Home » Language IDEs » Java Development Tools (JDT) » getting compiler error. I think its something to do with eclipse?
getting compiler error. I think its something to do with eclipse? [message #1032987] Wed, 03 April 2013 18:22 Go to next message
howard hardaway is currently offline howard hardawayFriend
I am getting the following compiler error on the package com.lynda.javatraining.db.tables;
Internal compiler error: java.lang.IllegalArgumentException: info cannot be null at org.eclipse.jdt.internal.compiler.codegen.StackMapFrame.addStackItem(StackMapFrame.java:81)
Not sure where to start. I do not think it is the code. I have supplied the code that I am using.
import java.sql.Connection;
import java.sql.PreparedStatement;
import java.sql.ResultSet;
import java.sql.SQLException;
import java.sql.Statement;
import com.lynda.javatraining.db.DBType;
import com.lynda.javatraining.db.DBUtil;
import com.lynda.javatraining.db.beans.Admin;
public class AdminManager {
public static void displayAllRows() throws SQLException {
String sql = "SELECT adminId, userName, password FROM admin";
try (
Connection conn = DBUtil.getConnection(DBType.MYSQL);
Statement stmt = conn.createStatement();
ResultSet rs = stmt.executeQuery(sql);
System.out.println("Admin Table:");
while (rs.next()) {
StringBuffer bf = new StringBuffer();
bf.append(rs.getInt("adminId") + ": ");
bf.append(rs.getString("userName") +", ");
bf.append(rs.getString("password"));
System.out.println(bf.toString());
public static Admin getRow(int adminId) throws SQLException {
String sql = "SELECT * FROM admin WHERE adminId = ?";
ResultSet rs = null;
try (
PreparedStatement stmt = conn.prepareStatement(sql);
stmt.setInt(1, adminId);
rs = stmt.executeQuery();
if(rs.next()) { // if next means I got data
Admin bean = new Admin();
bean.setAdminId(adminId);
bean.setUserName(rs.getString("userName"));
bean.setPassword(rs.getString("password"));
return bean;
} else {
return null;
} catch (SQLException e) {
System.err.println(e);
return null;
} finally {
if (rs != null) {
rs.close();
Re: getting compiler error. I think its something to do with eclipse? [message #1032999 is a reply to message #1032987] Wed, 03 April 2013 18:41 Go to previous messageGo to next message
Olivier Thomann is currently offline Olivier ThomannFriend
Could you please provide the version of the compiler you are using? I tried to compile your code with the compiler from 4.2.2 and it seems to work. In any case, you should open a bug report against JDT/Core with steps to reproduce.
Provide all dependent classes so that the compiler team can compile your code without facing compile errors for unknown types, methods or fields.
Thanks.
Olivier
Re: getting compiler error. I think its something to do with eclipse? [message #1033000 is a reply to message #1032987] Wed, 03 April 2013 18:45 Go to previous messageGo to next message
I don't know why my previous reply doesn't show up.
What version of the compiler are you using ? You can provide the org.eclipse.jdt.core bundle version.
I tried with the compiler from 4.2.2 (org.eclipse.jdt.core (3.9.0.v20130111-142029)) and it worked fine for me.
In any case, please open a bug report against JDT/Core [1] with steps to reproduce. Ideally provide all dependent classes so that there is no compile errors due to missing types, methods or fields.
Thanks.
Olivier
[1] https://bugs.eclipse.org/bugs/enter_bug.cgi?product=JDT
Re: getting compiler error. I think its something to do with eclipse? [message #1033061 is a reply to message #1032999] Wed, 03 April 2013 20:19 Go to previous messageGo to next message
The compiler version is javac 1.7.0_05..
My version is
Eclipse Java EE IDE for Web Developers.
Version: Indigo Service Release 2
Build id: 20120216-1857
(c) Copyright Eclipse contributors and others 2005, 2012. All rights reserved.
Visit http://www.eclipse.org/webtools
Re: getting compiler error. I think its something to do with eclipse? [message #1033070 is a reply to message #1033061] Wed, 03 April 2013 20:35 Go to previous messageGo to next message
javac is not the compiler used in Eclipse.
Please provide the org.eclipse.jdt.core bundle version from:
Help>About Eclipse SDK>Installation Details>Plug-ins
You can also get it from Configuration and copy the line that corresponds to that bundle.
Thanks.
Olivier
Re: getting compiler error. I think its something to do with eclipse? [message #1033177 is a reply to message #1033070] Thu, 04 April 2013 00:02 Go to previous messageGo to next message
Still not sure I copied everything and pasted it in
*** Date: Wednesday, April 3, 2013 4:57:24 PM Pacific Daylight Time
*** Platform Details:
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.buildId=M20120208-0800
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-showsplash
C:\Program Files\Eclipse JEE Indigo\eclipse\\plugins\org.eclipse.platform_3.7.2.v201202080800\splash.bmp
-launcher
C:\Program Files\Eclipse JEE Indigo\eclipse\eclipse.exe
-name
Eclipse
--launcher.library
C:\Program Files\Eclipse JEE Indigo\eclipse\\plugins/org.eclipse.equinox.launcher.win32.win32.x86_1.1.100.v20110502\eclipse_1406.dll
-startup
C:\Program Files\Eclipse JEE Indigo\eclipse\\plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar
--launcher.overrideVmargs
-product
org.eclipse.epp.package.jee.product
-vm
C:\Program Files\Java\jre7\bin\client\jvm.dll
eclipse.home.location=file:/C:/Program Files/Eclipse JEE Indigo/eclipse/
eclipse.launcher=C:\Program Files\Eclipse JEE Indigo\eclipse\eclipse.exe
eclipse.launcher.name=Eclipse
eclipse.p2.data.area=@config.dir/../p2/
eclipse.p2.profile=epp.package.jee
eclipse.product=org.eclipse.epp.package.jee.product
eclipse.startTime=1365033368299
eclipse.vm=C:\Program Files\Java\jre7\bin\client\jvm.dll
eclipse.vmargs=-Dosgi.requiredJavaVersion=1.5
-Xms40m
-Xmx512m
-XX:MaxPermSize=256m
-Djava.class.path=C:\Program Files\Eclipse JEE Indigo\eclipse\\plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar
equinox.use.ds=true
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.version=51.0
java.endorsed.dirs=C:\Program Files\Java\jre7\lib\endorsed
java.ext.dirs=C:\Program Files\Java\jre7\lib\ext;C:\Windows\Sun\Java\lib\ext
java.home=C:\Program Files\Java\jre7
java.io.tmpdir=C:\Users\DEVELO~1\AppData\Local\Temp\
java.library.path=C:\Program Files\Eclipse JEE Indigo\eclipse;C:\Windows\Sun\Java\bin;C:\Windows\system32;C:\Windows;C:/Program Files/Java/jre7/bin/client;C:/Program Files/Java/jre7/bin;C:/Program Files/Java/jre7/lib/i386;c:\oc4j\bin;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\Java\jdk1.7.0_05\bin;C:\ANT\bin;C:\Program Files\Eclipse JEE Indigo\eclipse;;.
java.runtime.name=Java(TM) SE Runtime Environment
java.runtime.version=1.7.0_05-b05
java.specification.name=Java Platform API Specification
java.specification.vendor=Oracle Corporation
java.specification.version=1.7
java.vendor.url=http://java.oracle.com/
java.vendor.url.bug=http://bugreport.sun.com/bugreport/
java.version=1.7.0_05
java.vm.info=mixed mode, sharing
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Oracle Corporation
java.vm.specification.version=1.7
java.vm.vendor=Oracle Corporation
java.vm.version=23.1-b03
line.separator=
org.apache.commons.logging.Log=org.apache.commons.logging.impl.NoOpLog
org.eclipse.equinox.launcher.splash.location=C:\Program Files\Eclipse JEE Indigo\eclipse\\plugins\org.eclipse.platform_3.7.2.v201202080800\splash.bmp
org.eclipse.equinox.simpleconfigurator.configUrl=file:org.eclipse.equinox.simpleconfigurator/bundles.info
org.eclipse.update.reconcile=false
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSGi/Minimum-1.1,OSGi/Minimum-1.2,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5,JavaSE-1.6,JavaSE-1.7
org.osgi.framework.language=en
org.osgi.framework.os.name=Windows7
org.osgi.framework.os.version=6.1.0
org.osgi.framework.processor=x86
org.osgi.framework.system.capabilities=osgi.ee; osgi.ee="OSGi/Minimum"; version:List<Version>="1.0, 1.1, 1.2",osgi.ee; osgi.ee="JavaSE"; version:List<Version>="1.0, 1.1, 1.2, 1.3, 1.4, 1.5, 1.6, 1.7"
org.osgi.framework.system.packages=javax.accessibility,javax.activation,javax.activity,javax.annotation,javax.annotation.processing,javax.crypto,javax.crypto.interfaces,javax.crypto.spec,javax.imageio,javax.imageio.event,javax.imageio.metadata,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax.imageio.spi,javax.imageio.stream,javax.jws,javax.jws.soap,javax.lang.model,javax.lang.model.element,javax.lang.model.type,javax.lang.model.util,javax.management,javax.management.event,javax.management.loading,javax.management.modelmbean,javax.management.monitor,javax.management.namespace,javax.management.openmbean,javax.management.relation,javax.management.remote,javax.management.remote.rmi,javax.management.timer,javax.naming,javax.naming.directory,javax.naming.event,javax.naming.ldap,javax.naming.spi,javax.net,javax.net.ssl,javax.print,javax.print.attribute,javax.print.attribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA,javax.rmi.ssl,javax.script,javax.security.auth,javax.security.auth.callback,javax.security.auth.kerberos,javax.security.auth.login,javax.security.auth.spi,javax.security.auth.x500,javax.security.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi.spi,javax.sound.sampled,javax.sound.sampled.spi,javax.sql,javax.sql.rowset,javax.sql.rowset.serial,javax.sql.rowset.spi,javax.swing,javax.swing.border,javax.swing.colorchooser,javax.swing.event,javax.swing.filechooser,javax.swing.plaf,javax.swing.plaf.basic,javax.swing.plaf.metal,javax.swing.plaf.multi,javax.swing.plaf.nimbus,javax.swing.plaf.synth,javax.swing.table,javax.swing.text,javax.swing.text.html,javax.swing.text.html.parser,javax.swing.text.rtf,javax.swing.tree,javax.swing.undo,javax.tools,javax.transaction,javax.transaction.xa,javax.xml,javax.xml.bind,javax.xml.bind.annotation,javax.xml.bind.annotation.adapters,javax.xml.bind.attachment,javax.xml.bind.helpers,javax.xml.bind.util,javax.xml.crypto,javax.xml.crypto.dom,javax.xml.crypto.dsig,javax.xml.crypto.dsig.dom,javax.xml.crypto.dsig.keyinfo,javax.xml.crypto.dsig.spec,javax.xml.datatype,javax.xml.namespace,javax.xml.parsers,javax.xml.soap,javax.xml.stream,javax.xml.stream.events,javax.xml.stream.util,javax.xml.transform,javax.xml.transform.dom,javax.xml.transform.sax,javax.xml.transform.stax,javax.xml.transform.stream,javax.xml.validation,javax.xml.ws,javax.xml.ws.handler,javax.xml.ws.handler.soap,javax.xml.ws.http,javax.xml.ws.soap,javax.xml.ws.spi,javax.xml.ws.spi.http,javax.xml.ws.wsaddressing,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage,org.omg.CORBA.portable,org.omg.CORBA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNaming.NamingContextExtPackage,org.omg.CosNaming.NamingContextPackage,org.omg.Dynamic,org.omg.DynamicAny,org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny.DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,org.omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInterceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org.omg.PortableServer,org.omg.PortableServer.CurrentPackage,org.omg.PortableServer.POAManagerPackage,org.omg.PortableServer.POAPackage,org.omg.PortableServer.portable,org.omg.PortableServer.ServantLocatorPackage,org.omg.SendingContext,org.omg.stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.css,org.w3c.dom.events,org.w3c.dom.html,org.w3c.dom.ls,org.w3c.dom.ranges,org.w3c.dom.stylesheets,org.w3c.dom.traversal,org.w3c.dom.views,org.w3c.dom.xpath,org.xml.sax,org.xml.sax.ext,org.xml.sax.helpers
org.osgi.framework.uuid=5071440f-ba9c-0012-1df6-ae9e2d74f2cd
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.6.0
org.osgi.supports.framework.extension=true
org.osgi.supports.framework.fragment=true
org.osgi.supports.framework.requirebundle=true
os.arch=x86
os.name=Windows 7
os.version=6.1
osgi.arch=x86
osgi.bundles=reference:file:javax.transaction_1.1.1.v201105210645.jar,reference:file:org.eclipse.equinox.simpleconfigurator_1.0.200.v20110815-1438.jar@1:start
osgi.bundles.defaultStartLevel=4
osgi.bundlestore=C:\Program Files\Eclipse JEE Indigo\eclipse\configuration\org.eclipse.osgi\bundles
osgi.configuration.area=file:/C:/Program Files/Eclipse JEE Indigo/eclipse/configuration/
osgi.framework=file:/c:/Program Files/Eclipse JEE Indigo/eclipse/plugins/org.eclipse.osgi_3.7.2.v20120110-1415.jar
osgi.framework.extensions=reference:file:javax.transaction_1.1.1.v201105210645.jar
osgi.framework.shape=jar
osgi.framework.version=3.7.2.v20120110-1415
osgi.frameworkClassPath=., file:c:/Program Files/Eclipse JEE Indigo/eclipse/plugins/javax.transaction_1.1.1.v201105210645.jar
osgi.install.area=file:/C:/Program Files/Eclipse JEE Indigo/eclipse/
osgi.instance.area=file:/C:/learningDB/
osgi.instance.area.default=file:/C:/Users/Developer/workspace/
osgi.logfile=C:\learningDB\.metadata\.log
osgi.manifest.cache=C:\Program Files\Eclipse JEE Indigo\eclipse\configuration\org.eclipse.osgi\manifests
osgi.nl=en_US
osgi.os=win32
osgi.splashLocation=C:\Program Files\Eclipse JEE Indigo\eclipse\\plugins\org.eclipse.platform_3.7.2.v201202080800\splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=c:\Program Files\Eclipse JEE Indigo\eclipse\plugins
osgi.tracefile=C:\learningDB\.metadata\trace.log
osgi.ws=win32
path.separator=;
product.home=/C:/Program Files/Eclipse JEE Indigo/eclipse/plugins/org.jboss.tools.common.model_3.3.1.v20130102-1651-H83-Final/
sun.arch.data.model=32
sun.boot.class.path=C:\Program Files\Java\jre7\lib\resources.jar;C:\Program Files\Java\jre7\lib\rt.jar;C:\Program Files\Java\jre7\lib\sunrsasign.jar;C:\Program Files\Java\jre7\lib\jsse.jar;C:\Program Files\Java\jre7\lib\jce.jar;C:\Program Files\Java\jre7\lib\charsets.jar;C:\Program Files\Java\jre7\lib\jfr.jar;C:\Program Files\Java\jre7\classes
sun.boot.library.path=C:\Program Files\Java\jre7\bin
sun.cpu.endian=little
sun.cpu.isalist=pentium_pro+mmx pentium_pro pentium+mmx pentium i486 i386 i86
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=Cp1252
sun.management.compiler=HotSpot Client Compiler
sun.os.patch.level=Service Pack 1
user.country=US
user.dir=C:\Program Files\Eclipse JEE Indigo\eclipse
user.home=C:\Users\Developer
user.language=en
user.name=Developer
user.script=
user.timezone=America/Los_Angeles
user.variant=
*** Features:
org.eclipse.cvs (1.3.100.v20110520-0800-7B78FHl9VF7BD7KBM4GP9C) "Eclipse CVS Client"
org.eclipse.datatools.common.doc.user (1.9.2.v201109161655-26-311A16321A3557) "Data Tools Platform User Documentation"
org.eclipse.datatools.connectivity.doc.user (1.9.2.v201109161655-37D-7733L3D753L7BBF) "Data Tools Platform Connectivity User Documentation"
org.eclipse.datatools.connectivity.feature (1.9.2.v201109161655-7C7e92Et1axl2OkbmSVP6fJgCpG) "Data Tools Platform Connectivity Plug-in"
org.eclipse.datatools.connectivity.oda.designer.core.feature (1.9.2.v201109161655-7B7C7HCcNBGRDTHWF_Ri) "DTP ODA Designer UI Framework Plug-in"
org.eclipse.datatools.connectivity.oda.designer.feature (1.9.2.v201109161655-4127w312312232267) "DTP ODA Designer UI Framework Plug-in"
org.eclipse.datatools.connectivity.oda.feature (1.9.2.v201109161655-7H7C7OCcNBHIEZHeFbLX) "DTP Open Data Access"
org.eclipse.datatools.doc.user (1.9.2.v201109161655-47C08w95FFAK89FHEC7) "Data Tool Platform User Documentation"
org.eclipse.datatools.enablement.apache.derby.feature (1.9.2.v201109161655-77788hBmKDQ2MoTTLwdv9ILX) "High-level Sybase Enablement Plug-in"
org.eclipse.datatools.enablement.feature (1.9.2.v201109161655-7J9B7UBWx_Q7338QL5SxTUtFvz0X) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.hsqldb.feature (1.9.2.v201109161655-67D2AqGBM7KfNTHwKO9ILX) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.ibm.feature (1.9.2.v201109161655-7F47SFC7sRdmSz0nz0bcci) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.ingres.feature (1.9.2.v201109161655-540AkF78Z7UCRAQDB) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.jdbc.feature (1.9.2.v201109161655-4-29oB5885QBB8HKW) "High-level Sybase Enablement Plug-in"
org.eclipse.datatools.enablement.jdt.feature (1.9.2.v201109161655-2-07w312218332612) "Data Tools Platform Connectivity JDT Extension Plug-in"
org.eclipse.datatools.enablement.msft.feature (1.9.2.v201109161655-544AkF7AL7MDMAOCS) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.mysql.feature (1.9.2.v201109161655-546AkF7AJ7d8JEOFC) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.oda.designer.feature (1.9.2.v201109161655-3358s7355573G57AI) "Eclipse Data Tools Platform XML ODA Designer"
org.eclipse.datatools.enablement.oda.feature (1.9.2.v201109161655-7A7T7BDZRDKGGZFrGhOd) "Eclipse Data Tools Platform XML ODA Runtime Driver"
org.eclipse.datatools.enablement.oracle.feature (1.9.2.v201109161655-548eAkF7AK7SDKBQ9K) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.postgresql.feature (1.9.2.v201109161655-552AkF7AJ9KAT9SFN) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.sap.feature (1.9.2.v201109161655-540AkF7AJ7YEJBU7S) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.sqlite.feature (1.9.2.v201109161655-541AkF7AI7TCLBQ7L) "Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.sybase.feature (1.9.2.v201109161655-7E46F9NiNc1QBgyT6T6) "High-level Sybase Enablement Plug-in"
org.eclipse.datatools.intro (1.9.2.v201109161655-26-7w312116392911) "Eclipse Data Tools Platform Intro Plug-in"
org.eclipse.datatools.modelbase.feature (1.9.2.v201109161655-7707CCcNBHIEQJXHUNf) "Eclipse Data Tools Platform SQLModel Plug-in"
org.eclipse.datatools.sqldevtools.ddlgen.feature (1.9.2.v201109161655-7A-77F7RZHQSImUlNvbu) "Eclipse Data Tools Platform FE UI Plug-in"
org.eclipse.datatools.sqldevtools.feature (1.9.2.v201109161655-7N847OFDsn3ivl-o7D-5qe3gjF1Q) "Eclipse Data Tools Platform SQL Tools Common UI Plug-in"
org.eclipse.datatools.sqldevtools.parsers.feature (1.9.2.v201109161655-623BgJ9EE9ZJRDZKE) "Eclipse Data Tools Platform SQL Parser Plugin"
org.eclipse.datatools.sqltools.doc.user (1.9.2.v201109161655-37D-7733L3D753L7BBF) "Data Tools Platform SQL Tools User Documentation"
org.eclipse.dltk.core (3.0.0.v20101211-0331-7l-2ED-z0UkhYdtV3_LBO) "Eclipse Dynamic Languages Toolkit"
org.eclipse.dltk.core.index (3.0.0.v20101026-0553-79--9oA5885GAJ) "Eclipse Dynamic Languages Toolkit Index"
org.eclipse.draw2d (3.7.2.v20110927-2020-4617w3122212803131) "Graphical Editing Framework Draw2d"
org.eclipse.emf (2.7.2.v20120130-0943) "EMF - Eclipse Modeling Framework Runtime and Tools"
org.eclipse.emf.codegen (2.7.0.v20120130-0943) "EMF Code Generation"
org.eclipse.emf.codegen.ecore (2.7.0.v20120130-0943) "EMF Ecore Code Generator"
org.eclipse.emf.codegen.ecore.ui (2.7.0.v20120130-0943) "EMF Ecore Code Generator UI"
org.eclipse.emf.codegen.ui (2.7.0.v20120130-0943) "EMF Code Generation UI"
org.eclipse.emf.common (2.7.0.v20120127-1122) "EMF Common"
org.eclipse.emf.common.ui (2.7.0.v20120130-0943) "EMF Common UI"
org.eclipse.emf.converter (2.7.0.v20120130-0943) "EMF Model Converter"
org.eclipse.emf.databinding (1.2.0.v20120130-0943) "EMF Data Binding"
org.eclipse.emf.databinding.edit (1.2.0.v20120130-0943) "EMF Edit Data Binding"
org.eclipse.emf.ecore (2.7.1.v20120127-1122) "EMF Ecore"
org.eclipse.emf.ecore.edit (2.7.1.v20120130-0943) "EMF Ecore Edit"
org.eclipse.emf.ecore.editor (2.7.0.v20120130-0943) "EMF Sample Ecore Editor"
org.eclipse.emf.edit (2.7.2.v20120130-0943) "EMF Edit"
org.eclipse.emf.edit.ui (2.7.0.v20120130-0943) "EMF Edit UI"
org.eclipse.emf.mapping (2.7.0.v20120130-0943) "EMF Mapping"
org.eclipse.emf.mapping.ecore (2.7.0.v20120130-0943) "EMF Ecore Mapping"
org.eclipse.emf.mapping.ecore.editor (2.7.0.v20120130-0943) "EMF Ecore Mapping Editor"
org.eclipse.emf.mapping.ui (2.7.0.v20120130-0943) "EMF Mapping UI"
org.eclipse.epp.mpc (1.1.1.I20110907-0947) "Marketplace Client"
org.eclipse.epp.package.jee.feature (1.4.2.20120213-0813) "Java EE IDE"
org.eclipse.gef (3.7.2.v20110927-2020-777D381B4Bz0755B465D34242) "Graphical Editing Framework GEF"
org.eclipse.graphiti.feature (0.8.2.v20120215-0845) "Graphiti UI (Incubation)"
org.eclipse.help (1.3.0.v20110530-0844-7i7uFFmFFl8nvqbDpEqTvx) "Help System Base"
org.eclipse.jdt (3.7.2.v20120120-1414-7z8gFcuFMP7BW5XTz0jLTnz0l9B1) "Eclipse Java Development Tools"
org.eclipse.jpt.common.eclipselink.feature (1.0.1.v201108080010-3-08s73553F3G3343) "Dali Java Persistence Tools - EclipseLink Common"
org.eclipse.jpt.common.feature (1.0.2.v201111103010-6-3AkF7BC9EBID797) "Dali Java Persistence Tools - Common"
org.eclipse.jpt.dbws.eclipselink.feature (1.0.2.v201202073020-797B5CcNBHGEQHTAwHJBF5) "Dali Java Persistence Tools - EclipseLink DBWS Support"
org.eclipse.jpt.jaxb.eclipselink.feature (1.0.2.v201202073020-7741BgJ9EEAREX8z0A9572) "Dali Java Persistence Tools - EclipseLink MOXy (JAXB) Support"
org.eclipse.jpt.jaxb.feature (1.0.2.v201111103010-508cAkF7BC8GBGA78A) "Dali Java Persistence Tools - JAXB Support"
org.eclipse.jpt.jpa.eclipselink.feature (3.0.2.v201202073020-7J7F7EF7RZHQQNYTz-KbSRNVB) "Dali Java Persistence Tools - EclipseLink JPA Support"
org.eclipse.jpt.jpa.feature (3.0.2.v201110193010-7S7B7HFC7sRdlV6fmbQaRBF5) "Dali Java Persistence Tools - JPA Support"
org.eclipse.jpt.jpadiagrameditor.feature (1.0.1.v201108100925-4-19oB5885P7C687B) "Dali Java Persistence Tools - JPA Diagram Editor"
org.eclipse.jst.common.fproj.enablement.jdt (3.3.0.v201102200555-377DF8s73543E5I5768) "Eclipse Faceted Project Framework JDT Enablement"
org.eclipse.jst.enterprise_ui.feature (3.3.2.v201111030500-7b7II1YFSK2WIuPRDEnExPV-RvTn) "Eclipse Java EE Developer Tools"
org.eclipse.jst.ws.axis2tools.feature (1.1.200.v201103022333-78-FF0DZRDKDDePSKwHj) "Axis2 Tools"
org.eclipse.jst.ws.cxf.feature (1.0.100.v201105171845-7H77DRFAKlZgjHCaHg65uE6I6I) "CXF Web Services Core"
org.eclipse.jst.ws.jaxws.feature (1.1.0.v201105171845-7E78BsF8NcJSWKvN1Rjcv) "JAX-WS Tools Core"
org.eclipse.mylyn_feature (3.6.5.v20120215-0100) "Mylyn"
org.eclipse.mylyn.bugzilla_feature (3.6.5.v20120215-0100) "Mylyn"
org.eclipse.mylyn.context_feature (3.6.5.v20120215-0100) "Mylyn"
org.eclipse.mylyn.ide_feature (3.6.5.v20120215-0100) "Mylyn"
org.eclipse.mylyn.java_feature (3.6.5.v20120215-0100) "Mylyn"
org.eclipse.mylyn.team_feature (3.6.5.v20120215-0100) "Mylyn"
org.eclipse.mylyn.wikitext_feature (1.5.5.v20120215-0100) "Mylyn"
org.eclipse.pde (3.7.2.v20120120-1420-7b7rFUOFEx2Xnqafnpz0E--0) "PDE"
org.eclipse.php (3.0.1.v201201110400-7V-79F8NcJTcJTTTJwJJ) "PDT Plug-in"
org.eclipse.platform (3.7.2.v20120207-1839-9gF7UHPDFxGjd-PqDr2jX_4yKaumkoHTz04_q-q) "Eclipse Platform"
org.eclipse.rcp (3.7.2.v20120120-1424-9DB5FmnFq5JCf1UA38R-kz0S0272) "Eclipse RCP"
org.eclipse.rse (3.3.2.R33x_v201110030150-7L7CFGH8wqio8s-qYtkPgn8qWd4T) "Remote System Explorer End-User Runtime"
org.eclipse.rse.core (3.3.2.R33x_v201110030150-7a7JFZ4F8Fz0vz03_qRujci-z-Mp) "RSE Core"
org.eclipse.rse.dstore (3.3.1.R33x_v201109141647-7L78FRAD2YR70wUHbQUplQ8LFC) "RSE DStore Services"
org.eclipse.rse.ftp (3.0.301.R33x_v201109141647-782F8O9KC92gz097E9EKF23225) "RSE FTP Service"
org.eclipse.rse.local (2.1.300.v201103142315-7B4FKsBgJ9EE9ICQIFYT) "RSE Local Services"
org.eclipse.rse.ssh (3.0.301.R33x_v201109141647-7A3F9xAGGB5k0C7KEATN92641) "RSE SSH Services"
org.eclipse.rse.telnet (2.2.200.v201106011538-775F8NAkF7BB7B9NEIPP) "RSE Telnet Service"
org.eclipse.rse.terminals (1.1.1.R33x_v201109141647-771Bh9uD7HbBF3u7DNO3293A3752) "RSE Terminals UI"
org.eclipse.rse.useractions (1.1.300.v201103142315-31F8N8s7355353B75DD) "Remote System Explorer User Actions"
org.eclipse.tm.terminal (3.1.1.R33x_v201106281309-4007S44yaw312218292641) "Target Management Terminal Widget"
org.eclipse.tm.terminal.ssh (2.1.0.v201103142315-30-7w312212153266) "Target Management Terminal SSH Connector"
org.eclipse.tm.terminal.telnet (2.1.0.v201103142315-30-7w312213121A22) "Target Management Terminal Telnet Connector"
org.eclipse.tm.terminal.view (2.2.0.v201103142315-31-7w312214253426) "Target Management Terminal View"
org.eclipse.wst.common.fproj (3.3.2.v201201121600-377DH8s735735535DD9) "Eclipse Faceted Project Framework"
org.eclipse.wst.jsdt.feature (1.3.2.v201201112313-7G78FZvFC7sRekSz-g-nAlz) "Eclipse JavaScript Development Tools"
org.eclipse.wst.web_ui.feature (3.3.2.v201111030500-7O7IFj6EMjB7yO1Xs_G1kMtQeOye6HTXFWve95_R) "Eclipse Web Developer Tools"
org.eclipse.wst.xml_ui.feature (3.3.2.v201112072049-7H7EFZ7DxumTmce4khcSkIiqoD8eDMKlT8Oz011P) "Eclipse XML Editors and Tools"
org.eclipse.wst.xml.xpath2.processor.feature (2.0.0.v201103310043-7A7J-CcNBGOCUIWFYMf) "Eclipse XPath 2 Developers Tools"
org.eclipse.wst.xsl.feature (1.3.1.v201109012200-7T7YFRTFIqUoIrvbEtBlSIJXGZNg) "Eclipse XSL Developer Tools"
org.hibernate.eclipse.feature (3.5.1.v20130102-1835-H100-Final) "Hibernate Tools"
*** Plug-in Registry:
com.ibm.icu (4.4.2.v20110823) "International Components for Unicode for Java (ICU4J)" [Active]
com.jcraft.jsch (0.1.44.v201101211721) "JSch" [Resolved]
com.sun.syndication (0.9.0.v200803061811) "Rss and atOM utilitiEs (ROME)" [Resolved]
java_cup.runtime (0.10.0.v201005080400) "Java Cup" [Resolved]
javax.activation (1.1.0.v201105071233) "Apache Geronimo Activation Plug-in" [Resolved]
javax.jws (2.0.0.v201005080400) "Web Services Metadata" [Resolved]
javax.mail (1.4.0.v201005080615) "Javax Mail Plug-in" [Resolved]
javax.persistence (2.0.3.v201010191057) "Java Persistence API 2.0" [Resolved]
javax.servlet (2.5.0.v201103041518) "Servlet API Bundle" [Resolved]
javax.servlet.jsp (2.0.0.v201101211617) "Java Server Pages API Bundle" [Resolved]
javax.transaction (1.1.1.v201105210645) "geronimo Javax Transaction API 1.1.1 spec" [Resolved]
javax.wsdl (1.5.1.v201012040544) "WSDL4J" [Resolved]
javax.wsdl (1.6.2.v201012040545) "WSDL4J" [Resolved]
javax.xml (1.3.4.v201005080400) "JAXP XML" [Resolved]
javax.xml.bind (2.1.9.v201005080401) "XML Binding for Java" [Resolved]
javax.xml.rpc (1.1.0.v201005080400) "JAX-RPC" [Resolved]
javax.xml.soap (1.2.0.v201005080501) "SAAJ" [Resolved]
javax.xml.stream (1.0.1.v201004272200) "Java XML Streaming API" [Resolved]
javax.xml.ws (2.1.0.v200902101523) "Java API for XML Web Services (JAX-WS)" [Resolved]
net.sourceforge.lpg.lpgjavaruntime (1.1.0.v201004271650) "SourceForge LPG" [Resolved]
org.apache.ant (1.8.2.v20120109-1030) "Apache Ant" [Resolved]
org.apache.axis (1.4.0.v201005080400) "Apache Web Services" [Resolved]
org.apache.bcel (5.2.0.v201005080400) "Apache BCEL" [Resolved]
org.apache.commons.codec (1.3.0.v201101211617) "Apache Commons Codec Plug-in" [Resolved]
org.apache.commons.collections (3.2.0.v201005080500) "Apache Commons Collections" [Resolved]
org.apache.commons.discovery (0.2.0.v201004190315) "Jakarta-Commons Discovery" [Resolved]
org.apache.commons.el (1.0.0.v201101211617) "Apache Commons JSP 2.0 Expression Language Interpreter" [Resolved]
org.apache.commons.httpclient (3.1.0.v201012070820) "Apache Commons Httpclient" [Resolved]
org.apache.commons.lang (2.1.0.v201005080500) "Apache Jakarta Commons Lang" [Resolved]
org.apache.commons.lang (2.4.0.v201005080502) "Apache Jakarta Commons Lang" [Resolved]
org.apache.commons.logging (1.0.4.v201101211617) "Apache Commons Logging Plug-in" [Resolved]
org.apache.commons.net (2.2.0.v201101241833) "Apache Commons Net" [Resolved]
org.apache.derby.core (10.8.1.2) "Apache Derby Core Plug-in for Eclipse" [Resolved]
org.apache.derby.plugin.doc (1.1.3) "Apache Derby Plug-in Documentation for Eclipse" [Starting]
org.apache.derby.ui (1.1.3) "Apache Derby Ui Plug-in for Eclipse" [Starting]
org.apache.jasper (5.5.17.v201101211617) "Apache Jasper 2 Plug-in" [Resolved]
org.apache.log4j (1.2.15.v201012070815) "Apache Jakarta log4j Plug-in" [Resolved]
org.apache.lucene (1.9.1.v201101211617) "Apache Lucene" [Resolved]
org.apache.lucene (2.9.1.v201101211721) "Apache Lucene" [Resolved]
org.apache.lucene.analysis (2.9.1.v201101211721) "Apache Lucene Analysis" [Resolved]
org.apache.lucene.core (2.9.1.v201101211721) "Apache Lucene Core" [Resolved]
org.apache.lucene.highlighter (2.9.1.v20100421-0704) "Apache Lucene Highlighter" [Resolved]
org.apache.lucene.memory (2.9.1.v20100421-0704) "Apache Lucene Memory" [Resolved]
org.apache.lucene.misc (2.9.1.v20100421-0704) "Apache Lucene Misc" [Resolved]
org.apache.lucene.queries (2.9.1.v20100421-0704) "Apache Lucene Queries" [Resolved]
org.apache.lucene.snowball (2.9.1.v20100421-0704) "Apache Lucene Snowball" [Resolved]
org.apache.lucene.spellchecker (2.9.1.v20100421-0704) "Apache Lucene Spellchecker" [Resolved]
org.apache.oro (2.0.8.v201005080400) "Apache Jakarta ORO" [Resolved]
org.apache.velocity (1.5.0.v200905192330) "Apache Velocity Plug-in" [Resolved]
org.apache.ws.commons.util (1.0.1.v20100518-1140) "WS Commons Util Plug-in" [Resolved]
org.apache.wsil4j (1.0.0.v200901211807) "WSIL4J" [Resolved]
org.apache.xalan (2.7.1.v201005080400) "Xalan-Java" [Resolved]
org.apache.xerces (2.9.0.v201101211617) "Apache Xerces-J" [Resolved]
org.apache.xml.resolver (1.2.0.v201005080400) "Apache XmlResolver" [Resolved]
org.apache.xml.serializer (2.7.1.v201005080400) "Apache XML Commons Serializer" [Resolved]
org.apache.xmlrpc (3.0.0.v20100427-1100) "Apache XML-RPC Plug-in" [Resolved]
org.eclipse.ant.core (3.2.302.v20120110-1739) "Ant Build Tool Core" [Starting]
org.eclipse.ant.launching (1.0.101.v20120110-1739) "Ant Launching Support" [Starting]
org.eclipse.ant.ui (3.5.101.v20120110-1739) "Ant UI" [Starting]
org.eclipse.compare (3.5.202.R37x_v20111109-0800) "Compare Support" [Starting]
org.eclipse.compare.core (3.5.200.I20110208-0800) "Core Compare Support" [Active]
org.eclipse.compare.win32 (1.0.200.I20110510-0800) "Compare Support for Word" [Starting]
org.eclipse.core.boot (3.1.200.v20100505) "Core Boot" [Starting]
org.eclipse.core.commands (3.6.0.I20110111-0800) "Commands" [Resolved]
org.eclipse.core.contenttype (3.4.100.v20110423-0524) "Eclipse Content Mechanism" [Active]
org.eclipse.core.databinding (1.4.0.I20110111-0800) "JFace Data Binding" [Starting]
org.eclipse.core.databinding.beans (1.2.100.I20100824-0800) "JFace Data Binding for JavaBeans" [Resolved]
org.eclipse.core.databinding.observable (1.4.0.I20110222-0800) "JFace Data Binding Observables" [Active]
org.eclipse.core.databinding.property (1.4.0.I20110222-0800) "JFace Data Binding" [Starting]
org.eclipse.core.expressions (3.4.300.v20110228) "Expression Language" [Active]
org.eclipse.core.externaltools (1.0.100.v20111007_r372) "External Tools Headless Support" [Starting]
org.eclipse.core.filebuffers (3.5.200.v20110928-1504) "File Buffers" [Active]
org.eclipse.core.filesystem (1.3.100.v20110423-0524) "Core File Systems" [Active]
org.eclipse.core.filesystem.win32.x86 (1.1.300.v20110423-0524) "Core File System for Windows" [Resolved]
org.eclipse.core.jobs (3.5.101.v20120113-1953) "Eclipse Jobs Mechanism" [Active]
org.eclipse.core.net (1.2.100.I20110511-0800) "Internet Connection Management" [Active]
org.eclipse.core.net.win32.x86 (1.0.100.I20110331-0827) "Proxy for Windows" [Resolved]
org.eclipse.core.resources (3.7.101.v20120125-1505) "Core Resource Management" [Active]
org.eclipse.core.resources.win32.x86 (3.5.100.v20110423-0524) "Core Resource Management Win32 Fragment" [Resolved]
org.eclipse.core.runtime (3.7.0.v20110110) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.2.100.v20100505) "Core Runtime Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.200.v20110110) "Authorization Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.registry (3.5.0.v20110505) "Eclipse Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.2.500.v20110928-1503) "Core Variables" [Active]
org.eclipse.cvs (1.1.100.v201202080800) "Eclipse CVS Client" [Starting]
org.eclipse.datatools.common.doc.user (1.7.0.20090521092446) "Data Tools Platform User Documentation" [Starting]
org.eclipse.datatools.connectivity (1.2.4.v201202041105) "Data Tools Platform Connectivity Plug-in" [Starting]
org.eclipse.datatools.connectivity.apache.derby (1.0.102.v201107221459) "Eclipse Data Tools Platform Derby Plug-in" [Starting]
org.eclipse.datatools.connectivity.apache.derby.dbdefinition (1.0.2.v201107221459) "Eclipse Data Tools Platform Apache Derby Database Definition" [Starting]
org.eclipse.datatools.connectivity.apache.derby.ui (1.0.3.v201107221459) "Eclipse Data Tools Platform Apache Derby UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.console.profile (1.0.10.v201109250955) "DTP Connection Profiles Storage File Editor Plug-in" [Starting]
org.eclipse.datatools.connectivity.db.generic (1.0.1.v201107221459) "Eclipse Data Tools Platform Generic DB Connectivity Plug-in" [Starting]
org.eclipse.datatools.connectivity.db.generic.ui (1.0.1.v201107221459) "Eclipse Data Tools Platform Generic DB UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.dbdefinition.genericJDBC (1.0.1.v201107221459) "Eclipse Data Tools Platform DBDefinition Generic JDBC Plug-in" [Starting]
org.eclipse.datatools.connectivity.doc.user (1.7.0.20090521092446) "Data Tools Platform Connectivity User Documentation" [Starting]
org.eclipse.datatools.connectivity.doc.user.contexts (1.7.0.20090521092446) "Data Tools Platform Connectivity User Documentation for context-sensitive help" [Starting]
org.eclipse.datatools.connectivity.oda (3.3.3.v201110130935) "DTP Open Data Access" [Starting]
org.eclipse.datatools.connectivity.oda.consumer (3.2.5.v201109151100) "DTP ODA Consumer Helper Component Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.design (3.3.4.v201109211529) "DTP ODA Design Session Model" [Starting]
org.eclipse.datatools.connectivity.oda.design.ui (3.2.6.v201112151316) "DTP ODA Designer UI Framework Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.flatfile (3.1.2.v201112081200) "Eclipse Data Tools Platform Flat File ODA Runtime Driver" [Starting]
org.eclipse.datatools.connectivity.oda.flatfile.ui (3.1.2.v201201101437) "Eclipse Data Tools Platform Flat File ODA Designer" [Starting]
org.eclipse.datatools.connectivity.oda.profile (3.2.7.v201112290953) "DTP ODA Connection Profile Framework Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.template.ui (3.2.3.v201201121156) "DTP ODA New Plug-in Template Wizard" [Starting]
org.eclipse.datatools.connectivity.sqm.core (1.2.4.v201201131116) "Eclipse Data Tools Platform SQM Core Plug-in" [Starting]
org.eclipse.datatools.connectivity.sqm.core.ui (1.2.1.v20110926045) "Eclipse Data Tools Platform SQM UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.sqm.server.ui (1.1.100.v201107221459) "Eclipse Data Tools Platform Server UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.ui (1.2.2.v201111190813) "Data Tools Platform Connectivity UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.ui.dse (1.1.4.v201107221459) "Eclipse Data Tools Platform Data Source Explorer Plug-in" [Starting]
org.eclipse.datatools.doc.user (1.7.0.20090521092446) "Data Tool Platform User Documentation" [Starting]
org.eclipse.datatools.enablement.finfo (1.5.1.v200906161800) "Eclipse Data Tools Platform Enablement" [Starting]
org.eclipse.datatools.enablement.hsqldb (1.0.0.v201107221502) "Eclipse Data Tools Platform HSQLDB Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.hsqldb.dbdefinition (1.0.0.v201107221502) "Eclipse Data Tools Platform HSQLDB Database Definition Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.hsqldb.ui (1.0.0.v201108120600) "Eclipse Data Tools Platform HSQLDB UI Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries (1.0.2.v201107221502) "Eclipse Data Tools Platform IBM DB2 UDB iSeries Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries.dbdefinition (1.0.3.v201107221502) "DB2 UDB iSeries Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries.ui (1.0.1.v201108130630) "Eclipse Data Tools Platform IBM DB2 UDB UI iSeries Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.luw (1.0.2.v201107221502) "Eclipse Data Tools Platform IBM DB2 UDB LUW Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.luw.dbdefinition (1.0.4.v201107221502) "Eclipse Data Tools Platform DB2 UDB Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.luw.ui (1.0.2.v201108130630) "Eclipse Data Tools Platform IBM DB2 UDB LUW UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries (1.0.2.v201107221502) "Eclipse Data Tools Platform IBM DB2 UDB zSeries Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries.dbdefinition (1.0.4.v201107221502) "DB2 UDB Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries.ui (1.0.1.v201108130630) "Eclipse Data Tools Platform IBM DB2 UDB zSeries UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.informix (1.0.1.v201107221502) "Eclipse Data Tools Platform Informix Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.informix.dbdefinition (1.0.4.v201107221502) "Eclipse Data Tools Platform Informix Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.informix.ui (1.0.2.v201108130630) "Eclipse Data Tools Platform Informix UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.ui (1.0.0.v201107221502) "Eclipse Data Tools Platform IBM UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ingres (1.0.0.v200906111150) "Ingres DTP Plug-in" [Starting]
org.eclipse.datatools.enablement.ingres.dbdefinition (1.0.0.v200906161800) "Ingres DTP Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ingres.ui (1.0.0.v201105270214) "Ingres DTP UI Plug-in" [Starting]
org.eclipse.datatools.enablement.jdt.classpath (1.0.1.v201107221501) "Data Tools Platform Connectivity JDT Extension Plug-in" [Starting]
org.eclipse.datatools.enablement.msft.sqlserver (1.0.1.v201107221504) "Eclipse Data Tools Platform Microsoft SQL Server Plug-in" [Starting]
org.eclipse.datatools.enablement.msft.sqlserver.dbdefinition (1.0.1.v201201240349) "Eclipse Data Tools Platform SQL Server Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.msft.sqlserver.ui (1.0.2.v201201131118) "Eclipse Data Tools Platform Microsoft SQL Server UI Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql (1.0.2.v201109022323) "Eclipse Data Tools Platform MySQL Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql.dbdefinition (1.0.4.v201109022331) "Eclipse Data Tools Platform MySQL Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql.ui (1.0.0.v201109022331) "Eclipse Data Tools Platform MySQL UI Plug-in" [Starting]
org.eclipse.datatools.enablement.oda.ws (1.2.3.v201112061438) "Eclipse Data Tools Platform Web Services ODA Runtime Driver" [Starting]
org.eclipse.datatools.enablement.oda.ws.ui (1.2.3.v201112061438) "Eclipse Data Tools Platform Web Services ODA Designer" [Starting]
org.eclipse.datatools.enablement.oda.xml (1.2.3.v201112061438) "Eclipse Data Tools Platform XML ODA Runtime Driver" [Starting]
org.eclipse.datatools.enablement.oda.xml.ui (1.2.3.v201112071047) "Eclipse Data Tools Platform XML ODA Designer" [Starting]
org.eclipse.datatools.enablement.oracle (1.0.0.v201107221506) "Eclipse Data Tools Platform Oracle Plug-in" [Starting]
org.eclipse.datatools.enablement.oracle.dbdefinition (1.0.102.v201107221506) "Eclipse Data Tools Platform Oracle Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.oracle.ui (1.0.3.v201201131121) "Eclipse Data Tools Platform Oracle UI Plug-in" [Starting]
org.eclipse.datatools.enablement.postgresql (1.1.0.v201110070445) "PostgreSQL Connection Profile and Driver Template Plug-in" [Starting]
org.eclipse.datatools.enablement.postgresql.dbdefinition (1.0.2.v201110070445) "PostgreSQL DB Definition" [Starting]
org.eclipse.datatools.enablement.postgresql.ui (1.0.0.v201107221506) "PostgreSQL Connection Profile and Driver Template UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sap.maxdb (1.0.0.v201107221507) "Eclipse Data Tools Platform MaxDB Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sap.maxdb.dbdefinition (1.0.0.v201107221507) "Eclipse Data Tools Platform MaxDB Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.sap.maxdb.ui (1.0.0.v201107221507) "Eclipse Data Tools Platform MaxDB UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sqlite (1.0.0.v201002041100) "Eclipse Data Tools Platform SQLite Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sqlite.dbdefinition (1.0.1.v201107221507) "Eclipse Data Tools Platform SQLite Database Definition Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sqlite.ui (1.0.0.v201107221507) "Eclipse Data Tools Platform SQLite UI Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase (1.0.1.v201107221507) "High-level Sybase Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.asa (1.0.1.v201107221507) "Sybase ASA Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.asa.dbdefinition (1.0.0.v200906161800) "Eclipse Data Tools Platform Sybase ASA Database Definition" [Starting]
org.eclipse.datatools.enablement.sybase.asa.models (1.0.0.v201107221507) "Sybase ASA SQL Model" [Starting]
org.eclipse.datatools.enablement.sybase.asa.schemaobjecteditor.examples (2.5.0.200810071) "Sybase ASA Schema Object Editor" [Starting]
org.eclipse.datatools.enablement.sybase.asa.ui (1.0.1.v200906111204) "Sybase ASA Connection Profile UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ase (1.0.2.v201201131122) "JDBC/Sybase ASE Connection Profile Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ase.dbdefinition (1.0.0.v201107221507) "Eclipse Data Tools Platform Sybase ASE Database Definition" [Starting]
org.eclipse.datatools.enablement.sybase.ase.models (1.0.1.v201010140307) "Sybase ASE Model Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ase.ui (1.0.1.v200906020900) "ASE Enablement UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.models (1.0.0.v201010140307) "Sybase Model Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ui (1.0.0.v200906090452) "Sybase UI Plug-in" [Starting]
org.eclipse.datatools.help (1.5.0.v200906020553) "Data Tools Platform Help Utilities" [Resolved]
org.eclipse.datatools.intro (1.7.0.v201005281800) "Eclipse Data Tools Platform Intro Plug-in" [Resolved]
org.eclipse.datatools.modelbase.dbdefinition (1.0.2.v201107221519) "Eclipse Data Tools Platform DBDefinition Model" [Starting]
org.eclipse.datatools.modelbase.derby (1.0.0.v201107221519) "Eclipse Data Tools Platform Derby Model Plug-in" [Starting]
org.eclipse.datatools.modelbase.sql (1.0.5.v201110151330) "Eclipse Data Tools Platform SQLModel Plug-in" [Starting]
org.eclipse.datatools.modelbase.sql.edit (1.0.1.v201107221519) "Eclipse Data Tools Platform SQLModel Edit Plug-in" [Starting]
org.eclipse.datatools.modelbase.sql.query (1.1.2.v201110151315) "Eclipse Data Tools Platform SQL Query Model Plugin" [Starting]
org.eclipse.datatools.modelbase.sql.query.edit (1.0.1.v201110151245) "SQL Query Edit Support Plugin" [Starting]
org.eclipse.datatools.modelbase.sql.xml.query (1.0.2.v201201131123) "Eclipse Data Tools Platform SQL XML Query Model Plugin" [Starting]
org.eclipse.datatools.oda.cshelp (1.1.1.v201107221500) "DTP ODA Context-sensitive Help" [Starting]
org.eclipse.datatools.sqltools.common.ui (1.0.0.v201107221520) "Eclipse Data Tools Platform SQL Tools Common UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.data.core (1.2.1.v201110050500) "Data Core Plugin" [Starting]
org.eclipse.datatools.sqltools.data.ui (1.2.1.v201010270945) "Data UI Plugin" [Starting]
org.eclipse.datatools.sqltools.db.derby (1.0.0.v201107221520) "Eclipse Data Tools Platform Derby SQL Tools Plug-in" [Starting]
org.eclipse.datatools.sqltools.db.derby.ui (1.0.0.v200906020900) "Eclipse Data Tools Platform Derby SQL Tools UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.db.generic (1.0.0.v201107221520) "Eclipse Data Tools Platform SQL Tools Generic Database Plug-in" [Starting]
org.eclipse.datatools.sqltools.db.generic.ui (1.0.0.v200906020900) "Eclipse Data Tools Platform SQL Tools Generic Database UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.ddlgen.ui (1.0.2.v201201131129) "Eclipse Data Tools Platform FE UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.debugger.core (1.0.1.v201107221520) "Eclipse Data Tools Platform SQL Debugger Framework" [Starting]
org.eclipse.datatools.sqltools.debugger.core.ui (1.0.0.v201003161000) "Eclipse Data Tools Platform SQL Debugger UI Framework" [Starting]
org.eclipse.datatools.sqltools.doc.user (1.7.0.20090521092446) "Data Tools Platform SQL Tools User Documentation" [Starting]
org.eclipse.datatools.sqltools.doc.user.contexts (1.7.0.20090521092446) "Data Tools Platform SQL Tools User Documentation for context-sensitive help" [Starting]
org.eclipse.datatools.sqltools.editor.core (1.0.1.v201201131129) "Eclipse Data Tools Platform SQL Editor Core Plug-in" [Starting]
org.eclipse.datatools.sqltools.editor.core.ui (1.0.0.v201001150815) "Eclipse Data Tools Platform SQL Editor Core UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.parsers.sql (1.0.2.v201107221520) "Eclipse Data Tools Platform SQL Parser Plugin" [Starting]
org.eclipse.datatools.sqltools.parsers.sql.lexer (1.0.1.v201107221520) "Eclipse Data Tools Platform Lexer Plug-in" [Starting]
org.eclipse.datatools.sqltools.parsers.sql.query (1.2.1.v201201250505) "Eclipse Data Tools Platform SQL Query Parser Plugin" [Starting]
org.eclipse.datatools.sqltools.parsers.sql.xml.query (1.0.0.v201107221520) "Eclipse Data Tools Platform SQL XML Query Parser Plugin" [Starting]
org.eclipse.datatools.sqltools.plan (1.0.0.v201107221520) "Eclipse Data Tools Platform SQL Execution Plan View Plug-in" [Starting]
org.eclipse.datatools.sqltools.result (1.1.2.v201201131129) "Eclipse Data Tools Platform SQL Results View Plug-ins" [Starting]
org.eclipse.datatools.sqltools.result.ui (1.1.2.v201110010535) "Eclipse Data Tools Platform SQL Results View UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.routineeditor (1.0.0.v201107221520) "Eclipse Data Tools Platform SQL Tools Routine Editor Plug-in" [Starting]
org.eclipse.datatools.sqltools.routineeditor.ui (1.0.2.v201111230714) "Eclipse Data Tools Platform SQL Tools Routine Editor UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.schemaobjecteditor (1.1.0.v200906022302) "Schema Object Editor Plug-in" [Starting]
org.eclipse.datatools.sqltools.schemaobjecteditor.ui (1.1.1.200810071) "Schema Object Editor Framework" [Starting]
org.eclipse.datatools.sqltools.schemaobjecteditor.ui.pages (1.1.0.200810071) "Schema Object Editor Pages Plug-in" [Starting]
org.eclipse.datatools.sqltools.sql (1.0.1.v201110050515) "Eclipse Data Tools Platform SQL Core Plug-in" [Starting]
org.eclipse.datatools.sqltools.sql.ui (1.0.1.v201201270743) "Eclipse Data Tools Platform SQL Core UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.sqlbuilder (1.0.3.v201107221520) "SQL Builder" [Starting]
org.eclipse.datatools.sqltools.sqleditor (1.0.2.v201107221520) "Eclipse Data Tools Platform SQL Editor" [Starting]
org.eclipse.datatools.sqltools.sqlscrapbook (1.0.1.v201107221520) "Eclipse Data Tools Platform Sqlscrapbook Plug-in" [Starting]
org.eclipse.datatools.sqltools.tabledataeditor (1.0.1.v201005250945) "Eclipse Data Tools Platform Table Data Editor Plug-in" [Starting]
org.eclipse.debug.core (3.7.1.v20111129-2031) "Debug Core" [Active]
org.eclipse.debug.ui (3.7.102.v20111129-1423_r372) "Debug UI" [Starting]
org.eclipse.dltk (3.0.0.v20101209) "Eclipse Dynamic Languages Toolkit" [Resolved]
org.eclipse.dltk.console (3.0.0.v20101211-0412) "Dynamic Languages Toolkit Console Core" [Starting]
org.eclipse.dltk.console.ui (3.0.0.v20101212-1106) "Dynamic Languages Toolkit Console UI" [Starting]
org.eclipse.dltk.core (3.0.1.v20110823) "Dynamic Languages Toolkit Core" [Active]
org.eclipse.dltk.core.index (3.0.0.v20110429) "Eclipse Dynamic Languages Toolkit Index" [Resolved]
org.eclipse.dltk.core.index.sql (3.0.0.v20110423) "DLTK Abstract SQL-based Indexer" [Starting]
org.eclipse.dltk.core.index.sql.h2 (3.0.0.v20110423) "DLTK H2-based Indexer" [Starting]
org.eclipse.dltk.core.manipulation (3.0.0.v20110609-1525) "pluginName" [Starting]
org.eclipse.dltk.debug (3.0.1.v20110824) "Dynamic Languages Toolkit Debug Core" [Starting]
org.eclipse.dltk.debug.ui (3.0.0.v20110423) "Dynamic Languages Toolkit Debug UI" [Starting]
org.eclipse.dltk.formatter (3.0.0.v20110609-1525) "Dynamic Languages Toolkit Formatter" [Starting]
org.eclipse.dltk.launching (3.0.0.v20110423) "Dynamic Languages Toolkit Launching Core" [Active]
org.eclipse.dltk.logconsole (3.0.0.v20110424) "Dynamic Languages Toolkit LogConsole" [Starting]
org.eclipse.dltk.logconsole.ui (3.0.0.v20110424) "Dynamic Languages Toolkit LogConsole UI" [Resolved]
org.eclipse.dltk.testing (3.0.0.v20110423) "Dynamic Languages Toolkit Testing Frameworks Support" [Starting]
org.eclipse.dltk.ui (3.0.1.v20110823) "Dynamic Languages Toolkit Core UI" [Active]
org.eclipse.dltk.validators.core (3.0.0.v20110423) "Dynamic Languages Toolkit Validators Core" [Starting]
org.eclipse.dltk.validators.externalchecker (3.0.0.v20110423) "Dynamic Languages Toolkit Validators UI" [Starting]
org.eclipse.dltk.validators.ui (3.0.0.v20110423) "Dynamic Languages Toolkit Validators UI" [Starting]
org.eclipse.draw2d (3.7.2.v20111017-2020) "Graphical Editing Framework Draw2d" [Starting]
org.eclipse.dstore.core (3.3.1.R33x_v201107181530) "RSE DStore Core" [Starting]
org.eclipse.dstore.extra (2.1.300.v201101042155) "RSE DStore Platform Support" [Starting]
org.eclipse.ecf (3.1.300.v20110531-2218) "ECF Core API" [Starting]
org.eclipse.ecf.filetransfer (5.0.0.v20110531-2218) "ECF Filetransfer API" [Starting]
org.eclipse.ecf.identity (3.1.100.v20110531-2218) "ECF Core Identity API" [Starting]
org.eclipse.ecf.provider.filetransfer (3.2.0.v20110531-2218) "ECF Filetransfer Provider" [Starting]
org.eclipse.ecf.provider.filetransfer.httpclient (4.0.0.v20110531-2218) "ECF HttpClient Filetransfer Provider" [Starting]
org.eclipse.ecf.provider.filetransfer.httpclient.ssl (1.0.0.v20110531-2218) "ECF HttpClient Filetransfer Provider" [Resolved]
org.eclipse.ecf.provider.filetransfer.ssl (1.0.0.v20110531-2218) "ECF Filetransfer Provider" [Resolved]
org.eclipse.ecf.ssl (1.0.100.v20110531-2218) "ECF Core API" [Resolved]
org.eclipse.emf (2.6.0.v20120130-0943) "EMF - Eclipse Modeling Framework Runtime and Tools" [Starting]
org.eclipse.emf.ant (2.7.0.v20120130-0943) "EMF Ant Tasks" [Starting]
org.eclipse.emf.codegen (2.6.0.v20120130-0943) "EMF Code Generation" [Starting]
org.eclipse.emf.codegen.ecore (2.7.0.v20120130-0943) "EMF Ecore Code Generator" [Starting]
org.eclipse.emf.codegen.ecore.ui (2.7.0.v20120130-0943) "EMF Ecore Code Generator UI" [Starting]
org.eclipse.emf.codegen.ui (2.6.0.v20120130-0943) "EMF Code Generation UI" [Starting]
org.eclipse.emf.common (2.7.0.v20120127-1122) "EMF Common" [Active]
org.eclipse.emf.common.ui (2.7.0.v20120130-0943) "EMF Common UI" [Active]
org.eclipse.emf.converter (2.5.0.v20120130-0943) "EMF Model Converter" [Starting]
org.eclipse.emf.databinding (1.2.0.v20120130-0943) "EMF Data Binding" [Starting]
org.eclipse.emf.databinding.edit (1.2.0.v20120130-0943) "EMF Edit Data Binding" [Starting]
org.eclipse.emf.ecore (2.7.0.v20120127-1122) "EMF Ecore" [Active]
org.eclipse.emf.ecore.change (2.7.1.v20120127-1122) "EMF Change Model" [Starting]
org.eclipse.emf.ecore.change.edit (2.5.0.v20120130-0943) "EMF Change Edit" [Starting]
org.eclipse.emf.ecore.edit (2.7.1.v20120130-0943) "EMF Ecore Edit" [Starting]
org.eclipse.emf.ecore.editor (2.7.0.v20120130-0943) "EMF Sample Ecore Editor" [Starting]
org.eclipse.emf.ecore.xmi (2.7.0.v20120127-1122) "EMF XML/XMI Persistence" [Active]
org.eclipse.emf.edit (2.7.2.v20120130-0943) "EMF Edit" [Active]
org.eclipse.emf.edit.ui (2.7.0.v20120130-0943) "EMF Edit UI" [Active]
org.eclipse.emf.exporter (2.6.0.v20120130-0943) "EMF Model Exporter" [Starting]
org.eclipse.emf.importer (2.6.0.v20120130-0943) "EMF Model Importer" [Starting]
org.eclipse.emf.importer.ecore (2.6.0.v20120130-0943) "EMF Ecore Importer" [Starting]
org.eclipse.emf.importer.java (2.6.0.v20120130-0943) "EMF Annotated Java Importer" [Starting]
org.eclipse.emf.importer.rose (2.6.0.v20120130-0943) "EMF Rose Importer" [Starting]
org.eclipse.emf.mapping (2.7.0.v20120130-0943) "EMF Mapping" [Starting]
org.eclipse.emf.mapping.ecore (2.6.0.v20120130-0943) "EMF Ecore Mapping" [Starting]
org.eclipse.emf.mapping.ecore.editor (2.6.0.v20120130-0943) "EMF Ecore Mapping Editor" [Starting]
org.eclipse.emf.mapping.ecore2ecore (2.7.0.v20120130-0943) "EMF Ecore to Ecore Mapping" [Starting]
org.eclipse.emf.mapping.ecore2ecore.editor (2.5.0.v20120130-0943) "EMF Ecore to Ecore Mapping Editor" [Starting]
org.eclipse.emf.mapping.ecore2xml (2.7.0.v20120130-0943) "EMF Ecore to XML Mapping" [Starting]
org.eclipse.emf.mapping.ecore2xml.ui (2.6.0.v20120130-0943) "EMF Ecore to XML Mapping Editor" [Starting]
org.eclipse.emf.mapping.ui (2.6.0.v20120130-0943) "EMF Mapping UI" [Starting]
org.eclipse.emf.transaction (1.4.0.v20100331-1738) "EMF Model Transaction Core" [Starting]
org.eclipse.emf.validation (1.4.0.v20100428-2315) "EMF Validation Framework Core" [Starting]
org.eclipse.emf.workspace (1.5.1.v20110823-1800) "EMF Model Transaction Workbench Integration Core" [Starting]
org.eclipse.epp.mpc.core (1.1.1.I20110907-0947) "Marketplace Client" [Starting]
org.eclipse.epp.mpc.help.ui (1.1.1.I20110907-0947) "Marketplace Client" [Resolved]
org.eclipse.epp.mpc.ui (1.1.1.I20110907-0947) "Marketplace Client" [Active]
org.eclipse.epp.package.jee (1.4.2.20120131-1457) "Java EE IDE" [Resolved]
org.eclipse.epp.usagedata.gathering (1.3.1.R201106061540) "Usage Data Gathering Plug-in" [Active]
org.eclipse.epp.usagedata.recording (1.3.1.R201106061540) "Usage Data Recording Plug-in" [Active]
org.eclipse.epp.usagedata.ui (1.3.1.R201106061540) "Usage Data UI Plug-in" [Starting]
org.eclipse.equinox.app (1.3.100.v20110321) "Equinox Application Container" [Active]
org.eclipse.equinox.common (3.6.0.v20110523) "Common Eclipse Runtime" [Active]
org.eclipse.equinox.concurrent (1.0.200.v20110502) "Equinox Concurrent API" [Starting]
org.eclipse.equinox.ds (1.3.1.R37x_v20110701) "Declarative Services" [Active]
org.eclipse.equinox.event (1.2.100.v20110502) "Event Admin" [Active]
org.eclipse.equinox.frameworkadmin (2.0.0.v20110815-1438) "Equinox Framework Admin" [Starting]
org.eclipse.equinox.frameworkadmin.equinox (1.0.300.v20110815-1438) "Equinox Framework Admin for Equinox" [Starting]
org.eclipse.equinox.http.jetty (2.0.100.v20110502) "Jetty Http Service" [Starting]
org.eclipse.equinox.http.registry (1.1.100.v20110502) "Http Service Registry Extensions" [Resolved]
org.eclipse.equinox.http.servlet (1.1.200.v20110502) "Http Services Servlet" [Starting]
org.eclipse.equinox.jsp.jasper (1.0.300.v20110502) "Jasper Jsp Support Bundle" [Starting]
org.eclipse.equinox.jsp.jasper.registry (1.0.200.v20100503) "Jasper Jsp Registry Support Plug-in" [Starting]
org.eclipse.equinox.launcher (1.2.0.v20110502) "Equinox Launcher" [Resolved]
org.eclipse.equinox.launcher.win32.win32.x86 (1.1.100.v20110502) "Equinox Launcher Win32 X86 Fragment" [Resolved]
org.eclipse.equinox.p2.artifact.repository (1.1.101.v20110815-1419) "Equinox Provisioning Artifact Repository Support" [Starting]
org.eclipse.equinox.p2.console (1.0.300.v20110815-1419) "Equinox Provisioning Console" [Starting]
org.eclipse.equinox.p2.core (2.1.1.v20120113-1346) "Equinox Provisioning Core" [Active]
org.eclipse.equinox.p2.director (2.1.1.v20111126-0211) "Equinox Provisioning Director" [Starting]
org.eclipse.equinox.p2.director.app (1.0.300.v20111126-0153) "Equinox Provisioning Director Application" [Starting]
org.eclipse.equinox.p2.directorywatcher (1.0.300.v20110815-1419) "Equinox Provisioning Directory Watcher" [Active]
org.eclipse.equinox.p2.discovery (1.0.100.v20110502-1955) "Equinox Provisioning Discovery" [Resolved]
org.eclipse.equinox.p2.discovery.compatibility (1.0.1.v20110502-1955) "Equinox Provisioning Discovery" [Starting]
org.eclipse.equinox.p2.engine (2.1.1.R37x_v20111003) "Equinox Provisioning Engine" [Active]
org.eclipse.equinox.p2.extensionlocation (1.2.100.v20110815-1419) "Equinox Provisioning Extension Location Repository Support" [Starting]
org.eclipse.equinox.p2.garbagecollector (1.0.200.v20110815-1419) "Equinox Provisioning Garbage Collector" [Starting]
org.eclipse.equinox.p2.jarprocessor (1.0.200.v20110815-1438) "Equinox Provisioning JAR Processor" [Resolved]
org.eclipse.equinox.p2.metadata (2.1.0.v20110815-1419) "Equinox Provisioning Metadata" [Active]
org.eclipse.equinox.p2.metadata.repository (1.2.0.v20110815-1419) "Equinox Provisioning Metadata Repository" [Active]
org.eclipse.equinox.p2.operations (2.1.1.R37x_v20111111) "Equinox Provisioning Operations API" [Active]
org.eclipse.equinox.p2.publisher (1.2.0.v20110815-1419) "Equinox Provisioning Publisher Infrastructure" [Starting]
org.eclipse.equinox.p2.publisher.eclipse (1.0.0.v20110815-1438) "Equinox Provisioning Publisher for Eclipse" [Starting]
org.eclipse.equinox.p2.ql (2.0.100.v20110815-1419) "Equinox Provisioning p2 query language" [Starting]
org.eclipse.equinox.p2.reconciler.dropins (1.1.100.v20110815-1419) "Equinox Provisioning Drop-in" [Active]
org.eclipse.equinox.p2.repository (2.1.1.v20120113-1346) "Equinox Provisioning Repository" [Active]
org.eclipse.equinox.p2.repository.tools (2.0.100.v20110815-1438) "Equinox Provisioning Repository Tools" [Starting]
org.eclipse.equinox.p2.touchpoint.eclipse (2.1.1.v20110815-1419) "Equinox Provisioning Eclipse Touchpoint" [Starting]
org.eclipse.equinox.p2.touchpoint.natives (1.0.300.v20110815-1419) "Equinox Provisioning Native Touchpoint" [Starting]
org.eclipse.equinox.p2.transport.ecf (1.0.0.v20111128-0624) "Equinox Provisioning ECF based Transport" [Starting]
org.eclipse.equinox.p2.ui (2.1.1.v20120113-1346) "Equinox Provisioning UI Support" [Active]
org.eclipse.equinox.p2.ui.discovery (1.0.0.v20110502-1955) "Equinox Provisioning Discovery UI" [Resolved]
org.eclipse.equinox.p2.ui.importexport (1.0.1.R37x_v20111103) "Equinox Provisioning Import and Export" [Starting]
org.eclipse.equinox.p2.ui.sdk (1.0.200.v20110815-1419) "Equinox Provisioning Platform Update Support" [Active]
org.eclipse.equinox.p2.ui.sdk.scheduler (1.0.100.v20110815-1419) "Equinox Provisioning Platform Automatic Update Support" [Active]
org.eclipse.equinox.p2.updatechecker (1.1.200.v20110815-1419) "Equinox Provisioning Update Checker" [Active]
org.eclipse.equinox.p2.updatesite (1.0.300.v20110815-1419) "Equinox Provisioning Legacy Update Site Support" [Starting]
org.eclipse.equinox.preferences (3.4.2.v20120111-2020) "Eclipse Preferences Mechanism" [Active]
org.eclipse.equinox.registry (3.5.101.R37x_v20110810-1611) "Extension Registry Support" [Active]
org.eclipse.equinox.security (1.1.1.R37x_v20110822-1018) "Equinox Java Authentication and Authorization Service (JAAS)" [Active]
org.eclipse.equinox.security.ui (1.1.0.v20101004) "Equinox Security Default UI" [Starting]
org.eclipse.equinox.security.win32.x86 (1.0.200.v20100503) "Windows Data Protection services integration" [Resolved]
org.eclipse.equinox.simpleconfigurator (1.0.200.v20110815-1438) "Simple Configurator" [Active]
org.eclipse.equinox.simpleconfigurator.manipulator (2.0.0.v20110815-1438) "Simple Configurator Manipulator" [Starting]
org.eclipse.equinox.util (1.0.300.v20110502) "Equinox Util Bundle" [Active]
org.eclipse.gef (3.7.2.v20111106-2020) "Graphical Editing Framework GEF" [Starting]
org.eclipse.graphiti (0.8.2.v20120215-0845) "Graphiti (Incubation)" [Starting]
org.eclipse.graphiti.mm (0.8.2.v20120215-0845) "Graphiti Notational Model (Incubation)" [Starting]
org.eclipse.graphiti.pattern (0.8.2.v20120215-0845) "Graphiti Pattern (Incubation)" [Starting]
org.eclipse.graphiti.ui (0.8.2.v20120215-0845) "Graphiti UI (Incubation)" [Starting]
org.eclipse.help (3.5.100.v20110426) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.400.v20110425) "Help Application Server" [Starting]
org.eclipse.help.base (3.6.2.v201202080800) "Help System Base" [Starting]
org.eclipse.help.ui (3.5.101.r37_20110819) "Help System UI" [Starting]
org.eclipse.help.webapp (3.6.1.r37_20110929) "Help System Webapp" [Starting]
org.eclipse.jdt (3.7.2.v201202080800) "Eclipse Java Development Tools" [Resolved]
org.eclipse.jdt.apt.core (3.3.500.v20110420-1015) "Java Annotation Processing Core" [Active]
org.eclipse.jdt.apt.pluggable.core (1.0.400.v20110305-1450) "Java Compiler Apt IDE" [Acti
Re: getting compiler error. I think its something to do with eclipse? [message #1033686 is a reply to message #1033177] Thu, 04 April 2013 14:16 Go to previous message
Would it be possible for you to update to the 3.8.2 or 4.2.2 release ? I believe your problem is already fixed.
HTH,
Olivier
Previous Topic:Foreground color not applying
Next Topic:JDT Compiler throws NPE in Java 1.7
Current Time: Mon May 21 19:09:46 GMT 2018
Powered by FUDForum. Page generated in 0.02210 seconds
