aRNKJlxAEjEZQd5ZmOVSFS8HuQQIF3OEVLSrw0UWa+4iESL92xj9Q5ti 8P6jdpnUeu2m
vWnzwEUpFaGy9nSAfr+CZYFOFEVFSdx/DHQ2L+W6zaEqHLdK6d5lcjyK0ZAR WHGemZq9h8up
3c5Zy5IKX4P0OKQVWTqhTQ2pdE+Rn0NRQ2Z1sgOwDWF56Tbr4SJzakkWCS+9 tCQapY3Mtw2Y
7fW2JUGwEhJ+nOvl8v9cqWHB5kAvAgUAVuH/p3ub/n9DSq38V2WOqyQE1fM/ lepr7v80pNSF
/zyYhIq/FFTP/3Qz/tugUkf+Y5dFAreHmefnbO+o4P8D45Om/5+Og/8PjxNN /78R5ejY6IHr
2YtCF4V+Ewt99dVX11577TfffDMzM7Nnz57XXnvtqaee+vzzz994440HH3zw 008/fe655665
5prPPvvszTffPHDgwOWXX87z/Ouvvz4xMXH69OkzZ8688sorkUjkhRde2Lhx 4969e19++eVw
ONzR0XHxxRf39/e/+OKLb7311s6dO9vb29va2jo7Oz/55JNcLnf27NkPPvjg ww8/fPTRR1ta
WlpbW2Fk3333XbWT2fnVhpZQKBbqwR/wnEIbpV//pHhjz1V/8Gr+5rMHuiI/ fnTwdPbgncxl
f/mbse2Poanf/+SBZ58ZHnrk85d+2fvbf37111c9fed//O3/pLe+8F/ikY4N Pbft3/+7+1va
h0Obrnp4uGfDhSOhKzbfsX/3w21doz/YEWlpufySna1HQ91bL7u6fe/Pjv31 L2KDoYG6s2hN
Sz31f0HiwQtzan8A/U/02fU/CatFb1P/G1Es+p8Kge699957gAKgnAAEoPyg lqDngAiABQ88
8AAAAWgsoAMoMwDEq6++Cpp/9913P/PMM6D5O3bsADgAFABtBz3/4osvHnro IdB2UGxw4UDb
AQ6otgMQbNu2bXh4WJKk7du3A6ysrKyk02nAjk2bNgF2dHV1AaAAskxPTweH A6r/Kav+C4ef
IPr/0pVvHzjF/N7ERxc935Hu+flNO/ftXLxwInT4sv/e8PCuxx77af8fP9E9 kez/Wmjd+KNn
W+9/+/b2I5F8ePQSZn+is3PPzaObtuTa2pKhHwy3Ri/cvmHDdRdf+ZOh1o3x S1F4c0fqqaln
j//V80fXnfKH6qr/NIglyQXS3oIDFfW/N+1Y/xO9OP+vqf9rXyz6fygEmgZK DtoOugq6B/oP
+vz1118/+eSToPOg+YAFgAugk4ALgBEACt9++y3YAqC0H3300YkTJwAOQLFB 5w8dOgTL/jvv
vANoAoYDqPT7778Pmg/sBhQAXABQAG0HJQfL4uOPP77vvvvArHj33XcBEQAX AEQymQxgCqAM
QAlAAwDTl19+ybIsgA5ABlglxWIxlUoBZoV0dKD6f8iq/79z+E+J/r/y/sTO w3vv3XjkH7v/
/fbejjteulve1j/843869m//GXpiRjzzZxc9e/YfhPv/9cETf//S3fGnrr8t nx/qaLuk/Qi6
/8QFV7d0Hby2q6Vl/w2JrUMXxm44Mb9lS+iG8L6h+7dtumLz5j2XJSduOTjQ vXvHhnjkovGx
i7dn/+5Xv1ofaFBP/WeVUx6rfwD9j7vW/2Qm2dT/RhSL/mdCoPl0zQcUAMUD VQeFBz0HHQb9
h8UfVBc0GdABFBJQABZzUFSwBQACAB3oeg4QAOYAKDPoLcAHrOQAE7DgU1sA 2A24AEAAaz4g
BWg4aDJgAWg+wAQYDgAlFBQAgAAgQNVB8wM6BVT/M1b9zx/+I2r//1Tm26Lo kYnrtk5fc/ND
v1XIPP3Ind97en7kuus3P397NP3Pv7x6x+O/PqL8y3vPni1mX9yS2L55S1vb tt4Nl4x2brjr
ggtSveErRzt2b0Xt7fHLrwod7WiN7d10zaV/Mv7Mz8bXh6Z7lzrqvyBJxdXp fzLu1v9UU/8b
UWz2P+g/aDuoOig8AAHoPwABQABgAYCCof+gmaDSoOegsQAEoKKg6qCldAEH 1QU4AE0GLACM
oPY/IAUoPIAFsBvQAZACNB8QAdABsAB0HuCDBggAFAAgQPMBFwBoqgoHeNj/ BWL/d86/uvvt
M9m9j//io+l7hlsvvbZl6/DZS3/4ZFvysh/9DROLyH/4w+cjF4z15B/fx+45 dmSX0n/zhiPf
Wzk2FNm7+eqNG3clOq4Y7ezgWlqSidZto2079m1vb2e2XBIabwt37d50Yfdf TP/8uedfSK1D
IKiL/mfhh75LqmgbfJZ8rwr6n0qmnfG/RKq3Gf9rSDl/8n8CiJN3vk9fM9/n /M33wVxlMFeD
ZP345+voNYKm6Sxp6R3MkLYpkQXnZCBgGz03pNr6IzQnx5YANChq6TmOGeg5 OjgNiFawSr32
VDHltrrUHS8NMpOGFOQYjDUfB9iexzoLksjP0awjKw0VpCxIJSGPZnEGSE4o 5TmQTZEKPrzV
knHCL+I0kTleBBkCPBE4VkQ5a1dT0LmW31EpHch7Qn6JP663VJyU0YP/7AAu SoKKwQDP0zur
yGuYUd+5++UQWVNhMBow7vkc9KXkKlOOHBKxK0fIr38b9avegypmHlHK6A2Q o2Pze0AZ7gx0
qGUhkQQ7rxSkKHliTT/S9c8/A8nI9rLwJxo12pEeezwYNKATExdOAOT2er9V lPzHYK1lH4et
fbmxWHt2jQuWPh8B806rCjAxB7BVpq9W0ZvMei+Us77T8Uz+aqZ+rVE5L87/ 4Jx/Sy4IPv+T
yTTP/zSi1MVgL6P+zWM/53dpAP8r+P/JJD7sZ/f/k6ne5v5fQwqY3HUtmpOp O+DYHU8Ck3vw
z17DH5dkImPEsZXAuJapp3MeeefnkXPuJJrpmQ9Oj9HX656dEaSpb6mbs88V 5rAzAzRnREnl
55aZwTxbVP1O6rirT+JfGkJV16bcaSA87iJ22ZjBWWAtuEBWCPNud88cC54n SCkJhjFjBaDO
MKfkZL4I7PNuoyypDEhxEcRKoS2865V4Bp8jURiQenAIVZA8Zmya/r1Mo2+B DyppyD4tlOZ5
sUJEw364yYHqrvcHi7+QpLDAtVcRrRmX8MGY4PWrqmtLaTkX8SPrATJWE040 yyqcf9SIxJT0
zsG5ozGfmo+BeSzu9nNfXrpDa1giT5q+GxEn7VUKhq6cFixy6BIamzh6cujG qbGhEXTQ9BMd
tRgaWBiVpcIoL3BRu3tZzkIh0+yx1484UxojusMaeMBTE9NTt0wOn8wOztzU 8HFbUrGrHvn4
1NT0ORm1voEcMeMuQcd8Loar57tUTeDs8cHJmdGp4xOD2bGpyYYP25WmZ6G3 NQJ7nARiKPTw
eGD0zCp8coKLKwCrfW9+TYM63qFBjV5k7vg4IvnDGTXSu3RHBJ0U5h2fD7oD XjhYpvVni+MR
bXdEudzdmXBkiWEZQTiPfu2rSKD+7SIS8D36ShjoDYaWB+y8TJDTh0RWAAxK qaCda33aWYr5
jA4edDYJGAWl8kcF/aC9ic2GYrCIakOOdjO6wB7n5rFbsEy/cqiqx0QYVZoB Y1+cj3ZbY6Gu
eVhGf29NoyqWqhtVT8XKzhiuJ+3qRr/gNFyxslVjN69Z27bnfmi3UCqwIrRk 88ShU5eLHBLZ
grHpUwvM0QFjnMtCt5PQa3Co89Ga8vsfEf1xJKime8Gg3hl9GLSrssind2mv FLRrH7DTO8WP
CZwEnnXFTZyIXqWqfsv0p3fjEtbIHSUwyKUl8a6IU2T1bVWHO4iK9o+ORU9v pbvCSCU3CXgu
+973MHgYGf77r8R/9NaCcjtFTj1Y8tx+cm2XOqutfiM0J8ng0pdElS+AR09c FQwA+KIFzW+x
XLRgu/TAMUttD9PSjtRGpziPTV8Yn7TIyTKf5+g9IdwcWxLAy+MW2EUeljz4 ghfpRrTuY9n9
KzodLVy1RDawuTNFcpcD9Ee39VQJb2qzhqAgGrjIM8jWB+Yp4B5pqIdFUA7Q ENot4hG6erA0
j9mhyiGj1CjFC5tJBgcpLDoAtLM3jzog3lGfyAJjoTh+SW174uXDQrsMU9X/ sg2HTevmvTlZ
WgP+cGiBubQFnEXlCJ3jDdYJOUnuPzMH/vi2dSxfTpyiQOUvDc76brvAA6Uc IylHVG9hKjpj
XauUIt94J6Y1vc3FTWMKIQZUu2q6xcdA8zUV9ix3xmO0hkRYDBtLRfdgY/us to8nbzyNv+tQ
pB9FfB5ZoYfazzsPIq++MUKQFzte8v2qaveTJRqbhPm7Ih766W1WUiBmFS10 53ibFr2zLKY6
d4M2DbTies7Tj1eu3A3cmlznE60BW/21gle0v0YlGYtI5XuN6Bz1FCtXe/1K I/jbX3vgIcOd
LrGCEjWnh1lPFu2qATjYVOnHoQWYG5ePBt/18KHAosTnkb1Payv6yN6FFZlF SiNsN1oqYhqM
LGIzDdPSCpkW6yU2swwmQ4GRSioDdqaoCmKUbJOBwjpGRN7RH4EnZd6C2/Vo FTjZs7aOjXrl
ObBYS7J3z6P0Ga2KuiP2nC5liVfBZopaBMRBGlxyON5uJSczODyM+gNUOjkx OHl75ZrHRyam
TowErefZKeUFyk4NT/XTe+IKYM0CZ+ckbPthdwIvwLkFXsjLnEiryNyczCkL 33d3pT0Z0qpH
nb4+LrPgKZyykdN71DMjWa/Raq84wStE9cq9Qf+8sgaKqBjra7BtxHIKaPZl LN9gntCv3FpH
l22sc3qdei/hR+lmIysY6zh8SVxBP7ODTMNZyWHDAcriCpxrpaaAapMIEEmc YKFqFx9iCwFH
kXMEERQ9t9bqMEJZkKRTY6IqOdcpP0PO4REy5vitBF0rkua5QER1V3OQdWfV dDXukwxG1pKI
CYt3E1ZLWOscvEhrtXtwOA/faEnWAkxHRHxJFkcWbLdg0kHbgFsx+gHowjNR wJvF+pQvs/dg
ctIWnTN2LIQ5sxV8yaqWZG9plmabGH1UGpjL/CU89hPcVUX4drp8I1z0aXMa fgFwMmw+T5bc
ijwpSIuciyPGlaNBiJxdKCk9CJou8WBkixISJEwjmctxILmeJKsDh6A/Ty6x 4jJZ5spzxV/u
15gvMiG4mzXnUTZzXfP/fBI/K53/c93/05tIpdPN/L9GlGb+XzP/r2KpKf+P uPBAK4EZlGV2
Gd9ePODxcAwYw9oy58xnWpt1cuQvu1AuOcvOK2JnsMZ6W/td3db9GT0xq2wG l9/JP+NAn7YE
k0Nz+JAWy5tH2ZBKTs+VP/MHHSzh00i2E3dVbD0F23PSSej83vPt5SNltk0p c5XXHxuvsuyQ
l51rpY0r13k/z17AT/SjpGFYUILW5uBYQ7705m4jBuBrZmEFRX71LfMm9YwQ hC1CqwVboQMa
CrDbXuXo6niH+R4H9bBMGRDkCjdgRYzqIETkGn/ABy214QIS0IfQ1HjOLLDK JAl3DzjsQceI
rAKkW5u4E3iBO8hq9C7Srt1dkZvYcfNgO9h6sZGEug24suMFK/aPWpg05yF0 Wm1XSNVOap2C
tQbKVxMhDxQat8uhS2qdwXC/KPh5ZNYHLnWx//2Otmo+QAX7vw9f9uc4/5PM NP//T0NK0/5v
2v8VSyPs/yFJEMCYwAGjIC5AVceEGuA4mI5AVc2mKVlr9R9s9viqnQg/GF/v joTvvAJdIOJt
Ovje5mCaDdYqth5r9RusfdXbd6hgkFlbV7DDhqqiITaprJ/LmGE2O7cuCQmN d4SC+DSWOVvA
kRmZmM7efnJ8bCZrYT15r6qx2kVK7FnNlGaXfFwtx8vsxjvptEbansvdR7rV hPeRtL0JbpEc
RDN3PUqzzuABKrsFWYG2wTckayDkudpzpDsalHiKOWuzTtk9xlVQzm/HsTra rZc0HHz4wz/X
pbKv7wg64LQeLTdmLO+R26PlxowNRx32CE3VdZ3vgOFZujuInK1sR35Onpy5 5citU8dvGh2f
urVycETPxCmTGeQR1PDoCJfAOSh6AdGmkktFWxLy/nX9Rdy/DS7uOI9zrlNC /gQrlDh7eqrH
WMlIgbsSBmv/mn4g1phxavk9nvErs46GMs4HjhiU5aPlTydY2BXPpmvrPU6z VqXW+I/98I73
rT+V9n8T7vtf45nm/m9DSkyL2BCHCTtn6FhJQIkMDdh06ddPnifXw5aRNu+7 YZPNu2FrCT+F
w3kwwMRweEyLOC2CEmiMriYo5Be5ycvsUjLPjI3y82BUDKxpdKe2uzzqGN/R gzKEtLrwuW9w
9ZJ0v0iM8RzsobCRBTw5lTXDRaDcy5zKMAweSpiMJexxkjVMhhI27jP1GkXU /rWRNUXeHqYx
CpcRoVcawHW0IaJBkLX98zgTkKAPvp9AlUv4BlKkqKVZqLqiDddp6YdrydjU rlUgQhftNidt
nm6iz5C9Ip2fz9jpP9vWhx22nzKvxzQcoycfJWASj714jzkQV8SrbvBpVDvw NXGz7BJZlYNF
Z8rPRcueNwBHxuUqaE3DwT0olzNE9ZjKe5h6N1FLX/obwsRXcTa23/9w8uTY 5PQt2Zl+2iKs
p8WTD1X0MnVLth7dGJ9Pjtw2fXxkZga+9ehzBf9coTLUNLnP01KrRTaSn694 12d5+z+RSFj3
f/FdsMlMX2/z/780pKwv+98lbd5Wf6Zp9dfB6m+kka/VASNleV4Sh7mcttld sbbAixzMQKS7
I0E9iPPi1knDKlv2r+M2A83JWu6nDOiVYPWphwej/0eLeffuNN0vNPwRvD2N 62nbgsZlhGST
e44IBOmR3izGm/+ZAvekYOdlGbHIzWgGHeFyLGAympXUBeRPHKqcmgJrbMeR U07G93eiBXYR
X2lhnLHX7N8etAT6C73jM8UiPqhErTlVMh0q3CMFEFevvAiMJMovka0lQAe6 yb1A7xEC0gsC
QSuPvfqybqGV5q6LF71mf699Qx2318fLar9pZqTliSX/0roh7H3pkfPfPJjj ixLG+x6pMf/X
heU7fTPX4i0aYVs6nnqf3nP6gvZZVfAIXZNySyp2avU/KaXddWwhchcGgvTI 0pKlse2prS2p
yeBTqByIKd40c9UHa35scPLo+MjJ7Ni0Z9sZIA8XTYMFwKStFcyJMMY5V8s4 SHvvM+JGBqkF
p+vK1gq+sQ9PfT1k98Yc3nkTBBOxHVso5gNmaGpycmSIOEojk8PTU2OT2ZmT x6fGRxz3qek6
NyLmixKvhXBo3/YL4Vb16iOB3j3DaVkFNwJCCpwSfAzebyWvMmfm0Zt5j5WJ Fxh98e8yKR/4
cblUDx3eTJA0QNnj6lnHS9xHte273t6y+b/s/W1wZMmWGIa1uE/yw7NaWpmM 8Nqi7Dvo1Uzh
DbqAKnzNNBozgwGqp2sfGmgC6Jnp3X2GClUXwN0u1K1Xt6rRePM6vCLXNG0x RFKWTI8V5tIO
/nEowqYs/qW5DHElSjFS+AcddoQjSEUorJAd4Y8/ClmSHe08J7+/7kd9AZip u/umUfdmnsw8
efLkyZPnw0OfRSK+qFSp4MQf+cXouIIh04Ncw844R5E7QodncAUidfhH64zS AXocqD1pDIxq
MeBBzBCWAw4EuSwIMnRd2VfzhhLMfZs7hG2BDUgPYEGkpwtkTEHYQh/jRr/f aF7Q1XwR9kJH
3ApuRiD6W9BowOxsbfeL2snJ0cGLwx0rPof6mJEqcgI+3iaH4VTLBB/g1Avy 8VP9sFEysCEP
teeIlgGPMV1o5SjKOaJnKOi4aXs1sbNZ7vpM+FZ32VtsKuYeB3Nv9w7FZ7s1 UwbfnmdUjRxn
a2BNqgiFBew/KpXKqm3/UZ3Zf0zlcet/qyu3U/+bQm0zTfAk7T8mbAAiVSHb neaFL30ObGsg
bZAhJ+CsA39kqE7Zkb4s9D465fhr98JfDMKkT9rBlSE7eEg/5Kh5GDKFh6yS L/2OMkbeqjXa
8Sl6653ugKCjl9u25WDQL1hDXbYORbJ7VXOVcpP58nCs0NBMUqlGneGEOyEs lnZIdcT1Pihx
EzWqMtU2k9PFKSFdHtS4FZxeYyHan8enn3jo5fHS6Se8X5iEB88yBXW47uEK ba6naVTl2kpZ
t0TnbsIh2NkJh3Ob5owgm+ZZmg/QX0Chf5jVkK0DKx9x1nL1KwEZxCC1OQ/U oKdBV/BqrVxO
vubxuWSVXOBQ0T8CYufxXqjTZHJMQvv4jwFecWwX6AXVPCpO6KnJhFTig1Ja EzwiwNVujkF8
XsjTIBQs0e7q6mUcpdQtl6AtXU8gQxEwbqgRoZxUtQtml3I4+EMxHMrTOGFd 9yoeXU2KGxov
NnJ1gRdXujIGxXmxdccIfzqrTmtsnGuOuYEa30se8sOjLtM5K2txP7yiSkpd OT6OlUhF5rSV
KIHJ7de9GOX3jNVIG81ejSyKOl+NkmIpZhKDS7GaDsdCz7KdDA0L6YtzuQwS NqW1XLTracSE
NSmapRes8J+tgBKsZBkK4dr3woSCy0Knk7IIALbn+0G7xdg0FJLcffyL4/u2 TU2Y3jkvmSi9
6438QOidMUJO7zzPxfQ3Aw7mpreCbIqfqXpv+TOqRq78QHVF1mwzy5Xyx9hG hv63ura6otv/
rlQqM/3vdJ67Zf/rpTW39vfjmfb3tnn/TSAa7NgdCvPY6+bT5FIL10SLLGV2 bfwxqW44fhVV
orqWapqVsBYMiFoLx3jaZqHh6n1uhpZImzdYFVA5gkUbA/knGA0Lg0uFPbo+ Gq1WAiXC9hl8
57kHEGrc4TFgRMh7jDsf9TmUBNXIF6RiJyZLOSJCWPAaU5bwLGF0aTao1Bsx g2YW/IBwiMUg
iQFeKzzDdAgx9hYVr6gPZkMg3Uh4/HxXsvZUlbIL2UKhrL70aJHzmPa62tBi MWWZ+pZowCbD
tBe7Mi2d81SNRqkRhKvo0Oadx9v1/dqhz6STL8odTv9jsCnd23558OI4d4tf v9xrXMeDcViz
HtX2mFnpk1pt9/PtnZ/5esGJ8CnZvduwg6dant52E3IlCpe9bTg00PbqZO0Y AZeyGizZhfHU
6GtY5R9zRh4alJJaBD9wK8fkHcpjKYuNlVBxSUy555VMrxxgxtEeSyFjpIyB Kz8Pi5pFX5pF
X/I935/oS/vh1Y1GXzJ3uJxRl+CPYrzX5rRUudeHFK+Njteesa4yQKu0zfk8 jBJwTSv6b/0m
FsKSYkty2GPBL0X4fBr6VesBnD7J7tJuU3OGJh19orNgKsGT824So521aANE 006zPWjRwynU
XOTHUDzWRnSXB8tdEBj7IWkHV2wHYkl6N75C2QEI0ULya1e4fp1VZ8cTdGRq MjiWiPcf6T4f
2Ea/aChNNUOADosgkRxOSlFf5gvI5skUE2gtTCrSVAAZofoL9JnP8E1325U+ gIKYvOA2C0c6
eRz/wCOV3vYLkHFEZPC7EVI78Kz4f8tm/I+V6urKykz/P43HY/9dvZ36/xzU NosD+P26Ccih
7f88ZD7Ue4TY+j7rccvUPLXYeRhfhv3edfk5Ao7SLL6dITnyWKX7SdkPgHpE JnLQuHQFjAIV
RQWpun9O7aG5vgUIlFWz9daLTNHvH4TMvUTPL0bqCtDxMP/OSyLuRcBMTnnn koDQH89jbHMa
qi36KU0mgUE8aJZpWAUERIAwhgmu4R/N/Z/McY26v1DwjR5e0Qxfl+V1r4ZQ nE6oxGxaZPpN
s4Az6CBNvOYpTweHRZC6XGe8uTl7NaG1P/6xpdpLC9sf1Tp2bk4s2IAR0pZu ZcoO9viNVcHc
b6Cui0jh5U3yz2NWuZxEvwS/6YdBlbz+8EMetc9YRJyO6Yg8S7PEh7EYLC8G NF6eVpyxr5LR
3UXSnw+DygILJQiow9MVbZO+favEnGxTZsXoQdVVCJ8JowU6KKmc4F84ZhUV 8CyY3/frGdki
4yIm8spu1AubfVPu509W/rdKtWrI/8sbq9WZ/D+Nxy3/ryzfTvk/hdrccn9l eSb43zbB3yFt
7zVOw7ZfdB3S6dOkE381YRUtqwzvtIk0SlBJrz/zeW5aBkMIpKCpENbJb1jE Othoaw6dlh2P
c8lxSx4iqUJbzMUSCwUwB8HZoNOk0KP+9X0e4g8+9WHJNAIKl1uDfJAEz2mf Wa+YCUw+6xdn
F4X9i/XhGxSLaMSoI0LwpD/NQa9HuiGQspkuxrtbdIjvo8nkZgNw/yXfZZr4 W8TsktgV634b
tAVBWPaLIOJfhH0a15BIsq/hWpIzNxhJ3INSDMf0KxHh6W/dZD+kRiFwCQG/ 2QUnnQZoZptV
J1UIF4Kr1wFh1peEKpjxFbvvYjYHjTbZ0FpAA3AQYDDYabKJk1eGG2qwzwJg rZh+JHDg8rpM
w4YHJdZlcY00ZwZ2Z5Dp9kkTMSI2CcxBtwXvZIuye3jMcbKJoHkpXCGcBWiX FMQchXRFQTtt
YKPQdnjZ7V8HCeJ5MSD/nJ+j7dlFSPXiBIVslmD16sMtI4qT0vz8Aj/tkGbq Hbr3AHoW4Z4J
tpwObGwxbjrcSYD0h42ZDej3KM1jG3NkdOBG8ILVKp2RhtgJhn/bpmcS9+jL 29QiaLe2Vzuu
saMP4SFJWBjEs4Pd+pOXCiK/iF5rs8WMVNg45JQFTTyG4t9eJ1HRF1qOCB6y oScREyKakgUH
MfJg6sZxem2QiotVC48PGDfzerFLlUzGpnUOS0hnDuzdz8KwG8BdzitOImJl Y00DHsEFfmMA
uB/IZWsC3A8SJu7Q9uEt5RGjcT8ah8oFN4v1jcTU6HJTiuLRn57F+aU1W3so GrGVTWd7rlRS
xQNBg/yUjm1htW0wNsGw/M6m2MKDrlD4RtNz+JaGE33Tl5yHxvbnnIGyBXC0 JgjDS2UWUAHO
CvRF/xErfAFkRRZWt4fXnkEjue40yeDAZJBe1XXbjSZnZ02CP7aNBP2rqEn5 8pwxXBjTC+S1
zxodIowCssn+C+lJ6OuSVJGMmyBJz8KDdmu81GgBzbELX4UiZN4525DZSmUU qoYkbsPpbdAV
/N+zrguS9Cy01118xhWRSfPGMdrI1P+sbujxv6obG8vLM/3PNB5+2LslCh4n OXlUO5WZamcU
1Q48dl744CELqNRG60HeFwFo9NvedNeuzquwNcJV8JNeGMLOv9e49qVesEsS 4SO1aJ7MFaTn
4ee4w07Q6SyP0uuQLEO0XuqEHV33ld/jbBhPsBt0ONM0RTZJu1RGJp+xEuvp PjR+z6kdFp2s
ofnDCLDcaaAsDelSXa2scELC04q/EMaBXjcr04BcVLhrnjDaYoZTgkhWoX3R zFaxFBxZ6Lrm
RwKjEvmiG6WKanQNY3m5pEsVrTC/Z2U8Zqw4naRT2lymRxpmgUuN9r9/sFvj cf7hqLiZWeOL
w+3nT+s723snxev6fMDy1keXmP3a/rGSmsDDIIEeGAqMCZWL/RAnnurRBGeS M8zoQv3qtngV
a1kJypEjJpgWxIMbqxo+A2OmQp/V/pBW/mj8MUemi39n61nu+5IUddt8ZWrm uJX7V5pBu9cI
fw7N2EuBasYesH7NqZ1Bq4pAGK0HAgBdFs5WfWb0c75W53I1KadSIQSlnsp2 7nh2zg5N+uBw
kFOczxCjvPgYEnLyfJzYMtd32X5r27u7j/yfTp5t77/0fT+sPTv4spb+VQHg zFIqPb0M70PM
PyXUdHPM10suOqqko1ZBWk5OT3eOasesGwzUl+jhnghIEsRbPhMu5y9tBMHM Xuj2P+M6sDt8
zoUqKEP/U61srBjx36vL6+sz/c80Hk/8n49up/1PFrV5NEUzRdGtDgI/gomP gxByWPlQalct
fLgqoVAAb0fjQo/g+vbNSLdPDojoD10kQm8+OxBXHF7vzVNmEnnTZGJ2UXSb nrFn5HDcAaXv
/9UqJHvR9//l1Y3Z/j+V55be/1jk5NnZV2Zb+/fvDijzlidfuhinJ994b2eK eP7lkVBUsveX
yp+CZrcXd4saMnMTZOhLMQPkiWadGSbfzJB3TFaaGnBelOleZIQryd5k4nIR C7ALPKbT1xJD
PCR8InoN5ywa2pCbpGJklzJrC8ypsB0ldy0U0jJLyGTjlItwQ2y6rh8P2tTt 8nE7+kRku6Fh
FjnFJqRmiM1fI087DQmzg/KBqMm4QPua59shPQd+pFck/Ip/XeqFouTjJQKB glri3Sl0U9dg
ymhf2hya3Z085t0dm3a9kIJMHcI3WZd6WlDFohd6nnw86o0eJinJip1oRYXy ZUgfV+oTT8KT
8d8Z8rbMsOdp913aXYO3oj1MCx8Y9wutZYF5JdMcr5nWIPd4vRVzjhdZr2e4 jF7RwFiPC++J
bG83zQxjO43LkF6YyI2EXdSQL0/iHgtrL+PNSxDYvAgElTJpJWjFGYneHULI GJ6S6OGWDQ/n
qOjoCAsT+cC0u0p23Y5iaZQs0oCKELOL3n/QHV9wNOtCk9fHanK4ZS+5yjIm grz8RxbKHXQS
dyHqfQTbUKPVogawDY0HLsIHKlgLJm4FlOSWsEESC/A8DjDpTcLuNWDjPkMf /oRul6xRQi40
3BA5T3wFvaJFZK9kAbRyFm00aKvxVUfmoNMYOJsy0fVFHtePOxBwHmBNxlgi Yua9m1MriNs5
jXB5gMn0/O7OazYzcqT/Ls4VY9IZ1dN5r4YJn2wA39ivvHCd0UJl2hk3JE8D 8LDJdnD8TXel
t+7X1ENmuMYd22v+xh2v3H3x9ENGTDOyPrJA2eriLTBPzvkfbooUX5ygRFOt +JvzIA4eX4Q3
M+2W+nhm23UdnKMqv+PNWm307jp7VSp33HkXpgzBOluYt3thTnpZDR3mN3MN eqPm3sxq8oRG
zk/F2skt9/w57DwKDEopYpxUJxcNeLq2kti/JR6vXjg0B116lUfETBbyR92T WLgfVR7KHe7e
ZSapF1YNjM3EvkOnFNDsI/3teQwmR5pQVRnywJ/3LFvn6okrah3p/G14Yk6x KEgWYWh56Gie
UFlcdwTmVeSB3DwvWp0x88vxQ+VNIdyXILAwljOzA6KGPujyyGD4s1QqKVps 4Yy4YLuyZqPa
3a9tImTZerTRUOvJWTlWWva0cStpmecGnRgt50R4cVr2AL5xWnb3axy0nLLR mlJD+ibrLm3q
tssOUUQWMUeeMPpxas10yvJUZ+azbgj8YxYQzHiMwaFtMFFST/B7JpQnUSeC Q4QXDC3gXCxS
D3bZeBVSLZGZJSWh6rEU1VBK0G1HqHD50Rc43zSSNzSa3mjz6ZHmDRnWceQW FvSWxJ33XP02
3zCo3vl2j8NLKSwmOqWVYcglNUq7Mwz6XSQZ/9nzrhFNoZGwf2aWeT+kp7xU XvpsL+6cgwvW
hNpgdv6+f5craxXxN76vVNbWq/eCvQn1R3u4/R+Yr6WVy/p+R5+xW+TbGQBd IUFmzy15pjD/
mfm/19eXTf+f9erGzP53Gs8d9//xcJtZMOA76QhkWuzuRkRWTbwWuGbxw7DZ b3TO05JgjMdM
1zLqGsFWd0jHp/24cxgm0S9hkgvHiLFXzVBOU8XCIgunIgwzVyQosgFDPV8N CegINWeg3Iry
dmboMMuFoukMk+59L467k0oPf9xrdBIImmIYwt+qmECWvTaNXJ1js3AlpKcX fNzGm9d5CPbf
MiwPY+6E2yaD04fiLVWbQsJ4wNmgjVbE/FqQh5KlBuRwq8g4v7KDfmAakotN hLTD08Url76G
qXNy37KyLubJaKNIWFc7Pn0zqkMjXYFhy4TMbnS3Wy2fY6M0iEPPkTbh++UD NKpPc260wMor
ErjeXwwoCJZdB5jDyI6OE0QPvWS3GNlYceVrIzAwxyJR8MeLSBfnDdrs7oP/ plcmrqIsIIVR
AWMZg8LdMpPHzim3WN7q4vqlJKSIBaXzm2p+Hb326DNtTe9Nu/XSyYPkRPSv Y2oDqsSB3Vc/
icRNCHmuqbYTbInlQOO3QJgTHe5WoO8yPFAL7QvGGwHTpMBZle2veh0Myc4C 89DsYITNRj2w
s7W4cXAaNhvkcCf9WTpxHy2YEwTlklvY2uCB2h0leOAU6LMrRLjLgEcGdKHg GVWDtlaGgHIB
kzGZ5xiqsuGU9BzUTrB4ZW6mPRUNSeD80gzzWuOyc1EKi25EaooVprAH0GbL lXeuLv0ncY+H
yuah4kXTYtmaa1UtA1GsS/NNNUY/6eQ8K6iUljRLf2/mIEBAH6O+X/2Kot1J pQLXmYW5PJcN
lSYy0EnfKyO7iNZR7LZS7jjpFTaFkuHzdKtJlg8JnTYKEa4alF8tOpldazds h/1wN+wSibHh
F0hypiNxA3NvWWMVvbzyVkTDsjMDOJ+c5RqXIjW7genyFA+ORhahEGF2YJ0T imf5OdjyF17y
nA0wfuGvRtmfVU/ZO8lWSJYiHmbEjtjj2ob7ahYUwkncmggl6L66sFk9NRCl iQg64EAL2j83
wmTa5xZ0wYs60eXg8ij6JThrWVNpaXhccyrUU4EN0AKgzStfkWKOyPmLzMnz RofdGCvQJhtd
f+SMbAY1ue56MuJ/ra1VjPx/1Y3V9Zn+fyqPR/+/fjv1/y5qc+v612eq/juQ 94/LdGmR04sE
YfenEcwZpp0Ve9bonUedm4jnnlwREZTuHaACavuCm0C5q6gFzqnl3SjpthuT D/E+xpDtLLeg
vpxd2ljYOWncChr0FCNl8PAZZeOU34kRuOIWy7J40QUMC/SCnBqor610Ey5j gA/RHOYUh2w6
WPsV5sO64F7S2ABN7cbiYLDjJFnhb2CKgm6cRKqLYtEs5AZSsqJbaNkME0it 3iRdhZRiSD3B
zsGzZ+DgsXOwd3DID3/wpcTIpoyi9llj0CbnncXq2hr+r/JxFeWO+0oWRDPS hZETUe831wWI
QBVqbkRLT6dEsxhSdi8Ymd4S5twx6bVcXzjDLJs4MxPWbIZRYtXyddHg1niY o7VZhq3gU/rz
UTA/zyRdkWuLhZxnE6Xyx1JghaWnIc1VdlXaAFHehEmW4HkPINGpN6jCKH3Q bZCjFelxbxAG
MvSyCHtPmSyXy/WzG8y4ihMztTjVD2luBeOY8AxXMHemLVdZHpTadKFK8Zri M8XUf24/KTFI
tpbmtPyQDHGUxYjwOjpruWhA0IGQ85WWFjvIXIzDBOJ2BKBWvPxB4WQ5LvIz 45iicmMfFDhb
VmlOtyfsD6l5KpVwnS0owSMWROo6lzsoXdTcYVVVFf2QQlyPSSJ30L08Cmac /1bWzfPfSmVj
eZb/fSqPff7bHpwHG7f6+Ocjtln057to9DVS9GdXnqssQ6YviCBUOCqi6CHV SheyY5qmMZBi
elMwqrV/cSlBre1v3+hyjedU4JSLrGzpPjMLelMyaIL3ELO1GNW2wuoOkxzl 9Kbeu6s0lG1E
oQNV6wYt/HTouH4H/XvYYQcOednF7sOsfNO8RRFXzLp2z7rN4+I7F6lclM76 uyOylLsKldQL
KmiZjURvS5C2lOEEcBDcRJ6dwLj7o9Ds277Ae5vohiuvJhlEtbpWhZ9m1POL 7y5T4F9AcF7G
iQhuNxwOfQxbspiZ4eJ/V6prIPNp8t/y2nJlJv9N47lz+n83tc1SxN6VWwAZ 6Hu712tc+3K9
jhghPPW2YCy6+2LBtFXCLRZUexghcBiBcRLKfWutZmj4pUigq/kRar3PIxsl gaqzw8rgvN6L
2yxGaZObM9P10WgR2ZWUCNtn8J07vSNUFj8wkYKECPzJoFB7btC+dWKylCMi qQWvMVYF8AUi
u/bp0mxQk5SI3RGwqBaEQywGSQzwWuEZWT5wpwC9RbGXW3Qza3OIMD70pYGF bCG2qy9zxLt2
whou7rULlCbMZca9RonPG+z6tkcQy0y4inEDisTr2j/eru/XDrPjdVnJgoYO Era3/fLgRY4I
YV4XgqFb9qV/tXvBaeop2b/bsIePMU7ZMNdLHsrJmfhYsa6yNw5v0G67KLuJ sQD4GizZhXNH
Y55jfBVEIpEgodWiV6FM4qFcljLZWF5eAH9E/nkVCnAQKhFOSecAtOeKVuLm OCMGPM4ddVE7
kUoA3+ikmf9exHktYkZlhO5lXY88P3ixv3tyvH30s5OToxeff3Vw+LMnewdf GZEhjX7CwyM0
p9wB5Q8vmTvOJX+WlliwEgyQHcTtlr/s0LFBrSQK/vizaaF6SV+xp2R2Y1ik /pK+oD2j9lOJ
ZprSTyaCpIYdpivfUcCI/qn8nGbQT2f6BM1a0s0G6ioDtErbnM/DKKnCrePi uaqqT4ozBpyc
rNadcINiS3LYY8Evmzx7NjoS6j2A8yfZXSBpCwsR30cDGY0FM7OX7XYSo6WL aAOE006zPWiF
wrRmkR9E8WAb0V2+FSQhyH/9kLSDK7ZDPWb0ySiUHBweLCdVmGQDFKdEI7wR 8EIL27ZOkBlc
+Fm0LywVtiHNPdIaKZ+nZB/nT3qQJ0fHKLEAJjBJuAjyZAJ+O3Sf+QzfdLc1 hpKR4WLcgpsZ
z6xolDwgwyjZhgL2BimYq3wtA9qTpUYPe0H4GlcoLiO2RoXHh6zp20uy51pf OI64fhPGsR01
rnhwOcDzewURzcLdIV4VvifL+AWJ4ZBqxL5jaL3VtiGjamTT9P78ybL/qCyv 6/F/qusbazP7
/6k8tyz/Z17F/izv5x3K+1lUPz+Iyq+j8CopS/1quf6c/n1Nia+wAr644n0Y JbonEkleFbit
+r5vqYGzsiZSfbBTD+zOoKjajxtY5gpu/lMYFdiHk7GnTNRUxnlUxYY/Lysd 3GXlX5rSjx83
qXjCAQhLa+4l7UjjqJip6KpCtTndblvRB+rqwDtt+zp7xmD/gU7Iqea/WfLf 6joR9gz737Xl
1Zn8N43nlsl/6eQ0M/D9XsmCw8ZHzCf5NVhiTC4VbDdzhLAzKwuDTw7F6m8+ q2FO1x16IVbU
bpiHHJSC5Xar0aWmsWypaOmp+AVcEyuyT3CkGlae9K5LS7h0lEEZc2jhi9vs anf21GQX1xwI
l62EzUvBhC+EzbXDRidwAFLCjLi1UTpdYQ7SnYP93TreVx8fnOw8Pajv1HjY DQIGs7bQezSn
+gr97TYtQZCqlhw9hJ6NQbhNs4lmSuL0GC4uxHJzYQVAZsacoZDKY/akIlYJ +6cvQGkDbOXk
2XQopelUKGNSChvTYJ+MuEMfoAXvbVotzCAM/JVdk2PyYrpmzbMSa0m+pl3y HjZ0A3TX0I2R
++fFzbuCprABdxfQrhKa1JCaTmvJXaG8TW09yKQ7qtI6qJilf7nyJDXR2to7 FWpObMYahdLd
xSo1VCul/FinQJRO+o53pZIevmdBmufTuxlWXx3OJA5a4xLY2FTCcJ41OmQz 6eX2/1tdrpj2
35W1jeWZ/D+Nx23/vVK5pfbf6dTmPh9UZ+eDW+0AmB28pWDM9T6R6og8E1Ij w7iHEfd8gVRk
hd2oF1LxktGUu8LvnTWaISqoCRrKddnMl4121GINWcbQXsJV9MENEeQZqINW tDrFyiNsECMu
4TVGpyDU1MLSuInBKwJFCBdIMxDvg0YOaLC9iury0MSZyDYQg5WRMDv9Rb9s qBZ8TTJaBA8C
DKG6sNeDvOwXYfMVabCw1bIXK+JYYY0/iIDr0KAvLuSj4lIJwrGp+ycycSpB HqWHNUE4IEdq
r9uUeCy/Rm/XS6A4tcO/0RYxTjJG5FPaoy9NcuUta26SDIpaWZQTzn48+Aj4 q3ERy4S+wGth
7kmMUDJcLA7P2nkA9CNb9QfhMMvR0YIEpLwEAZAavNFJRYkfzUqY05+7PKWI EmWZrigcYYdQ
fDOk1qfMXIrJ4gmN+UIqUpt/kwCO+Hdsp8R8Nl9DJ/WoMRIkmRH6bgGLUbdN TQpEyRPKGcIh
mGHyuxAtFjVKqlHyArsoZrukNLoQfApBZh4F8/LdJRF6gtOQjWx+psf/4T6j e+T5OEz++B8r
ayum/L++Nov/MZXnjsn/6dQ2ux/4fsr/QyR6KnQG0EV6WcldWgvRiHm9/eV4 iEYQVrRjAYpf
XCuoCNXoCUm1SIoswvxjYoJ5IsFjLYSSdMMmOKe0aJA5bqqdXMSDNmQ2QPBx hwk4kTgDsPMC
wmgOehidQTRXVIj3rklVVLc/qnYnirx+HNcorcyx8HIiNbunlZJdm0eUgKVS Vt9vmW281Rqh
gKRArBlBuGsWlpSt/j/ohZQYSnlIcsGUQ1mmdQZCFkSqokTFxgE0yGMYluDH gizCg1D3Yh5P
hOWv74VnpDjUgsus7qAfYkzqh2SDeFihJWVsfDx8ajjmgvrnYEmbcLPzLg8P rpbsQxIQyJh0
HG+fJnGbNFUCgLQk9gCjIyIg+FB+83B1EdssX0N/oK/lNx/yv64/JP2bu/EA G7f8GXVHrhH+
5jT6UJ4M+a+6trZmxv+urq/P5L9pPG75r1q9nfKfg9pmMt8dCfwxtphvPLjz FIO+yUYLWm4A
wWpyXy6RSidzJfyaPfSs+Gs6qJuNuWb3XuaMGVvENQuiFm5NTxpjTWvQFBGy jS8MWU2QQQCn
pRL8NyUQGL+R3rzdEsioHNlSdCdPGkAzRew/Vyprpv5ndWOm/5nKc8vsP9PJ yb3Xb8z2+rtr
/5l9m8tLMELI3Lxvb6JmJgzc/aTO9P+EKWqH3VUbM8VvtkGlRQtYq5sVcYW7 ymeX6uUXqu7J
6JcSAquIsaQBRQ0ZBddyhZLuukwmxR2gAVi+h1AOb/oiSTE6irnMKEvUhcyR qNFtHqmGcRLN
yuiotB16jy4SYVpN6ES1cN/IEqd/lq0Y1fK1xReH1Qr/IOGLovkgG2F9dOjO aGZ6II+cuHJB
16Hq0NRJS4WMQqkJWZwBEDIWyYkN5KA2HrTLaW7JmB/DzIvPQq6WPkbE2lXA mnRLnRGZfeTt
lK9v+zOqwOYOOKcHA8iS/ysbK7r/PzkQrMz8/6fy3K34v+nU5j4erM2OB2NQ BY75svem4/Om
hL/N1tU1mCdSoImiXtrMk8HNYaLoSbPmbcaMGudMvKbmWZu45m+SKdnGku95 uinElIsLI45r
vtCtGTDVMK3FIrNmYy9zuZvrSCBTjwyYf5W777kLZjQji2Cuf90NHZE3laiW wm6WRsAsBViF
J6WwI1lu7+4+8n86eba9/9L3/bD27ODLWvpXBQBfoY8wSB858JHFEHXOYsxL 2YmvwGVOxALE
Iizk46e0Ovsl4+1t0venhGpfsb89fTmqHT/SgHyJIa8TB4wh0qXNpPXb8owr I4Mj8LI4AWT6
fy2b/l/V5epM/p/K47n///h2yv9Z1DZzALvDBqCYmnYnRlVRP0m1BE09PuQK K8EKZDRnXWLr
UuwYc4H4smc4KJ3r1Qk9vo5ahCBYNoozIgCckrmg+WMbbDZtleUHCU80CzHI Gj0iDYWtRUiJ
jfFIuS8ZLUMKn4rkwWR8ZIrKQWELUe9YxNnIgVgUwAqI9IpZATnJJOExDu0J w0pKAAOHoOkC
4LYhYBYAImK0M9uyRtllsqT7YTCcu5UyyOQivhpljI767iFCCjcr1AKPwRCY K4mIsX8GfPiJ
BP2rXzEtb6G6O4e17eMaJLFmIvgQKEYy+7wt8le/Hdl8xUGgD4yOpRxhjZLc /MRK2NBkr9jP
LWdKBhGGQgUpTjHc8ESDVFYC2kJAc9XbbyaK/4Cf8Wlk/RHgMvM/Ly8b+v9q ZZb/eTqPO//z
rVf/F4kPNxP/b7f4f2cTQBfL/DxKKufRghDnEtJT1tYo+Z9TwM4SQN+yBNAq ATmyQKenf5Y2
0vdHSvvMhjfmpM8MaoGUz6AzL+khpb8/WZ/lM+qWbFpcuTzAsvS/q6b/f3Vj vTqL/zuV527Z
fzipzS31rc+kvu+b2UcxNSunlWJZH4raXWfnQTZpNi0BhFnWkf8hVYgz6+uS m5nTt5DdiWVa
y19k2pncXuMRxWLYyGkwp8HSC2GAAKOani5B/+pImeAGrwL2gdRzOhSMQmCv MBpGunezZhpn
JTvBpTPpqkAUFx3BwqOAgcdc/nysVmpVusCYuAddpu1u2VlOhVwLpVLTte4d HDxnqVq/elrf
q8lYxxLInIPaQED9ChLzKRG/HClCabAxliiUd50Ju2+FeJong+dY7at4Ul9h UeIzrrIKKhym
bH0Us5wTYdpiA4wZBQBjc9/7+BHjUskZdl/aMSBd/id/bayb9t/VytpM/p/G c8v8P9PIyRPp
YabevaPun2ZUr92ITHnitfA2i6dE3ioYL8wrFo3PPN1Xx9dGwYjHOSRmd+VJ pNoDXVmuQxev
iB5epgWx1YkhzflHPsXl8EoNlOOeh4MZp75TMLilIiXmgiBsST0M0nNfRHMO KPwXArzFCU8D
boWMNtpmnA0/I0CevjvRDXyS6JchMhkMIgZSetQhE9mNgVeJNMUJ7w82vkgZ YUdKaaQz0B+a
3ZjwQgBD2Czt6iDhZkUUS7mWnxrqmnQ87EFMNP3YK1wx9EsMA/nUR5Cfhb1L hBZTHIdZP4TD
cNE0iWodvt6ZxZXwZ5Qyr6fzXr8Oy/M34UdD5fRt5ML4HqTPBnmtz8gMiOoM A5DbFCorpWTO
Nl/9YHNlJ/24Wwipqbmzc6HVnS2bI9adtYVyE8JoOOvmq8FK1+JGnrmWXH21 8Ml1MEZJTNni
yK9ZjDD8OhnMyAm8wkcJgqVYJe3OC64z9m4SQqN/PaEB6Us54x3w3FtWfXb7 CfoV/3DIR25F
KGcBrdxgI5DJgcY61ETgOZ9sl7aCJSwxjZ2Q2WPaw6bTRy9dj51TaelOdK8d CyKN70l2/GBL
5w+gFcWPzoUMKP66tLDoXDnw8aWemEkI9VTKcLQlSpT0b/D4GvkqavUvSC/y 13gawqlP75sS
uJRdZ4s3JYKYReyyzrlKJYtlIxvgl/KoaaJedmiM2gOJyxgYnPCMnisaYuNL bwRCbsa9sNwb
dPoEw+U6EjEcH4GxMIpW1iquGw/BshWp1KMpLF6F1zZhkf5BnOJe1KLhh1vh WQPuxk/Di8br
CG4wwrOoQ7OQmLpBCYUcTOnZ+ApDGYdvusgTxBZAxNJTIrQK0Yvl12ihcbqE AcrjsEFP9Hz7
DZqE6zDjeRuCUn1J31INqY9phLe2FDQYqMAJpAwLaESrrqVHe2sxOGHjyzEO jZikIE9aAerM
W5lZpUuy0IJKdcWIbHh3UAcaTJKTNziGlO2ta4g+pjROxXH/DJnlbaaiBchx HU+9Mo9/grvm
+VbD/zC3KTYy8t6OqBXyXY84b0d0VglT4bsj8U8G9cENSqIbhvT6jT076Lxq duirg8OfPdk7
+Oqktld7Vts/Pjn5Ong0dN2XI9T9qr57/HSE+k9r9S+eHrsAUGqyvHNdxbi3 rvrurUWeHvGb
n+9RNQnLm6ap0Y/78sSgkU0i4PRj5MIyZL1fhJfcRruSxvpQq30ma9HQ9jLi fXxK1boCRlbH
LL6Di853Zsx9GAfy5118z2JB8PBhh4zFQ3j0RqtVAjRnHIguyQ5rzYdIZZkH xccXg2QxIFWv
onabIIZIgoChXtgMyaHRibAxzA+B55yjRucavdvT58R/5JzwrPQQ4ebEfC+u BMeTkTHN+i/z
/m+jUqlY8d/XZvd/U3nulv2fg9o8t4IfzW4Fb1sAeDxrks63y/U+2PWzRJlD WgtmZw0aSxip
yfuXm64vR32C3BxeLDLlYmZnRshvCslbtIRIRSPnO1N957wYFB7zSqrSolV5 y89JFYaoPSaz
5nbeKRhImLXYaB8M+t1BH1rOW7l4jWwDVJ1pppmfssRTMap7dMU/jdBbIKur ++5N9afwXrul
zZl1F2cniL0U1G2LzqaNqy5uqqldxfUbQ4r/1s00eDXk9nHfEJmWrx6J2W3/ avVeXVo8LMSW
EuXVUBDBQ0uhV409P5qQDA9Td5zxxathR/GXolgGBT7+laLCYuFmU25fTLBS R6YPKqOJkfVk
E7e9dZHvXdcZ5TMFFqGJeVWPHkm5RfKUhMcXi82ndVlaYodwZJDIpdnaiQd9 kSubkjT94IbD
FOuxA28H7Raz3PWodFh64URP9KxuOgtBjHcf+41LPxgylG2uRcIMgZAuMAJX NRifBdcLZD+m
EejAXgTMWXTFlLuatSDLnlZLSRHFFjz81mE4tZmtGoOHxbQOjPucnATrmiG7 c++/7zUsdxYW
S889TofRubAx3947OXhx/PzF8cnzg8PjE2l87l9VjObidsulJveSoR9Dfvq0 aWPQbTX6ioG2
3QHSL8eVoGNlaZbxOaqYxvQ613pr2zakm9NrlUaVEBS7eteVr0+ZlnlBzOa6 QybHnGxll5bz
x/VpTjJ11ii3w8453OMGnwTLbvr91F3TXfhRMP87YJ93GbZ+Pq+Qk01KCQME ZXVhBZEiaVdn
DdzzwMk7nKpaYIWUKXIWi+d/pTcfiKSssG/E2DLuKImM40VhNehGc9FIgtMQ vhApvEUIhLHq
Vq751oYm5lwOUX7H1pTB80N7EDGXdHVaaDXQlUasmIa4K3CtCEpRv0x6v08O A5pVknkfB42T
TU3lIKRmB6sZXAJNnUpYI4vXmnZQLjEg7vSjziC0dwMnG5QJelO2YOgbS3sq PEs2neDoSssB
yckvARM2odN2WSqz7Q4RSXqU6B3Xoh6k2EAJ4dk7NEBdlCjJ3lHfjpn9ucM2 U2DuJeGvYR7v
yq6ipgkdQQuuUQyLQVY8WfrxFa530B3DGwIJUp2QBY+ZcmEwfZh5DUxMT92S uJgSgP1URCk7
HLSOcyU6zm79sLZzfFIjGzyNEG2IMOK8J4/TaoRorYNNHjuD3T2xGCGdC1h9 LWrP3OLUwaXg
uDt853cOnj0/2IfL0NSuO0OMpHJnNE+RcxFchnDvFSWXGO6OfEiE4Qi9YiNz SAq02qFZVYDk
se6o+vgy7F/EYK0J6t+oEyZMtYt5jyVpEAJvvkLtO9QL6WcBEtTQ5KREtxGq Pma0ECagk7VT
a9NGunFCKcZKMi5Ag6EOvTIM23RhYNNlc90oJ0tGw+zYr0YMdN+2kQ8y8B9w HWfMP4U+/RuD
nefbIYQ6eSDW3DYNsfhTKlm61AUcEFZlNvG6PQcfndoZ932ig6MyBZWr9/Co FM0mWlFvecYA
j8OwTH10VS49fqcUZ2kwW56s68rILcwogyxDlMkc5yvT8kVah77oRGRK5O5p br5eLY4hojh3
1ZIEw3fENIZBF3+P3mmDawUV706vFYcKKrbpa5suwXnYIUSD88F5+7p7IWDT KziwqXDrzPHC
J3wTNgdQitCb9KmASdiNwbuDSJNM9Q528s1XaSuZ9EZR4Hl1g1Y/miL6j7uA NttNGk5nGwWQ
krtCeXsHjp0QNNRRlc2hMptqIfXShA7ZcVg5jGNmBvolXmvQvyXWOIFIULrY j5hkqC+Rbo3T
XC7PRcUDKuGrsyUNN+l6SFMG2rXZGgLJAoRJhxGnOw4X289oCC4FB98LU4gf 5DOWjOydVhcM
xh2hP/HJiv+5DO+0+P+k2MrM/mMajyf+f/V22n+kUNss9ucdMQNxGHGQabxu k+ORVFX4bRmK
ekU70s9bBOS4NHdTWmbofTj8irNUSGAk5aDO3HlRk0ClbhHk398n3hRTDiYM LCgEqBSaUNpE
0PTinZAgXL4QTkXlTUBpcAWuMnBybMUDIA+UTnkXHXl3U6/23VhRokz5x5MV KNQN2hEjlIai
MVQ5RJY94vh5StFTWpA1y87vmyxajOy2qiDeI9ijfkZVZ7s20QZOWN+oYZzs SgsulyIRaRIF
UyN4lCtQDgh4qQjwFcmLgwpvfSbqfa+eEXZkcgztL+VpA1I8bayt+eQ/eO4R EXGturG+vF6p
3luurqxtVO4Fa5MePDw/cPlv1PlXL6mPQfFZOP4r+Vg18v9WNzZWZvFfp/J4 7L83bp3876c2
t+Q/MwC/+aj/fSPAvrQAf9bo+s4EtzAaE5QP0Zu6tt2niEoJJcVKSoPc9HKH 4VnYCzvN7JJH
GAJ/0Gu0mVFdpjm2sBKudwqaFU8jUcGTBgT0vy5azUJsejUwLDbr1sk77dAn Tj/K4Sc45qGP
2AImlcDiGM54uBylXhRNtoCiMKYI5GdFAF9FnVZ89f55f/N5j89yAj9BTwz/ 7kCk/S8oGEKt
4hUs7R0KLnGdw0w+6AhahOcmEVpibk4EAJmTZy6y9fW5khj14FQv/Ds/J6zs PGFHL7OtuQ6L
Q2H1gl2Jz805sF2GcHLsuEEWP4sa1bsmoPhKKR+yd+X6/tHx9v5ODUszXTWf zxeH9cA2agv3
j07Il01H66Im/70FhUxr1AXRIzhxlZTWFjSgjGaDM/bvlgm+rLiCs8IiZ64K iPy8OiPVGSBm
YcC/siqwCqFiH4LemmVp5NJNHvb06szyJA3IVNECAMD7mdUmr8AsvxRga0q9 hN6NYFqGeUbl
80aBevKEzHAC2ZN7Iusa/E9wnrkI/rJGIb6XFICkK/i+FNBKItbxyIGOtVA5 ugbCFU5HC8Is
l1ChcLijhc7R+5graA7tdJ4rHDG0MyLEhGMc2U3Gk8438EknBxcJsv0F1Uzf GaVrX4L5y/HL
5xAj+sX+cb5aMtl4Vsn9g5Mnte3jF4e1k3rOAai5zPOVLTDew9rRwV5e6DJX eUbBF/t2USVJ
y32RemeOmVX7/RkYZUh5cG6uQf6kL4VIh9nTN3mQcw5UsVS0ZTpBW/anuQQ2 jJL9YeFMyIM8
o7uvPdFfGWEc+o1wxTcdHgU4hyF/5pptcDiAKsymAuJJhj0WdYtVoFv2HDNo 5IWF2eIcjcQ+
N3cWtZTv0lPEzunjG47AtBwOwTiORnxyjeatNvHYmWj4gPBjYppDhBdzpXVN CyxGkeSMJvb9
jnM+e9zPCBoZ9AvNowAeQv+7Qf6Z6X+n8Iw8/zsXYfPVafyGB8TaDZNmL+qC hWHe/K/LK2b8
/2qlujHT/07j8dh/VG6d/jcXtc2MQG6pEQjOnk/jq0ec0KJNZJdmBJFVK7nq l6+iFhF1WPLP
JPLpcF0x8W16w8FIBeK2jCPZEmVQVciP7K/BdTChpsPCRMPufn5jDP9aEAYZ jk/f3LdTfkUt
7SczOQF53ZQw/W1yDUTUWuQOTQoczYwDiqjfNlNO7aNmfk1NcCB7z7yH+Ac6 FaVMArIkcDmP
gROiqMmSozK8KNWYiwY3sDbJo6QmLmU+X1822lGL+twpTghwdKKW/olaRC9P 4TAlUMjXz+wo
8IN5Rt6RU+OiUhEw6/5/vbpmyn/ra5WZ/DeNxyP/Ld9S+S+b2twi4OpMBLx1 IqC0BtiJ223T
7tcZLc5jR2C9/jJspoSXG+o6HzWcmaV2G/0GXByMzTrAdedfNI+TJrQOnQRq FEk5Z13wUPRI
2jeV/UlmUILVBVmIOi3qiYvh51FQJYvWCCKvJXWS4dQQopHS6QOWIgnsxIPm oAfSXfuaMGLy
HyIu00gQTKCGNc6PE3APlcgsTK04TDof9HkVZFyAcCJGJsDYFSxDQ3gAiTrg ycszPlFPwmdP
KL+X9wQAXdA1RQVwoBiuSbGOIs4HNAoAskcorbRQ1NQ8ldOr9g5mmPhv0D6a BofzxAXedBTx
WAvQyyR39hgjBryvNX41AUy7zN9tKX2Zgk2EZQMRFDSAGN+hi2LrAXPAhK2K BdUxz1Iy64RR
ULuUV6Z0En202VFi99TBaX/n54GvNu0+39Xm0Dtmbo5uMHPsgk1EoVYv1uQ2 OSd1DAk7KtIt
j5UM8HQIVEbA4Y02kWnEkrbCtBD6gAAtpUAN0CIvIuUdp+OqUI3Mwm/XBLvg F+z8ik/WU27X
8a4SS0QJXP7JqzzIS4WBw4GzndJADEAH9KuCA2bOAplrbMVEUCdcG1zR+zFd NyXXlWMAcaDm
9Me4ugxEEmXjZhKzEZFidXYzySYNPMppi/yykA/M2XX37nez3We7Ta7+p+iG hh9DxiDEFS53
sHEuxQW1v/14u9drXNM+u1fuN2+HuNctyFAoL8s0+JFMUK8otG1sThzWAtKG weQmuBStCnKW
uo1eEtbB3ItZBC5ELYF4aSUBQgbE2FMa+IJsHeKiXlMusbJMPxV8yl88Cubn J4LrKBEvwn4R
yyq1monmKRhVZY2NDA2Fu4KExBzFrIrDjHAS05U5osUg3xj9I1zkqwlV8VNf OALYkbJIFmln
FH4zXbXryBoZDMGL6iPwHWSmnboTUMb979rKxoah/1teX5/5/0zluWP6Py+1 udV+azO13y1W
+2U4AeXRlGkZEQy6yK83Khrg/7KIdgmv/AgJFPGoAWf4vGX34rhbBHahsr1G JxEqnKn797jV
cFL1g6tIn3TQbImAXPzbMZHtUO0FWi6aG/in8g6+9uyJIuhQ74SIqrjoHa6S dpLbnib5FVku
lqVlOzA+qformmaTmmtyBbTiv+MCXbIraQoo9f2WCfotBZ9TrEtbfA9o1GQq cKXpdpRCtJc/
VO8gea6CAwQ7WLGAdOwzHtbljPEEyAEsaXFE54d0AcPrNfSWSqVcC+AArPKu vA2odXI3xJlY
3kZ4+dwN6JwsN7K0WkXQhpJ+fozRjKF5weN2lRs6i5qXEzhsPXlBQ1kVsHbU L3zwzWIndHFQ
xaGfn6ilHN5bKqubGbiMdP5jkQuzLcCL23+vVtfWZ/bf03jGMP/Ah2nQIHf6 x8zz//pyxYz/
UV2e5X+cynNn8j96qM2T/nFm8n3jB382Yb4TPgv9txO3415GlkRWNEc2SFrk RT9qR6BkTi9L
RPC9xnU88EQQzE4wKUoAkNScirxk1Ak/j3utjGLnYXwZwlljNyJyYeINY2IW PySCT6Nz3taP
zrkOqXJVCdtxiAXAXqlHUhYzQnQtSKJfcisJWgSjFtBY7UR0BIsQ+oPeU4uP pWAe/maBBNjN
EuuU7A4X4ugto4Al6pD3uzTVEw0YQKVR+ZZlpxABBOzLArxX1HJwsCZFa2BA DZezJfZZSrYy
CSHHBobrexO2jghWeN9B1AYs8QjjQqymLwODauGMSLtTg6noE6F8/qt582oU W4o7eFG/KaCV
L0JkcltBlUw9BSwj7WOep6P6bi34MFjxfn++vVPf/4IUqZL/VTYDCZzGkvzp VlBZ3jTffpjR
pKtCxTo6MGIqqIjQ88XSW1bw/u2xeYg6/UWw3bKODdq8WXWCq6e8ZnABf+oH Cn2qBVFohCFX
F6VbvriUhTWHX+bm2ozRzDH3DMUhI6E/oePqCqHLiOeB40TVVhYbW2gJJxFc RW2xguiUkDNT
t0GOXVroDnj9OWHz5z04yyOXhnOtyqzLZJ/qa+WRtdGLdcnqSoQuBI3ifyTn JX3Bf2hv5Xuu
E6GfYf09a/xe3NtuR+cdGodEli1v79W/2D/Zqe0f1w6V3mhsucRbEqdVimiL vEamL2OehqOw
OVGNUJJShyZeeo4uIPQ2UhLfnF6UrbKHuZYlO+QjWWtQVGyZTubIERn19cmP QKNAyTTpN7HU
C+kEtH39QZsRh/Pe9zX1ahFcV5t/SWjnJmXQnklKQyT1GlGnr2w4i0igYoMt +RG6GCwvBg8r
8D9G9ve541NZdvHWaCDGIJFzXZz3DJh1/qusVcz73+WVmf/vVB73+W/l9t3/ plDbzOXjTh8B
c5yICpwS+fVDDqhPyLzmOY/Vc5w8cx7tjqN+O/y80StyCqwT0ugnxc90+kpR grTL+xnH+Y7X
oj0M2trPTS6We4K46006grejpKHD5KKq9lINTE67+7zRgVTfZUXONOCo5zJd VPkKrJtlBiku
tFxpr7n4okNlEgGvaVaxj4I67lnXhNgvKY42JrwQNLisxJXj5aZaS6emoI8/ ZTFFaDOxS1sX
1rPOxIi0rDBYn1PA87O81j4XQ5VyXAjMcX5wDZY140IOaYyJrfgfjgHuN60x AXPa6NtF85yi
H1KiTkd0wASnjHAx4LLtHJEfJTVLsFXlgswhRrMjmsjm7cB2WRZLgnRoNpFL iC4kKKDnA5an
tTRPzv2lUiJsdd9/P0i0XL0LwacE7qNgHi1c5xdI+fmFeV3Gn7PWhJPG+cow SPkbZWzu6ecq
FOQtsu/Yo4X54Q6xAqsFD4Y8FyliMmRk8oAIPs1BG0NcAgMv+XcW7dwoliKt FphgWB2WbY7j
gRUWF7UsbalRl9XZvC8vdcnEnkEF9qsfd7Wvp3G/H1+S7w8r2vseUzPx1+oJ Ut7/cmK4+XPO
7HE/Y5DIZTZFzwkw4/xXra6tmOc/+Gd2/pvC47n/++jWnv+c1OY+Aa7MToA3 ngJAPQIWPL+Y
My2jGslX6smFefBAWFGIRM3sXFPPK2YT9okFf8GR4w0TH5yKv4MXx89fHJ9A DuPt/S/2IEjv
3gFXRkP6014vvsoB4PiwbtXn+lI9ZNOpUweawJUEH3xJ+DSdchlQYoZs3aeu 4SklPnV39Ul9
v370lPXw0Qj4+JIs1FPQpb6nNMp9xrqogL0pr5gfzjMGjmwrFAr5/1SW16pm /MfljcrM/2cq
z52z//FQm8cOqDITAe6GEnjMdkA5NbtPemEI5t17jev8JbMshnhRyDXejX0J SllhlvsxfcTZ
3Ru7DdJRsxe326B0TS8GqdFz4GQYvfdYrJ+OL7imBGPycO6BOU6SgiFpHJrz dGOpOU15DctE
+aWrFql62zSJ4lElrYbdgiqad2itLA5/bT0nYBYxsFJEVSavcvP7C4h52aHT QINYAvNsXkTt
FpuhxLpOALqnFg8d05xfG2ZZlFG7cRtth8AWDD8Fj4Pl4Fe/oh/xh3S2wAHC zIk2SkEFfHLJ
f1RVJTeaQl2f1QvWA9q6Yp6Uhpk8nLwsif0Bt5+TrvnM7913PMHSirEdG7Q+ m6a93dytNRtZ
WnIbjuiLcDLGI9rJli0zc4g6A7Kv0/xLynH05EmrlVI8S7XCYmGh092DrncM eNykiULQ4ZIC
Swan3DdOW/5yBEIRrnNfOhSXIZ24wkS20aV7Vz5zOh0tpkmd3AyDBP/EgVEG Lr8JMyz5UZMv
1O9ly0DNKI4E6zNmw3blzisLis5hzF8mf2igxUt3HRAB0eQUXihGg7LUuO0G RSXFeFDd74zL
OfPiy7lFCFM2TgIzez/d3k+vyWyGH26lGAwvBdVJmAqWSoqoDmnP+XQvKDeT igGhrhny3zXa
FJR2B5/j8lsXYCd8F35fvYA2b/Vz3DMXyJSn75SIWyZhphxWlJ1Ux51anxcO znktikqxDwa9
JgSoM+W4z+EXi7UDp3UyBTiwPvjiwl3mccwWRK/JtIXNsvhYWl9c5yxqaSmA juOOlFwQLFzB
W96dcg5O1YaFQQZyzWZG1D2L2m1lQycjuaOqyjFoZKQ4OJT/3wqk+zb9/yob M/vPqTxEOBrr
wxRJXMkGKrcqmWSqThQ6t5jmu0XlVUyWZy8p3zIN3C1RwMFjIu1hEDFt3Pbz Om2eRxMRWtjx
PiOo+mS0n1pncMnyHG86Pj9tJBcY3NP1MS0EeHqs72EMSMnGi1FWtzvNC1/4 6vy6yGwHwmeN
3nnUyaEa+/plDlXbsPqz53HUyQlZV7XlCu7zBHRFRRKQF85YLu9yLQUgPbjK fYqfWkVcb+AF
p5AulL5Ro3czmib8qAssCbVWCJiHcQGwCRHp4aQbJ/y82+gEF43XYUDjd19F RDRvCsLC2ELI
94IO1FZiY28nCVkmLE0Q9EH2OqEQG4HAJS7+hExKQNbWKYFG2BpNmIyMFRGC ULEXBbWdikqT
SDb6efv+T9SL99qbZtiFccmL9Lkz0UcqqDrKcLWllCEFD1BwRRchj3IsSpQ2 UOCSdSkboMM3
l7ARI7m6WHVXphjLWVvT0Epk8RMDjNOENNfgHIXK+Hw9z2lucPxtSVyXp7my FTxvK6d2NJVU
groScZkc9ZHoBYWhrhc7zTrnGhaA4rMt1MP2Szi94tWghWCej5y1xE17LSIo Y0pw0bny/vaz
2slu7cn2i73jRVnboR7bJgOD4K64OLp86RBGwmrdl+YhXEsEpUBbSWSHiOCL 6iLJusUzL/yB
Gm2KI1utKDOYs2OvAMfjf3c0yxOaHV1ZMMb3koJYWZSfdFyzEuSYNx0SThHN BzviFPHBZkwK
LPPXIRGsIIEvizALvBeZImWBjOUlEZ4Y5fzRcG5k+pIkOu+ElGxb9EoCp8o3 K/plhnAuZ5Ml
sK7RVipNUaYxLaJi1y0mVYmca03TncGyoorFC0YathGUJDWl8Ki0ZoAaHz/I R2yHREAFUkqb
sMXgPCL0KCZBEtI4Z7GHPfFMZJCyfUgsl1yfF2z8QLA6BTSiHaPtU0DvGfEI bAC0rxaM9Lnj
lYzpm9PfQ+cOrjqGbte4cijOIpTZHZVH8KtNwST4nMkVY2xBng+BmyRBNG3S 2G8ygQwR4Rqa
bBnQEyekVyFDaJDhEAqLiXAaddnZmKGF/IXBLwn9Qe6XiIz/OQwd5FVorkEn myDvl2Evfkgd
OoKE+UJFcPSmawSPyawJB/XzLveV7pM2Sdvs/od0BKbng0SH4rgN5JHvJPe6 VDOm0JgJAOQ4
6qrREDkd8/KKpwp7pfmrSKcaCUpGRxCNbqplysadhHpIKwUrgXUhAepdWrUk uuwy4DwKG73m
RchOGR3gB6BMp4cQtmTiDkUju1ZDMscAqOSAkfQ5h+nxDPeE2vESGU81XXa6 0TmWq8J964I+
d/OOprRbR4NxmYxlu1/C42bQ5QkwrRqsLWXS2zGoeqIOebdH/iw/2/765Mvt vRc1Jo3PKRqG
gF2d+JkUi8bOc6ug91BQCiH/ybO4F9bEZ047dheBEVtMOAgxHwqrz+8B2Gir oPAGxrcXUy1r
CZN10jI4vhYp0YUSuxGNNFstdasiT0pQagWPAQciEwfFR4sWmJNYa9I3MkkG Q4hfvPuhIYRf
etMSLv7MF2ajwxcGFQ9AYMiSDFAkYFpGVRp0rDZUDsBvrMNWFoOTd4E55rRk SBb6Xb89T7mk
Bx+KRPfZkJNu2IzOItiwfKJwU8MBqk4QQgS6FowCGrZsnNmN6G0oSGLjd6AG jVBs8l34xuIi
5G+8ozJR8yq85guFNUPeaOuG1HQsHUqkpCwsFWYqg0UdSwSo2z0ppP4CD9ja XKC5fvnE8n6o
NM5ZaNrsscR1skE+Nfk2n2F2Gw7R0WbhHcbL62dbzW3mrEzJ6iO+RIgiIFAy eUQnpEbwminv
znKAEwKqAkohK6YHTJtNjYt6FIZZa42GIr6RteZvepgl55YmprbkZsLM8EvO RwhDLjk/uNxL
zjub2pJzK/gd56zD4UUTsRoVHlJYUqHlP0icmgYpm4As8oSsGaYl8+l8jKyR AU3u6JJLILuU
ld9RsbgVB+i0nI84PimiuJI8Sj2SiB3vESFZUE0lsSOXS3h33Mn8FLHFO7FU zxDy2yWqtivh
nRzaATTwPg2VIphSF5VFcSeEFCGkTHTeWSjbc6fDMyfPcZeFWUrV1wbVninX n3I8jOrYfY5U
48Svw95VL+r3QRdJKK/Xa3TOqV7GvN5jF4yNHvVqgL63zkNh4KCsYcu63mn+ rBDYppN1M48W
sE/rB9eLwRtJEm8CHtLzOvDZEtLgoptUg9PPYuMFspR2qULbZtku2rWtuU0D btQfSg2lZcL9
ZhEGrztMKMFZadDUawhymhaENRVH2pJ4w4RMNP/ktp4psB8ONRN+GXYCMwEM xECzyK9DyNe1
ythRB6zJo84gvGMzGuhTmt1lwTVcnZXUwO13U8khrWN6bGEDBfA/jweCypUd eno1R7i8eGVK
RaH1UBXyi07dPjJuzKTekcURos25oYkPfLKGcacKvVOvA1W+bRZlRG3vcNyz 4Wfhtf/6MPg0
KJUMkAsunY0XgkK5C8EjXRPOrbHN7SXPxKiXYWOaGW53UmhqrGtKOTfyU8l3 p5lvdny3M3R6
TKDu+fHCKDZBmmjeJEK0vLfhEjUTbeTKQashdhNExNAQ7YeUkualUQNitff6 6OoY4OTpJ8co
OaLfwXsjUuQFo65TbkggRjkpoQea4CB95z7F/kWXZMclBcgb0lxygL0orbtJ ZMrKUMUQ1SvL
2zGdNPSHNp9YGCufkVVwkTqfrsghAugwMzoWaSL/jCoHknFIFA6O4CYOFW8S XzZ5DOGPMUhC
0CW0d+K414o6ZO9NVDdGYb/Gp8tZXs+C1RsoKalzpkIYNRr/M4KTy8FlAX9a o8YI3rTwWzHk
e9boX5QvG29KHkVCOUGZatGn2mPfpTuSy1d3fXVRtkmQNqzAuJAlUKb4AqsY dHsC31IPaZld
IXsIb2/afeLOP2Pw/3HZImmeQBnx/1Yg2I8e/6dSXV2Z+f9M4/Hk/165tfF/ vNQ2iwJ/F2IA
+r1LeBDdQv43eUKzD+PhQnarJtLQ0F4xhUIdOq09ucuFDzGwXd5PCW7oNMN1 hGRfWgqOD3YP
gm0y70oi7CYqogZ4O5P0B6e2ZoEdPGKQhXM1zkMXYw2tJ/TNsKKJ2dAD9Q4u kyIsuYVe56kw
6BtyQF1mveYCd9zZC8/64qDPUfkoSK6iPlm7bQYBznoYaJkgk3KfVtglswvs g3wVxQhjYDcO
ip80jZZDz1Ts4FE2wgJwp2nsCbuOxM97NLozmmVrNF1iBaD2cdyFckKs9bSj eGATmozbg35Y
UpuR+kLFx9vqtqOrbX8nexn9c/aprfeGThIX/hunidrr8pvgIVYgfyyQk0Nl eROm8WzQImyN
pjuWHZV5uR1dZc18Svr8hlAA/PdD8l/U1S+SP67xJ1PWLkFWrFyDYW3K4biz LA/pdT6GHdlQ
odhO4Fnxn1cqVv6f6mp1Jv9N47lz8Z9d1OYW/dZmot+tEv2kTMTEAO6tgEE6 FMVofrnJvKXJ
GSE64epczGjfTsLN++lxoi1nPEuKwp+ZcaLr+6OFiab1PVGi88eIdmjuRYho FTfOCNGygCdA
9NHxNvlvanzoPHiQ4aFli7Po0ON+xsCRzRkuuv+vVDbs/X9tFv9lKs+d2/9d 1Dbb/+/C/j9a
dJbkihxVefgtrKCpWfggKAg0VmDmDC1+C5EsBmG/WaZiR0RtEiQN5xc6DAr0 q2GY1GGUL4k7
Nbkxs6TqZ1Gn0YYbq7m57cPDg6/oHdFWUNnYdJfFy5M5eZ1Eiq5xWWYpUN/D jcsCnn/RUrAU
KA38lB6MmzE5GK8sy8CjrgYR83N+YWTLGXzC130FmjsDhgXutE3ILge42tc7 tefH9YP9TIiE
nTGUZYBU5RoLynkvDDs5+qVlzyjYFyQM7f5vS53GJZawPf/cmQLY0Nj25Pvw EsNMXrstzxh2
5GPQWkFsWaznyAKSIf9VVqrm/V+VvJvJf9N47lz+j1Rq82QBmQmCtykJSKGb Md90ezIvzLaW
gs84MvJcxIRqUyLApvP/amV51Yr/ujqL/zqd586d/y1q8/D82en/Vp7+9YCv zxrdzYLhXmmV
WxrrNWc2p6yAsGPP5pQ7wuyzmPC52usww+YFi+0RagRrkdSSz+MEw9Hlm4/b EuBWXO2rNj0F
TYA8Oqyjr45zKLiexL6uQrGrqHUekuP0LvUeKC5VqUw0I4cVK/t53LoOTsl/ xCoQBciKlGEH
kbjVaK3ka2lBLa7pEGCcwc7B/m4ddTVPDvaPgy2448GcJeRjiY0RswEMetQS ZTGY3wa+O78Y
kI2KYLS8f3D4bHtPa2eHdwnu7Q6pnzYnWbxnNN5pehMVQd5cW468WBJDPL+X wJ4SVlGWuvXW
2BCVwG1hn5quinpVfLzOPAtLGdb0HwZV5ogx99Nghf21FFTFO68F/YjZsMzI f4JoGm0W7E/x
hrCDbFqhAWkx+Z0RCw1kpy8SLQidVgPdUZSSSig6KxJddcFXA1ePvrR8RSEt yXY7Ou9gUAuL
ZZcP61889VbGP9Jq79WeHHNEGHyi7MAZfjFXE8YDdRSxJ5HGMPTOozl1WjDO 2bz55o2O/Awu
EijyTY6PkR5SsSGCiRqllElmBc48U+tPH6fA4IXw67DcdfKJ45xp45DdybFQ 5ql7fudJHbfA
Z83rtq3eV73owseERzth0YPbOOHsloxuYuxCjYfL0APe6S974WuxArUvZDD6 BxOrA+yNKIMo
MWMdq+/UltQPakML7IqOUXGbreI0ShZB89hkKQuupIFmBimprvEcK66wTAbC G30jRk3Xij5C
B3HOF7CItdT3hYjRBkc6OggdLpgKavC3mqWJURMLoqR6aXIZwESp6plJhYSm aTQrSZpiV7EM
5hGT8L3LJpYnfkLppNcUXt4lggQzxowckggyowgLnhAz3myKKSIlSBz2a8P9 0i13egimzUr4
zLhczaV2kQNkfXJ0hsxS2+qXkVpNngdcSRhFB75oX3cvNJnq80G/H3dE4lu1 nEaFwLrtrZbT
kiahU8GaTbm+3Sqp0VITKcp0C7IUS5EAzrLsJcgf9ljYR9HhQvuqWbHAbo7d EZXFKltaErMH
dpVR53X8KhSxF8ypvrpgoc7nIe2DYBTzwTnOHIahi5qvMLYVtmgMHmQyTRFA pRztjViNKule
QhHCCJIkbJWkxiEQ2zlb2a5Os0jPsqCLiqFnCv1zB3HGAQQPcPTqMGyHDX+3 /BV3Y/Im3KEI
89eG/4oji0LNGfKNTShSvhkxuSU1pcxI9mckuZS5/rxZ/rQ0e7AUj/rXbZkU sLxX36+d7G4f
PRXES4UVClUAc6Bq1Aybwa3OsKkeqb3pNWVGW7KbNtrNAeyPXJ5gwmSiRufT smwHSYwhXB79
LgPyeND+hP/Zjj4RAfOYSNJpubh4ctHo8VDx3WC+F1/Nc+0281c6Y7mWCEgD epsqic5YODHG
ewAoUj6N3NZlDJAIQSBLqGkVUFi9pmAeK+CXxEAsajWl9TnzPEinLV148kXX Kyj7W8IWjaVG
KiwrP5813uhv4rMzspY4jWRGj6I8x545ppLRjxWMP1orSoYaq6wtykLCMW4B vZoq/NND5S++
nebsqOBwzv6tLgbVRXvBK937SDv5pAmr8lyqRDgMjGAivkgndFYtz0bjTCt8 8IAKrKghVpZT
sloUzaItTuc4a8/NUfKg2lNQuaUFAxMiN2wloiuUS3FF3JxI+YtB5Lp9nGrW Sno8MVYN9vDr
4BMkZblhM8K+3lQ3xZTzMEMHJywn3Ro0+Ya/nvvQDJonvjwMqsvKDzdGqO8e L3Yt/pJ0rhD6
W20j00+ErtwmPJ26KgfzzHQNLfcCSmpMGAv4iRozdjQ5h3dIQbAJtvB+FbIu X7CjJdxjUwAy
fCktENLUx8wNtaFL6Y12GfOVsG5F/SRsn1E4rTiEYLE8EUvnOjgbdJq0UtS/ Dk7DawKFygvQ
Eq0bXMRX4WuCqPtq/FX98kJPB6/nd9ZOGc5s8MaZjZ0z5FnBEvLHImekqMNT Q7l8SBhcvmKj
SH3F8zyLzbR4pmdVpGNFVcGOz8OTuBeq6esMm9FWo/cKUjCzVWakjzZYae1N l8grRAJ/SLaL
hzy0simLfgXLumR9hdFL1iKUDO7aFVdt+Mwmu9csv1kUf6Lvb1Nx/pWf3tBP KqtxVcjRnAJI
b+La3ZpRSG1RY1ozk6rv71NeKi99BgHXCS29mlAbzM7X9+9yZXVN/I3vK5W1 9bV7wd6E+qM9
3P4L7JPSymV9v6PPOCyyUlSOnozws+e2PFOY/0z7/3Xb/n99bRb/ayqP2/5z pXJ77T+zuI3b
HrQ6Mwe9Veag3FxtO0giJKMIdCBnjWbIAk33ozNGG8FZL75UcrFjPaYNrBFa eA5RcaESPb6S
iaBnV2Y6F7TCdtingZbCPCZysiepl2loI6dbD1l3DrZhilrEzv26OXVhewwr 0hFWV9/2s+L/
LK9WzfiPleWZ/9dUnjtn/++jNjfbX5mx/VvF9iXjV5SJwLtBnQHI1DPvJGVC jkkfbkYTniIZ
8BDTJJxKmB9UNaFukG8PPMMBIYYB6Th6/Z9hWEWtBTn8XJbTrhji7qhD91Pi CTmguCIz4m+M
vSOC4WC4Il+kHIz8nj+akNdHfhZY5wfzjCkib4r3X+b+v2ad/6ob1ZXV2f4/ jefO7f+z0H93
cNsfi7PeuPzvhvUfq3dADMlXFq//4aiYr3gOv7GU2EfPe/HrqMVMuE8bhJjw SA1mhOwADeYL
ykUxtwQqFxR+HDKPP8pikFzEV0R0CbZE0hFXCZRSHGVwmKTkmydRu01/pMQW 0io1AKSoBt/T
ZLFcIhi7KzbFr8/JQlCvLp0dVMSp/CEaFZlPhGjk3RN4PWXW52Y4RAcwtX9B MxB+Exp6mznh
aVKnq3t8UvN2UBVVjS7qk5nWyeEc6HLZP9pT5L7/VglIv/d2xcY+xYtr/RJb FDsvO67GnfGZ
eLguzIbDiYNfwS8t0fCq8YDsQWAuSNumd8llFwlrNKElzSQsvd1WkhCaZkzk fNYNWyVUvlFm
WVperJD/W16QCRVF/bleyvW9yMOIJjncBaBVQh8XnnuH345/yNOOki7qd/hB L9CsJTiGKH2a
OEJSuwgbrRTsGOTIuiLY/Vy3z51fxTthTEomDJWEGC2cTr4rurm74BtvLiB0 /mGlrh2ljBBh
qY2kApIWZEVHREnnedy+Pof8SICkBXXG4EsbjBnYp7m5wDSauo3Ose7sTymz lDI1nJHdHf0v
+XhJVmuylNXG8vLq8sbamu/8h3f+5Ii4Vt1YX16vVMn5b3W1snIvWJsGAn7g 579xzP8uXLCE
cKwhEucOfauqArLi/y5XlPg/q+ug/1+prs/O/9N47PP/9uA8uH3h37KJbRb7 7bZqAvjc+VQB
pJwoU2ZTqpZ1Ar9i6VHLjBQ2cxbnaVW1E3Su06+L8sQ5mP9WD8JapBN217tb 26sd1052nu0S
MXGeggwYzHn9KIvvYDRseOITiCERoag36ks+ruBKHaD/2OsajX4AVvuquY6r 56DwTdgcSLca
0pvLGn+lHPcM42G1FIszAuMhKBHzhF4W2Dn0VobPB0R6Z+hg4qOnNIsjoBd2 hYpoxekdt0+q
fFpKxvwwMLA+y7zZLXXynOdePmkla/ZUePydgh43RMJmxIA8qAHHUUo8ixZ6 Zpc9P7xnHFsy
FR6Gl/9Wl1dm8t8NPXcm/m82tc0M/yYnAI5T3EvPmzk1mW87YB2l1yMtzMXI d0owIGkImQrL
F0hL5SJRssVyWTFL9r3/kwwpck42QIqf8FgZ8652nUIl+MBaYqVUTINmq9l3 SpdEUkLvbnar
wp3sHA07blPeapVc8iMGdCFtm3EeWHdBJfs1Fii/YQpE5ctL+uVaiQmHop3I c2nIQVx0s7sm
hqvEBtDjuAgkOMakypXjHlD6iCyRzuyalGBL5gkjyCPCOuBxv9ugpLjmCWw1 AUbPX5thVyC8
E17RV1wu57lPxQcPLFX2deJHRB/TJv2HLvOOb0fmUwhhRHUhMEP+W11fXjPk v+rKWmUm/03j
IbvhWB8mRnARCwQuIkguU3FSSFxxj7IM2H1jIgj1mCnC7ZG/bon4BY+JtIfk /E51cdvP67R5
zdwDKo73uUWSnyLKFSoPXEkT/1j0BR/r4oEYYGY1QVE4maiVEOIl+aMdxKe/ R0aV8LA5LLTC
JRUo2W7Gq5aDZ3HS58Qo9kAEhCAFMLRwPkXpMkTqVVuHi8lme4BtQYaMZBEI uwvXsfwnBktb
ZMuD9GwvjrvsG0YDCqOejP5AxnxBCrXJeZAszbAcFDQT8iJ1ejKwo/F5lzwL 34M5DI80kiis
qmbnpDbzYcUlJzs65xeWc958u3D4QAjXThOWvKI3IMclp/L3upSKcN7DN1FS u+z2r9XIO7zO
U7TcoBVlhBY19oBSmAZcMMpiBAMZeUWR95eWwH0slCFP6MIkizFRI0hRB7IO EACGOYV4d412
W5EfSQ2YohJ2RFjmTP2kcJfwP+dDX+qJBAqU9DVJxH38l3Wdwtjir+/iaYSe PwyCuvETyFjk
f9xdhLOkpQFOl/8r1RVL/q+sr878/6by3Bn/7zzU5tYAfzTTAE/MBIB8/RIs NnsX4XUrvE1W
AUgleU8JVroAMArXjgvgrsiODE764+cFKgGLA5lyekAwUtW8CGJJdHaNf6pe 6pQqHP1hgkt8
Rj0cZVx29eBRfnza++TxEvmPnNNjNbQboRMywefnRLBvLSqR5aiDfErrEkIz 7pSDeidg/UDB
KYFTSB+gw9YHRLgYnIbNBmGb0u0gogIYQVEfnPFBBsOYcach6QVBC1lrju7v kMPIOXXrFz1j
sUmZEBeCmMOChzI/+yQDj1TfUO/Y/YdIdu4xNOMe4QldgIlXBU4sgSU8RsGD AdJDHF3pEJnZ
Nbw6BM5LKA5aYTNqIV4uG68gyp6nNwQkWn4D6OgypHqUMywYXBDuRSG3w9dA F2dAgYQe30T9
a5w3DIqNAaI5mZKW6GKnoWADGqr1Z2HYJcTCG+KziNyGEKKIQFlmMV6d1aAk D+XK8wkAKuAb
TkRaZZzc1nkIx1SyTeP6ENEgZO0gpTqpBp7AmKRHrqJFGD6RB2kcz4DIzJ0w RPrTesM8awjl
XYbk3NvCU3yrpVKiRVkQw78RnEevw44cOEJURg+r/zXSNHPLQS0YLArC2+Mr DaVLfE7sE/hi
YHJf53ncybHcpkueHOPbO+gnvL27y2PSZpR8drBbf/IyYJb5GYWpoREpXBVG S5LcTkPcYIFZ
QkIEPMb6sa8DYAwST4KM+TARXiVoCpIWbfJ9Q4Ei48ViSUfkYFY4IcwMIql3 rwX8HhFE4oGy
WBZxD8CVqkKL2zJOrwTId39snHaFzhUG/+wTHkG4VqjMzqKOf9xZdCRjo4B7 ClW2dRy2ifgS
nWntKPyc1uTePoTPvYAxSMet+4qxGQwbsMzmnYgvYSKO3Oj5FBIpqA0vacTq QZMIHKaWwk23
7nRc7NZKBvZ1kkh5t/Zk+8UeZHFn+XWkIZXpmiWB6TRAt5mcffVkHaJ9t9IN WYPQolMb3Txi
8Q0YdQBVKTN3X42qSgdECzpVQeCChV9LkjLU60DWxpYkGl9vcEHRoLVAoqeh WLlaX6CYrycw
USX/Clf7ha1t8YVv9olmUblWOcHVRZywTvL+odwhJDCjn5Qd+HpKgZY01qHd otIPW5KrmF0s
0NgLtg5LxhLUGhSrkv2lNjm8HpEAq/lUiUpvDJNOnuaG8Qehz2RDd/IbJj4B z+kYmYbc2DGQ
YbQ9ViwU0qbyn3TBGCnhTCpoBBdhm3AEIWXA+sGwymyBQwATOKywACYIepFu IoA1UCNquIq7
bOuAiCkNdkhsEXmf0jhuC/T4YbE8OTim0tZGh3Hou1oiPM7SrqI+abAUd4Xi EjyRFcHhEVUr
gn5S8jiu7KTfQHe7jS8IKhodqcKVFRptcg7B3DMQiKsl6wEiiLR8Af0Cia+F 4b741+OLQSI+
k40IcMe+Qoewya0tmnNELNiyGj0fO70gdal6HHmeSGhuToQ0PyUdfcU4u4YM JhsxfJDOUakV
pMB2Sx0qTi2mYoj6tLAqJjDGR80ceCe58ha/JOoX7P5mRteYkCC7dhhyQTVF 5F0Uhy4uzqLQ
LoBwMRuOHHDyotplxLAnXR/uAcjtjR4P4RToXMxU8+5cyapSPt8yHr4bVE/s 7IaqQuaLS9uZ
h1pgfEDafJvjyk+8NpmpFFqQ3Iy+oTjr7dgsOvVYnvG6ZBmG3+zJsP/ZII+h /19ers7i/0zl
ucP+f+la/1nkv9vp+AczViYjaJe3e73GtR4jR37kiZhc31idyfgSCrOZvHcH NSLq5C0rtJB5
K2i3EdM1kCroEzk2Z0joiN9WxzLVEXf1bmMc3RKHfwEKChJkVDKVEw/cIehS z1uPdag2uVid
JvcpcBW1lAFOF82cvpn6ma3Fqou+lnQLC/IfnroYuwmYJShE2UrJg4a/gchR qGdS2H0WTIWZ
z0A4i2ZImJu6gALNgoVAhoxWJbXEAvYBjUoGp5wiaSQY6CIPhzMHp148ekao fSb/PBbdZSnk
ycsPP2RCrj1wbeQLoirk0YoWZMwdNB0KQ1TzUyDIrXnPPkjEXLLSLdWJNikF 9ugCxXYfkYbW
I+QDNI7sAFDrSMiLCcxKgZrATCAUJgKQCVUXjMRl+B+LtKl3AJAf1KkRbn9d wvmUgXnoSQw+
8y8pPad8aRJdt1bYaF3ntjnqwlCLC8LmPYS/kSIRhSwsERsn9ytW2uDFj7Hb qcXZCHmNrzR6
9zfhGoFJd9qyazrWIKdbQCYRdkpaIecClJ4TgVwgZnrE3DAMErFdl8flR26v /UCxPxOGmdJD
hDEa4WGuGPvZhluBbsuWojjwDkCjw4RgROusncNb4B5Rbi/sAmtPrJ8gxP+y ZYivFqyU3Vim
zFQ3OhaRJ9hdabbDhho3D3tsr+cb67HdFaXHTv98tEwM9H2zaZgkNr21TWvC rmlF2HVXdRgP
cltKbVAu+nFwDBa4WqCS06c3bIT8Km/NI/hL+6boAGP8U8w7D3It2bXFZUV4 AoIFmyFSro5N
Kt85i6VfaZvKZ86w9V1L6UsgKMMnB6FIg81yzkCmYYsq0ETPRb+0XVytBzmc xd70VgCmPU6D
LMakb7NaVRM42wDxukMI9WykxzGvuki7p2+MoDkbi0WeIEC3Dihd/1OtVNdN ///ljeVZ/p+p
PHfQ/99JbZ7oT7PwT+Py/p+wpSdP5LPpLXFICCi71PC6n++rHqcujPyA5qTN G5Xf+M37ovKF
mcwBZSGEplhx1AhUVCrbNoP1M2ZG2UhpSmkgbreO2S/I+U7t7Vq6FV4umOw3 g3nEfuWB6R2e
BrRfoJcKRKZGyIAIYoBq8cf/+grMc0EcRCvhThwkV40utIEM5jTsX4HVqBud 5JcLJ46Y3651
rdkPmhy3sKLPgiD99fh8ghinqf3ywdkNk2YvovlcMPX5fKiIejinivsfyoRL Swocya7RrrTR
YQITWnp2mNTErJXk6VORfSmON7XPUmymU6N/1aRPWp37NHkKUSi8EB3CQbtl E5Ovk2L2ff0U
dJPSCwEko7cClt7hI7ISsDAK7GD2zIx9qKksMw7khkCELGm1JpNMTq91w0RM Il7WeqEqKXXN
KhVvEmrEoFOQqXS1CuiKVw8lj8kcYDhDK7jwlzyPnyref1/hBlu6TyHBaz2L +wGPUB5e78hi
YJeQoekUrOpYgncylUl8GYoqBGxbbQcLsmNRUEq0bjMVLjvQYLj9TVG0rw/G VxSMiPAg3Y7j
Loi0DTxQGS3qBzEKWr5zA+fgdxodMMznvKvBcg2eBc1BD8/24nhL3b7hK69L SjXAmZsXQWOs
qAPXa2H72ttJ/YRMe/ee3W+9WPooKJJa8QDERmV+hIV9AqZHbH5gfXIeIyNf M7Mp1lnCq1uw
CMm5k5ZVDuO2NeCIa6WQOZ5C8GJHNncIvpQSax31nYtIbqm2/ha4EFdU8EWY WewodcpTq781
BumTkwKbX7wnx5lobxRmccxMugB40gfD2XbUeUUvSpjdGoUmyNfUyphA8+jZ Fey85T3Zj2Hm
+o2ogyItdEPIQdhD3Bxw18ZthG7mbAOnY7miPhzM1pLf9xAGBu7fzKIQe5eI 3lHEsL4k1qTD
DUWeuWB0ZNCb5NLvWSTnngr20T8Zx3KlqpPBNWjeyUi5xbgFk8F6p7KWub61 tKzJMKbDu+EN
sZViFywVqmYOSlr+AsTxAJMKhB3GSpVrRXMnNCdHAWvtXJxiPrU+6cwjeKRI mi5lK53TELLb
KDttSlfMjUfpSvqeRLoi5VlPV8S0qxGBpVKTDoWfI9WJdrty0HJcecA+0Q3p vmnurAZ04H8/
IRsi1CyJdMM6RIYf8bUr8MNflZXwEPLWIyi9V+qq1+eqjoPu3YT0SBmo/gy8 PAn6lOK8f8Io
GRruWm0xhLIdOBsagvpUXnssBGoV/PpIUPjoGzkBjTK0vZOzU58soBn3px4G N21iOMRq1KY+
4buVixJo48rxSd3H1B7Is19KU2w1pLYlD2Iql1abkgfJlKaQUaY2hEckxiyN Frh1x9Rtq10e
EUeQ8FVOlO4J0gmvjuT8OVxl2GQpMyiq8MMcY/Dyw6Z8jadYm9mmdVOfZNFN sQ87u8kmWk6+
qMF9etiOIz9syteslyazTeulSh+0j/DG1z2kEXGmVt2MGGcW9kDKjum+jsPr L0viXNAFXzYg
hyDMG+E7sPtKkDUidQ92Q8cq5jTB3EbexI36p3Ym0SUi94HELpP/NJIicV01 xngakUZa4jzC
ynAVRC/sthtNqS2a3rmEdT+5iAdt9EMKXnWIEMGk4OvLuBd6Dg82UHS7eYjS 9FXUvzBGcWOH
INENF41kHoVMShjXWQjHa2iiHGQwpRMR63wmGdjHllxkoIzixo5fohv52YmD JcxOYXfkFMZ9
AEP07bPQxwSIfIwtk+p5i7VOAlll0f0TyRpWkfTfbJzGAx4Oh62qsotjIdY2 XUSsfJEDxDWD
yk+NKNRMKqkKuLdUY07/S69f4VEEsFhe2pTAqFmwQzKqBVFc85Gn75boH4aE dsDXSMn0kafF
v5EqfFVEY+7y8BpnObW7jAbH1F1L5PX2Vsh6Zm/f3rTJzPfqGYdFzhEaVSb9 HiS8dZiAZcX/
XllfNuP/rc7sv6bzzOJ/z+J/Zz6Tiv8tkua67bnM4phnOF/RESKL1ygqNRsq Gf3Pxet47D8i
IIGUYgBKmEQNAkOLxXQAn6VWfi87V6P3xxhLm9vxUFuGExFDF8xzIPheGLT5 K9WaJj/EQxwx
wKNjd4LB6cXIunGivpe5mUFZR2rblYi84K0Eko9RyZgh8AYxEtq47pAZIObG pyR87jIFP42T
vLAoXrAoy9xcm/YyUPODy8pfqxVfijr4BoM/U8Tw8M/8/Uv+/lp/z5pmGNMi O/MitLu8hIzn
rIcztnTwmskJ1Ax/MSCslwNiNgdCR+8irE1F7ewiFLsXtn/NTePFDDitxZum OmblI/BI+Yu5
HCYsmHZPhtXO0xAlee5MQoepOJO4w1pLNxSV6LVYWg0aS6vRS0n2g72Ua0vp BFsavl4YPi1s
7uiKsOeOvXfPHac7/9zxEubczUKFWM8I8n/Yioigkpn9faj87+TnLP/7NJ7R 51/1PU2eExnR
igCTEf99jcy6PP+tLYP/DxwJZ+e/KTyz89/s/Jf55D3/UY7gO/1xN5/d+JKc Y9znOCjzRa/R
JYhvtL+Mwquw5y8IzcHGn5SPSGnA/ZNeGJ7Fvct8vkKDqEyrGy3+LLx+2oD8 Rylti7pHzV7c
bhMqzN1tUfWY9Dat8O+dNZph+TWWSMp1akDvPS37SmP49LAFMT7CTt6mMCLv gAjchRo126y9
Dn0H9uSqXz766tj/sd24jgd9MjVRa7fRb+QquId/+osSeZBI2gkN85NE/Wzt gErZkkw4aSVP
GhC3+HqzAJA+mXQtzhBQgU2rOQGplZXeqJoLwpsibv4By5NI+HDNISKA0jie tD9BHzZxh4vQ
F4NOh2yTX5GqnVedsHnRdzsKGaKAcBTaPgXtRRMXZdyDT6iUMG8esLde0oVo pszSSdRIuFeJ
NgQaJxUCB5LBgVcWOa60aDAXSqtl86aCO7x72058H7bktQUc670QSvY1h364 0quVnIspwLja
CxKEAg33ClFLAgR7mdcs2oX4jNd8ak28FRfFuHXE1hZapAlGVVrQa8EDphqi LcWe0MVFnLXf
E9WVlFV6yW/sigeY7yI4i3pJn59pt+xi8JRKrr4syG7j5egTBZKFHo4irTlP 4CN1UTrw5RgL
PKQHxhZSWmChNfsYRMVdjY7P27yGHx6URRQt2cGXXAPnj/3lrf5K+cn+fLvp umGU/liwZGy2
wRErlqlc8I+7n3x+HbTCJDpnyTuQnw0gLyLkmoivOkxVK2UNpqAtK3wGJMSo E5zHjTYVBkGE
6xIps0EkPuSXGHmYg4cMHQy6AAIqjSXQSQlzJtLp5itHn/kNKY37oWQhuBy0 +xFtgTFn9w2q
hSGpzeE8vSf5gkJg1GmNfl1kQZQ4VuRcK7fAptUbHwEYvuWQ/co2o3+A5sjn IY1cYfFd7rwn
9YxmYWU4TGc4z/FB013OT2UY1EwF/kQxPW6XMsUL/2iR5dsQRU3vhMoSTfHX llxF8FtMN5Gv
yvsH+zV1SYtawFo+J+R63gNElmRAJOXlgrcmlbRASRpIwatUXaQ+ZgsLYtVj TTbOdtjv831E
QFOb4MJecM5y/Yk3Jf5H+Ul9b+/ky9rhcX1ne0+tfN6i+r6nEcbWqVTXlI9L S+QzVRiy7+Q8
qlYGslP7x1glnZYFOWTszHnLNUCTezuHmDWyzw+Onxqjeh32+gD2iJxBWY4U pdv2nlG448r2
PlSfJzEbqsiRPSJfxUar5RXHfAKdgynSNDDnHNNMhrSER2MqZAVxyPPvhNCA WZ+lHqFpLCD3
DUtAxufI2ta8+4yYVo/Yq7Ajk56yWZIxTEYrvnOxJlkZVctNltOXzjVrUKNY Gk3+LDqn9mFc
nveDNGmnEM8zgZH6qmqhRAfq1z1kQpOqBsZLPYqIklF3wcLKBYTkkQiB4Kex cupT99BzoPQe
7yObFrOBPFindqmtXuMc1VCtXtxV9wtWoWBDTLkF10lmS2jLmopP3hY7CutI NQ/KTgGIrnU4
XPuWueQwWCzn4lZq3ci6Vvhi9pKW42KrWeWqm65y41i6CrSRVi3YGT97fnB4 vL1//AjygHzQ
h7tLzbsOJkEOSuvmT+XfgU0NLEMgX0VM80BEB/DdV+o1+PtQlKUph8DeOuoH 5ECROE7FPw2S
6w5hnR1C/z1cVUe1Y7M8j0DT0yryDFBwljsNO+QcA3O8GJwOIEJfzzGKsnqi 04a9ZEycGAKr
T3gL8BWCXDhJaBuwesCADZiRjZzcEVa8QiGexe5SiJUg6MCCh27VE7ZmBq3w BvjHXt2ak5/E
rbJsue+eXsB7KFBYhFPpYh+ENP7DOjvZk5yxQz2Je78dx5dHgy5oLVOOd5Zs 5JBcfaO05agC
Q1UPaYOoXP+Krw6gEBjRcdRvOw6mpvWLVsxxJAU0CbvxBKk36kitJKxkDEfS t06sN2qVMPr9
L6SDTVKtAIrf/69VKyuz+/9pPOOaf3IeI8J+WD6Pzqw2Muy/l6tq/ne4/69u rGzM8r9M5fmi
/uSjjxu/fu/X7/1b8PP3P/30v//ppyfv/qv/97t3737/93//5OSEvCV/Oyu/ 91/86B+7d+/H
9xbhB8C496Pqr/979X/jb3/0j/7oP/snf+33/9Sff+/H/2z3zf/k7+7/p/+n n/+7C7/x19/8
8eFfP3385V/+k3/0D/Y/+rP/4X/8O3/7r/3VH9/bnN5wZ4/xjG39vw57IN64 GEDm+l/dMNf/
2kZltv6n8Wjrnyzzd+/+8O/8nT/8R//o77z7R5/+HfLXH/4h5QJOFkDX/5y6 /o+X/72P/3j7
N/653/7jz/74z/ypH3/w5t/+q42f/9/n/+4/c+//+n/7hz/u3vvRn/2H/5uf /Sf/Qum//Zc+
+xe3/3d/4zc6f/bv/eK/7Nf+9X98f/Dr/9q//L//R5f/zX/j2eBv/0d/8/rz 173/RfSfvfyt
tf/wT/4zMw4xsWdc61/681bWTR6Qsf4ra+tV0/6vulKdrf9pPHL9/+fszR+Q /7v3B39AOMGP
f/wH5P9+/Ad/8Ou//gfk/37jN/7ib/zFv7iwQP7/XyVF/h3y/MN/5x1KB7Nn 9nwPHrqf/dPK
fvbjg3v/3R//6ad/86//3T/34z/509/9+385+IP/2q/9U5/8xf/PvT/7oz/x J0r/1N/6C5X/
1T/241/70Y/u/Ud/tP2je3/is//xr7r/wvaf+NE//pP/zkdB9ff/6J/4J//U nz7+/Xvb//Yf
fvbnfvLP/dZycNu2svHz/+pqQf6/vLa8avH/Wf7P6TyU///Gvd+49/+7VyG/ f/d3f/dv/a1/
8Pf+wd965znz3drnj/7oj+j6/ZSuXxjTvX+i8dm/2C396P/7L//9v/GvPF39 6R8+/U/+D3Nv
f+tfevGfvvjsP3jyv/35/+uf/qz8V//4/7j8X/6v/3sf/Afdf2vz//LX/tL/ 49//7OPf/+Kv
/Vdf/PJXv//FIPlzf/A/in/x55/f+9Ff/is/ev2Xfu1/+lf/1R/91f9Z8q/9 67/27R/+2jZt
+Jat6GLP6Oufa8ydrh/4ZOX/Xd9YNs9/q8sz+W8qz8z/Y+b/kfnM/D/G5f/x fXN7MBwNcIFx
21q/u4FyNy7CL9wf0udA3X6KuhvoZsgapJkFsn4RqiLnB258zEc/Mzu+jWbH vN6tMj8exrzY
N5BJmRmrva9uGL0fwsrYWBpD2tC+/l6bzr4ubDH7emzWdq/HYGn3ehxmsRJI bmvY1xMygn09
YdtXD/z8BnASV0NauupAMi3fvn/GZIKhsBHCP7fOjgzNOC/itpSPJ2UxNrr+ ZzeEIy142sLk
PWt0yOT2NEVQVv5fS/+zUqlszPQ/U3n48e3mE/xmkpMnxe8sw++oCib7oK3o mJq8Cp9+fggf
XSHEgjYKSQF3TLcagxUF5t6NfTqdMcWLzNQ2AWGmh9OwyzNCTouiQVDcLnO4 8K+mX9nGJBF0
ZQTq0hhWceJcaEKDor4T6kX6mndRVanQ3Jws+aFaF4KGwx4GFMwGQGPMm3K0 WokB0vEm22qz
DiQWEBV7wS+VviZMxlYLlFYWUs8VVCvkRpOlHtK3e2clx6ZPNSQlfQUsYAT3 xaDEqZ2+KCiV
5SPfB4AkHnGCZoL0SDB4zrFL4yt7YDQ4w+/8XJmrLX1CMCAi/6EdcUBXWIJz aETqLG+Sfx5L
MOV22DnvX2wGH34Y+cNglErqIBdk9d+Jfr5QVkeB3Vcaf3t/FMHQu+4fNFot tUulfNOTNhcm
RPWHGLA9M/okQJ6Gtu34Ot6x02D5Yx6+A+hQGGCR/B1IsDmDCIzv5HAs6cdp qDE6S8XwS1k3
ZXhwOLO4YEltV4FjjxFClWAeiPe2HNzUCEpiFyg7sAuSieE9btVji1wybdmf fN35JrNnJtnz
bqnV1AXuAEE4D/zUD8VvrXkfnfCbjQ78rHd8x0Ilp7Ne8BsbdVs5ZtJI9Kt+ sk6aDsQo3Rjn
ZmOg42DgONs78aGUvFGEYD8mgRFCic8abygxujHCdlm74GgIqQyBDLUPk0JG 1MmJDL3gzSCD
92FCyNgnsjiyuvA1TY6ZjhJn8RtBjNGTCaHneS98HcWDpACKvFVuBE2O3kwI Vfr5wquj1EoF
3nrDIUvJGO9DVyq2zL5MCFUv6s/gRrzbjpRgd16CcpW+EVrSOzIh3PDzqA8v /HvgKDsaVtKo
Jh0xsh8TQkq+/erGN6uJ7lTwczs5Jmw/+/7DLjsaPuaDyvLyPz8/PFZ4ZyaI G+TuSTqV/M7P
A2fpERdOeCXhf1N5OzyaeK8mjqY8hGQia5wEhZfXvJVvGHmNjLhJUlli8P9s PZ67BjUGwzdj
waQXZw5kmT1SujIhlMHOIHKqZF4jZGBTA8YTtNwADrV+dCeFOtxMclGZUtKj KZ48TrAPqp53
EujY7kSXiPWj/nU7LGVTjLtSkMBfN4Uloz+0L5NEGmWKcLlbbjc652XKd/Ng jtZkYgVMrlZ1
+pij/VE6MkG0sa2Y7+s50GXUoCpwfHdTCGM9UjoyCYT9MlX7Kq60xqV3LYIH 3u6khp2iZRXj
Hpt+tejAJ6ZQBeDHcep2Lq76s7BD4Cg53chfN4Iq0gts+9baf9mmfaYXYIb9 19r62orp/7s2
y/87nWfm/zfz/8t8xmPu1Yx7YZlMK1oPJuX6s0bvlc8iipYddPrRZViuP4fJ D5PkWdxhDXhs
rtCe+U3/WdgZPGchUv2F8/gi6vbb/nK5fRbN3LxH4LDlL97qtMrHIZlejODb 6CRnYW+31zin
JpjZRmhd6nVSZt4nYITvL4w+jVr57OxUfD7Lv/WE/Dzks+uuktf78UnUbmc5 NU7LUTKjKKat
dRcDK3G6KdbBiD+r0JG3PVIGaLBOiL/2phl2/em4mFdqme/Fvb66GFPXLpMA nrcH5+qCIHWo
4AE1+V+kPvuTQWG/GCz2qwWZp/Ev7lpgU3LcPW70FEuwzfTOWsm6dRNJsqEw YSQ4bRBGTg0d
wZ4MjHQUf9QEvDUJ30QvIaxL/YN0x0bFSYgx6MfdT+p9Hn05gUbItpFQfwUa f/m6i95NYEZ9
Ac4qsD21o1dhoLSiLn3WRrLIvhmMRH5uIAC2LpHrJ3EQd4Yw/xQ4ouix5Tdh BCrJyLL19LqP
miaZNCu402NUM+rkXjospLQHjuTZrFwOC07HAG3v3vwOsmYV1l+j/+6zhd0V ty/toj1Qn/Go
Ftaa5XHGVFgSydpn1t0tib8hD2HAuY4ar0OQedAHphXDz1Lubdxz/qITjacw BtGsGFxqABSU
LC1hpPNuTABdPxJ2eEHSeA0LkTmDUcTIWorzE52F0kKZNc1bGjuatr3XQdb4 t113QeMe6fZI
VztyF6PeUHE/ptKdgxpMATDtGK4AYqWJYK9U0hECcfkJvyOE0uhdAwqEXLwI Ejrw47BNtoZr
GqPAvbBHHz1I5yX/Hr+YJiSkIQPhKoBYeH+1OnUXXFCXfA+ikVvig81MILd7 PyyZjsTkPUIu
Ucj6F+rLhl/Q7gf95oMPg/lHwTz5R3OnH+cSipLdqAdZAtNWELclNAqPvIYo oYWP6FnwMiR7
bovZ/kKiCTLogGzf7RBivl9fNZSsEDycvWMRik6mmR+rCQe8koSIJaGIO+6U BIVAmJgWvpgU
2SqUgCYZFL9TAvsb2SKsisWwoRxy+EjMYWCUjjR02DC8I1eKKg7+8NNNa6cQ NOSsQdhOcIUd
wWbBbY5LlC2NNz20hY50IjI7MdYVRzeJ7TZpMGzlXXnOSiOvwNR1ZDQ5Gg50 J1/C8Z7EzYF3
5+Y3LlohZbS54iiwyuPsNw+A0esPH0LEkk1soJOPIiLP8AE91StBLlgsELU4 O/kTiYEcaZ9i
ujmIzLHsK/IVRMDwlFCS8DWBNLeCNbsQOX1FvyTYyCjWGVzuxO3BZQecolR7 LlesE1onTywV
WQJnTARv2I0Scuq+Zrler8lBG5onywVQvHOwd3B4slc/Oj75fHvnZ18cHrzY 3/UHYHlCRLgx
Nffk4LCmNKcxhTZoVTCIhxpVAXUt7JuR6Rd9++CDDIdCSejpwWH9tw/2j7f3 gl/hi6On27sH
X50cvDhmL/ZqT451qiFgYKx4oys99p1lnpDZNjChK8IwsTApdIgBJ3oMLSWj 0NPa9m7tkKBk
/9jdzuSnWRnSpKbYakqJGZMSq0ZOoU0onfjKGXDMQb4WpzEoJTVkkRJ4SCon UwIVfW+WZQo2
suYNYwxpMKzAU1bsokxJ72JAxEMiATRaeNfSIWeL/BJvzspeiU9ozlzxwlI1 UegeHcOYM3qr
qqGy+5E3npezbypalcMw17HyDloiNPkJQQHIikMVqhvVWdozzznC0IY5RDzf WULTdmWSkapp
LHBGyKyWJjYpKj3j4OMbk09FJ8f0NI5fgZ5TxhuUt1XiDESl6F6Y9Pm9J0Vm SmxDPKYsaqGU
EvA4pr778Frk1T26JnImS1i4KCHRu9MmWW+nIdW2k4qvwrAbVANU4fVoN2R/ E9DHQ/ZDPUqi
0n47idXEiw06l3XRled6WkSZEpGO9wOqCAE9hz9EIk9wKFsm/ca4Uu5gUp4g e54AU/pP1oLz
XDR6xkVPsKmM5Q5TRPDag4M8oZZEzC5heFqrruOnkyjydAqSYrKBZiS6PGeK KjwsWTOvwPeu
mR0enCtxxohzLqIsekknBl84sPzUoEcgSy4aQP+vwmt6yaTiBzy/ZWg3JWba AjhfYyAJXURw
FwbsPkeWakgUabOP3VKhZERSa9Lr+uAy7AzUU6J1iS/owCX3611x1HaMgA56 MffQtpHKpBCf
Ek6Ntl3iPTbSkzPa5atbraHdwJaf7734or5/Ut8Ffaq8+GTx1BjmAHHziwI7 i0oL567VQfpN
ZuE3iaj7cH/v6GHlN43pCTsoGMmVCGHtgj5e0VJmym5wgUHgFW5i4YEsZfte t+SftuxLYTXc
H9TO3N0FT8MYumybDlvuPd1T2Luieb9VUklVcbroSVZ0jIkJUPSm1xMnUzPQ 4IVzpqJ2BESd
SsBMZxRaNSpqtgYJWAhWtCKJyjIaMtipz4i+uukpPY64mjrAocJraq15Y1oq 8mQp7rSvyRxK
sumSkrLAgsaDNHkhMUPTav23Q1WidUaj03+kUWmUKEEsYStvKK2rAM4aneY1 r/bIQJYnrOXO
IOnHlwCY9dQstGAwWc8AUStuKsmtETIeqI4ORBLU1CAPxJifMUEwWtslvplH Pmhaajn4YLZ5
lzEludmgzkJ85zS1jHfJ6szCDmfsP5XpjClXv60gwfzIrJ+V1UML2ojKkwKe N2Cuwjc0hiH8
DdbUwlhHVAZLGn5M6F8MLk87jajNLIMCntWSn5tYlltfR1TEZiBUHOHzxDLd nFyS6PJSeemz
vbhzvhd1Xk2khXs8z4vv3+XKWkXLBb1cwZSAwd6E+qM93P4b7uHSymV9v6PP +PL/eMVvd1Kg
2XMrninMf4b/R2VlbXmD5n9fr2wsrxJesFLdqMzy/07luXXxf/OxE3cs4Oos FvBdjQU8lPdG
Hs+MQVRuoBIkKetKnFxVCCHTWqRvYDLc93g2UGcIWqtcp1XylISx5ggNzIpn lrYGq2ZqyuMF
wGvzVShGYiR6ihJLgSd1dCBOg1lPKG4ZRsrs5OUEwk7d8c0yWKcjY2r13rXH vlwnEVZJoRi/
YqWRTxfpNz13Hxj07Et5VJxOpbKi6Uwdos/KXFerw4PG5HrlYMtGmHHgK+Lh 6xjmg9NB1G6p
StNcSyvNXsuCqFZEwvYGWbWZAxz6j8hfrUavRT990YsH3aSkwtEUDmRzJSRM yx7HLzqtGGuo
FRYDbS2XX+zvHoDWqG4kYxkC1GFNB+UDBjSVCWzn4PnL7H7lAvV8++i4NiZY u7W92gjAHJO8
Wz+s7Ryf1Hbrx2lI2261KDxd56NC17/oTLe8vbt7snOwT1qpH+yfHB+c7Dw9 qO/UnE22o/MO
GLofDU4Bfl56Q4LP2z0drUfbXwqkGgUdKAOLkucnUCdVe7WNvaN7S4OPibAg GFTf4phKVy09
i5KcyYOi/Ot8aSkQtRkWFK2fCob2dMCUzsqX0jxCmNcngwkKfG8y7rYc107y KqrkQPL2Xv2L
/RPTnk0NBc0aev999lc5Smqo7oSVobfOhoIRwmlhg5BYn4ft5k5t/7h2eAc6 elj/4uldQOjx
wfM70Mtn9d3dvdod6OjnB8fHB8+m0FEA+x4vRMBcdsEPZMHLlcuUnx2z3d3L bA9rR8eLvPXc
dwaGmOy+NDAKeZXchqjpmAnfvUGWHOneMuTtJeshuymT75E7w1VbVw6Mbia0 Rr1lvocaX6gV
UrYY965qbTTKdskMCXnj9hfRvI0qc/fIoHTexhhImtKzRoain4uBJPK7NGlS Xrbny5ymWz4X
XpYAJ4e7Oj9SPP/+zg+cKO7q/IjTzvd3esiBzDk7k7qbncYzboW967Iv9f6n sry6trLC73/W
N9ar95arGxsra7P7n2k8s/hfs/hfmc/wVzwY2jWKIaJTuB/3n4CNmyOGES9W P/B9xOSI271e
45plRrQ+1l4TBNC8c67P9T4YbKnBw+Q3kWwxR9QyGIn78qV4fDNZlrsCFitN c1zhwIepmB4+
zFd3N2z7wm2lVvkySvzB24yawjPSDEflDS5DFkiYERxLD0az3Wp0+7Be8xR+ 3uhf5CqXJ1Cd
XuWILNqB51ZRK7lPhJvi8HODPxqc5oLOwqk+BzvdKPNeFGPj1Z6kTWOh8HnS uSC1DBE441cp
uVzVZPT+UgVj9TmLF8kTK1Lc9MLwLO5d5uulXb9oPSXkrL940UiCVE4e6tJd KNtp3Vx1IONq
PyxQQQbsKVAprzmAUe0wbMUFWsEQFgWKczePInWANguUB+1IkeLdVqPQbNC0 gwUrHAzyzB1b
Gy7PtPHYcrSIKBafE4rq9eLeLv7IU9zgttkV6R082VbFWNylM6Ns8mgfzCXc a0pSJHqln9fk
jHCJglWuBsXw03mrFQfFWyx/cE2dqUnjGndpPtM0JE3aBPO4nXlxgIUxWwq4 feeYAaCdhHqN
dfrMir1c36G/D+hvAJUBgJzCuhAIBYS75/Tv66OLkLrB56/rqjpqlNIhbJqK RhotVP5Z3Arb
avZyzX6KWjhFlvM9c8LlFlSWBSY7J9f7EHHsKgkuwG8tDkCH0ZfHQDgTX0P9 +KqjQgfjTsso
C70nIGdxQnZd6FIvbLTb10GC4MrBV8zflCoVIWTCJQwNfSMwrioNqEpOrQgu bJAjM48TAEGg
yMkbtGthS/HrYMOEs2uTJ01Gn40kRL+a9vWYrMaEiZhjsah57eVxAA3HbI2r Mms0VTSNK8tk
PpiA5qugiccqoV1AxAgIaswELXgA1G+FTYwoG50pHuYB6hrIOgGH+U6sGEAo LidpyHGpbukY
BDpcsqqKGNd3ob5VTCSYlV18SrU2OmIS0Qu1JwCOlzuixajdhDjml6qGd5aY EKYGb7Vk8ANX
IDuyNFiPylpFpuZWG1e/q53VM65r4em0oHcqLEXHrCi54dGGi1fCWr1Nf+my 0bo3AfZbHWNO
izuGBZfVXeop5oHaI55h26mCWciBTxcwBUQQvpY+oA5cgsa/pE3CAq2Cvs+o PygtKKEVDc2/
AQ2xtRQ0+kE7bECkjE5orG6+GhcDZ80k9jBzsYr7cWzXTCA0D/Sv3xuEJgG8 1X+G7STMMwiy
1Z4SXnZN1kZCZI9FiDd4Qf6A9dC8CMlYgG/rS9QGxMP4EUzUKQ7J+nRl0oYH mGGJ69j4qt8y
6D1i30vmOAUyaLmLRrKvZssznwX7tQMR8GhLlE7jVmDQDGu0k9Yi0BqW85JT Rkfg0RAJ0+1p
DJ5Tsgu/8nx/a792vBKEJZtNIa+3aXwWDgoxhnAhBN7WdgFawrPAW7Reyb+G i5KNTSHZq9rk
Edp8QyiGSyLK5GKtDkzrPW2SBaNTdypeQUOcAM/qXXt2TiIYhSDNwTJu6XvY sRV+FqQoFnr2
6oIM4DW78mAXdSi2aSCuwLHZguyZTAi8DCcZnl4wueFpHcfSpkvaHJlVVF8n yj8ZEiKyWyoS
skv5M3LACxKMvsZ9jOHkkHTJAR+vkgS4y8YrUo1XhzuoXotQQlsxyaosQMoD cpTqLNJppODh
bI+hVMEE6+EnpE8xizVrBLCvivpKxV4IYdFaNEbTawYBe6GA+CChkabVfgmw o8qmXPl/DDGI
tNA2irzuvslYDJx3Dpa9QTGxKN8tyoOe9rqVGvrccYOTR2Iym3DByRKbdAwB oZD/bknJCV9b
S0Ca+bmh4vyQTZKCc0ca4g+WIcdy0Lbk4rGNPjlTlrQrHnKwY39lcwo9sA7Y rDMfHGpUshef
kz/a5L8CJkqQeHOiewzwRxYkpNvpI7cBcg0zWMe4KVAl8gfgB9nPRXVYLYPe uPRHobqIJl0y
Z3RFCcHG4K9+FbxH6YCgmgMn0xD+YkAkTEfEJnhKJVNLuMDDfbDfsKFDxNUI I7Y66I9bsVLp
y9NtDIYVQTQWGIA+9vJh7dnBl7XdbLLD84lRGaueHB8E7weipSftxjnQGbS1 nF+0hWAsZ3JT
gb2cMX1v+f2D49ojDKrXhPQ4REjoQSoZtoUMOsomEskthPx5ikIIjTUmgpR7 mwHlitAlaEED
hT6Wb34yaAzBNRVmym64aCadJXzDg9sdi7WEpxXXAnbIy/bhCh4/8qE89Crq I+7pZkl2O7aB
uutRL0OkYlB14L9b/rEY9+A8chSKC5R50SA2gub9oOARJPcMOnscw7W2m8HB w64HUIqHf7eM
6GIXYbtN/xSxZT2QGIRyA6IJ1t6ETQzrcwhiwWlbOx6oT8pJStsTBx0fhAwo 8Ij8Fiy0r8pc
SmyGvBiCx0FJ+DoH1Rk/GWsyT9hS4hQypy6JGdb4llRlWOFbpvUSLMEmU11i EK8B2Fo1klc0
8I4FN+LBvki5YygG+sT67qbZURbVHziIJrOb8HZFOa1Yy/l6062kdWW14KxI 5oQAJY9U4orq
hvqWQnL3ygyHZgzFqVV1D0R8VtgAi1NtH0hty9kx6tMGyqVtQrUd9Ed911Qw 4j/WRANOAXmM
ICM0UCa4hssDruum0C2EoS6YlhFtWtrghUItki2HG0FkNyvtAPI1bGn5PuBK PoK3vr1WjGQ0
iiJNh5tNvSbkdE3+ZdpXq3UZ7kqJc2W1qN+wKJeHvJq40VNh80BjmO/EE80Q U6l0NQMTHQiX
ZWl8WsWb3oJoHCJFTfbbgixDznL9lgXSvniWteQqRtKxi2YsXQFInOy0q2uI h9hfVMDKCnnX
s0XluZa0HWnWQos0yWKlNRutQutV4/upa1bnTjkWrJzfRDEAEZHfMLQyINkX b9NpP6LBspok
22KMBsF0UdsX5r4lbRUUoNwX57JRGpkDEqOIqKa+1StKeCQA/vm5b+tXC+i7 vthQ6f1cR3NM
EfeehGNSxOjyiRVotMQDjjQCInF20akEzwkyfITUOKluLaqrImmaHETs7VoL SUpKMAcT3R/F
mcnHck/hIX01H5V0Lx6GHm1vNLDkDnf4uKZvp7B++N+4oOidu6gC+mSYLx7m 1QvbRqDWuUz8
1ZQtvGSa2I0PnfAY0oLiX2vGekhFvh70my/JInORAqD4zFA+ZQUj53lgc01Z Wo9yzaCcspJh
XDj+KdT2pNEm0WUBUHgi/UCKT6YXYoFp9PcncyoVI8+S8vd451DfiYtO4A4o axL33DCMgFLK
GCo97ah6Hi3vHNRwji5deVHO1E4YAlaGFsKhedD6gOl/F8rqOAxfOkALvdpJ UyunI5iHp+Ik
3JG5KdD67JLr5vSpz9gqaZxsLlvayDaoDxAqTYipzl+LxGMXlzbTsrhWwWBU UEc1Ai8ZIvRC
4GrVAKIjWQ3opXRlMW+gnjxdNmzd3b1eDCx3C5q2LH00I8GnYU8m2ADEK5kg eBa/Y4ItsAg2
E2yBBUtx0pGQsqAF6TFgr62lpe0vj7ePfuas+Byur/zLjMvBv0TzfHbMUm31 S/TCkOm1FEcS
Xa2swjkQaRs1G/6ckKSMTvvk/3agZ03UWC85on4edeDe+gg0Hs3Q3uls8MNA UDoxXCpPn6X3
A5n1y5GP1J1qQSmqsGrtZtfYs2S6BXGe1LPrwaMfBCEIYKuFe5vKP/EFUtii fWVnbG4J3Rsx
/6IOfFHNp8H2TyvLtG8IDp22XtShzHZdzqjD2zGrDDNGuwlHT9y5auz28yAE si2lWf/BDVGa
4pBmdNJsYZ29s2dKT+9sImVc7XqwYjduY4YsXdRwKJcWGqasDrvvB2jeiZ1B D1J8jAdRVl9J
A7S/oYOWEyrLv8Zlb6wih+YPHmZmYXnDBKFfBFZ8nspwi4y/3WO0hG8HRc8f gDESApl3fa6R
zsDHIG42B6CYbA0wsgg0jQmjpW7DVT/02XUI3jxmJm0aQLoCkBplVCulJf5R vW/Q7QNta8wc
i0g0qVvXQ9I5uMb23djtudry0n+KXWXORSR77OuorbV3bNd6a/wOHcWvr8gW LrM3qUWkvpdv
70YZ2gNbz2+NzXEVYA2HTsi14xwWlK6idlvQAdhts6OcntPHOrh751jJ4NNo XzWuE7QZpXF+
jUgSoAtmcJQDPxTUwI+4cNT1EoMk67Bh8jjYp64rCsusElxqVXMKQtRiAy1j toqaIZk7P/QK
IC2KrhTfBh3GuKlM3bCdmx5Dx/rBLmXT0GMnX0eTJLpZSkmTuplR/7BO3Afr ZmqsXJS1s3+G
oM869BgvXiR1bjvkbYvstl2StuoHGlDnUHYSUr+UXKhVR0Rrgnxx0IvOQfOF dFbUOM6GCPOt
0RHGvSC7DvnP
Re: Up to date eclipse 3.0 GEF/EMF Example? [message #154593 is a reply to message #151974] Tue, 19 October 2004 13:58 Go to previous messageGo to next message
David Sciamma is currently offline David SciammaFriend
Member
I'm interested in contributing to this example. Can I help ?
David
> "Steve Jones" <steve@istech.demon.co.uk> wrote in message
>>Hi Randy,
>>I've not investigated any of these errors in any depth. I'm still getting
> up
>>to speed with GEF & EMF as individual frameworks.
>>My worry was/is that since the Redbook is now a year old and both GEF/EMF
>>and Eclipse have moved on that these examples may be "old stock" and
>>consiquently not a true reflection of current GEF/EMF thinking.
>>If your saying that the examples are current then I'll put some effort
> into
>>resolving the build problems.
>>How about putting the redbook examples in the eclipse://home/tools CVS
>>repository?
>>Cheers Steve.
David Sciamma
Addr : Prologue 2, Rue Ampere
Addr : BP 87216, 31672 LABEGE Cedex
Tel : + 33 (0)5.61.00.73.45 / +33 (0)6.27.39.43.29
Fax : + 33 (0)5.61.00.51.46
Anyware Technologies - http://www.anyware-tech.com
Re: Up to date eclipse 3.0 GEF/EMF Example? [message #154609 is a reply to message #154593] Tue, 19 October 2004 15:00 Go to previous messageGo to next message
Absolutely. Please e-mail Pratik Shah with your background in EMF/Class
modeling/GEF, and the are you would like to help with. Currently, we have
the following working:
Display of packages in the outline view, which contain classes.
Display of classes, attr., oper., in the diagram
Display of inheritance, references, in the diagram
DND of a class into the diagram, which auto creates an references and
inheritance connections.
We don't have:
Property sheet support
dragging of endpoints of connections
very much palette use
Pratik can give you more details.
"David Sciamma" <david.sciamma@anyware-tech.com> wrote in message
news:cl366m$4nn$1@eclipse.org...
> David
> Randy Hudson wrote:
> > The authors of the example would have to do that, but we don't have
> > resources to maintain so many examples.
> > For GEF 3.1, we already have 5 different examples planned.
> > news:ciulif$862$1@eclipse.org...
> >>Hi Randy,
getting
> > up
GEF/EMF
> > into
> >>repository?
> >>Cheers Steve.
> David Sciamma
Re: Up to date eclipse 3.0 GEF/EMF Example? [message #163478 is a reply to message #154593] Mon, 10 January 2005 19:01 Go to previous messageGo to next message
Pratik Shah is currently offline Pratik ShahFriend
Although this example has been publically available for some time now, it
still has a few things that need to be worked on. Are you (or anybody else
for that matter) interested in helping out?
> David
> >>Hi Randy,
getting
> > up
GEF/EMF
> > into
> >>repository?
> >>Cheers Steve.
> David Sciamma
Re: Up to date eclipse 3.0 GEF/EMF Example? [message #163487 is a reply to message #163478] Mon, 10 January 2005 21:04 Go to previous messageGo to next message
Member
I'm still interesting in contributing to this example.
We are working on a project that deals with EMF and GEF.
What are the topics to work on ?
>>David
>>>>Hi Randy,
> getting
>>>up
> GEF/EMF
>>>into
>>>>repository?
>>>>Cheers Steve.
>>David Sciamma
Re: Up to date eclipse 3.0 GEF/EMF Example? [message #163495 is a reply to message #163487] Mon, 10 January 2005 21:52 Go to previous messageGo to next message
David, I will open a helpwanted bugzilla and copy you on it.
Repost from the EMF newsgroup:
The compile error in the repository has been fixed. This example is very
much in the beta stage, and lots of things remain to be done. Here's a
brief run-down:
Improvements/Missing Functionality:
- Better routing
- Properties
- Diagram's imports should probably be Ecore resource files rather than
EPackages
- Validation
- Context menus
- Support for multiple inheritance
- Direct interaction with the outline (deleting from the outline, dragging
from the palette to the outline, etc.)
- Awareness about external resource changes
- Ability to move reference labels
- Ability to rearrange operations, attributes, enumLiterals, etc.
- Documentation
Known Bugs:
- PropertySources (Two-way references do not show the properties for both
the references; undo does not work properly except for TextCellEditors; no
way to edit EParameters; and so on)
- The outline does not refresh properly if you reparent a package
Because of time constraints, we're not going to be working on this example
much anymore. However, if anybody wants to contribute to this project,
they're more than welcome. Feel free to contact me with any questions you
might have.
By the way, one thing about this example that's not apparent right away is
that if you select something in the diagram and hit Ctrl+Del it will remove
it both from the diagram as well as the ecore file.
news:cruqpe$jbd$1@www.eclipse.org...
it
else
> >>David
> >>>>Hi Randy,
> > getting
> >>>up
> > GEF/EMF
> >>>into
> >>>>repository?
> >>>>Cheers Steve.
> >>David Sciamma
Re: Up to date eclipse 3.0 GEF/EMF Example? [message #163822 is a reply to message #163495] Thu, 13 January 2005 19:05 Go to previous message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=82517
"Pratik Shah" <ppshah@us.ibm.com> wrote in message
news:crutf3$u1t$1@www.eclipse.org...
> brief run-down:
> - Better routing
> - Properties
> EPackages
> - Validation
> - Context menus
> - Documentation
> Known Bugs:
> might have.
remove
> it
> else
> > >>David
> > >>>>Hi Randy,
> > > getting
> > >>>up
> > > GEF/EMF
effort
> > >>>into
CVS
> > >>>>repository?
> > >>>>Cheers Steve.
> > >>David Sciamma
Previous Topic:How to run GEF examples
Next Topic:how do i use org.eclipse.gef.ui.parts.TreeViewer
Current Time: Sat Apr 21 19:32:33 GMT 2018
Powered by FUDForum. Page generated in 0.02922 seconds
