Home » Modeling » TMF (Xtext) » Cross Referencing with a different attribute of a rule
Cross Referencing with a different attribute of a rule [message #1032430] Wed, 03 April 2013 01:43 Go to next message
Roza Ghamari is currently offline Roza GhamariFriend
Member
Hi all,
In my DSL, I need to cross reference a rule using a different variable than it's name. For example my rule is like:
rule1:
name = ID "and" name2 = ID
rule2:
"ref" [rule1|name2]
This always gives errors and cannot be compiled.
I also tried adding a rule for name2 like
Name2String return ecore::EString:
ID
The error is going away when I change the rule2 to "ref" [rule1|Name2String] but it still uses the default name attribute in rule1 to reference it.
Is there any way to solve this problem in xtext?
Thanks very much!
Re: Cross Referencing with a different attribute of a rule [message #1032528 is a reply to message #1032430] Wed, 03 April 2013 05:22 Go to previous message
Christian Dietrich is currently offline Christian DietrichFriend
Hi you have to customize the iqualifiednameprovider
http://christiandietrich.wordpress.com/2011/07/16/iqualifiednameproviders-in-xtext-2-0/
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Need professional support for Xtext, Xpand, EMF?
Go to: https://xtext.itemis.com
Twitter : @chrdietrich
Blog : https://www.dietrich-it.de
[Updated on: Wed, 03 April 2013 05:48]
Report message to a moderator
Previous Topic:Setting the key value for a map from imported ecpre model
Next Topic:cross reference into other DSL files
Current Time: Fri May 25 01:40:29 GMT 2018
Powered by FUDForum. Page generated in 0.02522 seconds
