| gdb: unrecognized option -i (solaris eclipse) [message #150874] |
Thu, 04 August 2005 17:37  |
Originally posted by: dxlaw.sdf.lonestar.org
I've created a debug config for a c app in solaris eclipse selecting "gdb
debugger". I get this error when I try to launch it. As far as I know no
gdb accepts "-i". How do I fix this.
Error creating session: gdb: unrecognized option `-i'
org.eclipse.cdt.debug.mi.core.MIException: gdb: unrecognized option `-i'
org.eclipse.cdt.debug.mi.core.MISession.<init>(MISession.java:133)
org.eclipse.cdt.debug.mi.core.MIPlugin.createMISession(MIPlu gin.java:87)
org.eclipse.cdt.debug.mi.core.MIPlugin.createMISession(MIPlu gin.java:103)
org.eclipse.cdt.debug.mi.core.MIPlugin.createCSession(MIPlug in.java:189)
org.eclipse.cdt.debug.mi.core.MIPlugin.createCSession(MIPlug in.java:124)
org.eclipse.cdt.debug.mi.core.GDBCDIDebugger.createLaunchSes sion(GDBCDIDebugger.java:102)
org.eclipse.cdt.debug.mi.core.GDBCDIDebugger.createDebuggerS ession(GDBCDIDebugger.java:73)
org.eclipse.cdt.launch.internal.LocalRunLaunchDelegate.launc h(LocalRunLaunchDelegate.java:71)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:569)
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:788)
org.eclipse.debug.internal.ui.DebugUIPlugin$6.run(DebugUIPlu gin.java:955)
org.eclipse.core.internal.jobs.Worker.run(Worker.java:66)
David
| Re: unrecognized option -i (solaris eclipse) [message #150878 is a reply to message #150874] |
Thu, 04 August 2005 18:41   |
Originally posted by: mikhailkhod.rogers.com
You should use gdb 5.2.1 or greater.
"David" <dxlaw@sdf.lonestar.org> wrote in message
news:be98783397836cd2ab02dbf9a9b5afab$1@www.eclipse.org...
ger.java:102)
ugger.java:73)
Delegate.java:71)
on.java:569)
a:788)
> David
| Re: unrecognized option -i (solaris eclipse) [message #150883 is a reply to message #150878] |
Thu, 04 August 2005 19:29  |
Ah. I guess the long form is --interpreter=XXX. Missed that. Thanks.
> ger.java:102)
> ugger.java:73)
> Delegate.java:71)
> on.java:569)
> a:788)
>> Thanks,
>> David
FUDForum. Page generated in 0.01398 seconds
