Home » Eclipse Projects » Remote Application Platform (RAP) » RAP export as WAR using Tooling(Problems with ServletBridge ExtensionBundle WAR exports)
RAP export as WAR using Tooling [message #1027121] |
Tue, 26 March 2013 15:22 |
Hi all (Ralf?),
I've hit some problems this week trying to use the Libra WAR Tooling to export existing RAP projects as WARs for deploy to appservers.
This process was working ok a few weeks ago, and I haven't done an export for a while, but now (after updating various components including nightly RAP build), I can no longer used the exported WAR file.
In the WAR configuration panel, I now get a problem on org.eclipse.equinox.servletbridget.extensionbundle, although it isn't clear what the problem is. Something is not getting resolved somewhere along the lines.
I can continue to export the WAR, but the bundles refused to go beyond "INSTALLED" state as they are missing constraints. The one that seems to be causing the problems is this one:
"...Missing Constraint: Import-Package: javax.servley; version=[2.3.0,4.0.0)"
I see from various posts that there has been some discussion, and wonder what the state of play is?
link: https://bugs.eclipse.org/bugs/show_bug.cgi?id=348045
and link: https://bugs.eclipse.org/bugs/show_bug.cgi?id=398780
Thanks, John
p.s. I'm away not for a couple of weeks, but any info and progress greatly appreciated as I can no longer deploy my applications to WARs (vital!!)
Just because you can doesn't mean you should
Re: RAP export as WAR using Tooling [message #1031981 is a reply to message #1027121] |
Tue, 02 April 2013 12:35 |
Ivan Furnadjiev Messages: 2426 Registered: July 2009 Location: Sofia, Bulgaria |
Hi John,
you already found all the needed information:
Libra WAR Product Tooling needs an update ( bug 398780 ) in order to
export application based on RAP nightly.
Best,
Ivan
On 3/26/2013 5:22 PM, John Gymer wrote:
> Hi all (Ralf?),
> Thanks, John
> (vital!!)
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: RAP export as WAR using Tooling [message #1058554 is a reply to message #1031981] |
Tue, 14 May 2013 12:59 |
Hi Ivan,
I wonder if you could help me resolve my WAR issues now that I am upgraded to Kepler M7, and still having similar problems?
Firstly, I have installed the "WAR Products (Incubation)" from "Mylyn for Eclipse Kepler - http://download.eclipse.org/mylyn/releases/kepler". I assume this is the correct place to get the updated version?
Next I use my working RAP Run Configuration to base a new WAR product on, and export it. On deploying the WAR into WebLogic (the creation of the WAR and the deploy into WebLogic both work ok), I use the OSGI command ss to list the bundles... result below:
osgi> ss
"Framework is launched."
id State Bundle
0 ACTIVE org.eclipse.osgi_3.9.0.v20130305-2200
1 ACTIVE com.ibm.icu.base_50.1.0.v20121116-2
2 INSTALLED iet.co.uk.rapide.RAP_85.80.0
3 ACTIVE javax.xml_1.3.4.v201005080400
4 ACTIVE org.apache.felix.gogo.command_0.10.0.v201209301215
5 ACTIVE org.apache.felix.gogo.runtime_0.10.0.v201209301036
6 ACTIVE org.apache.felix.gogo.shell_0.10.0.v201212101605
7 ACTIVE org.eclipse.core.commands_3.6.100.v20130220-2151
8 ACTIVE org.eclipse.core.contenttype_3.4.200.v20130221-0103
9 ACTIVE org.eclipse.core.databinding_1.4.1.v20130220-2151
10 ACTIVE org.eclipse.core.databinding.beans_1.2.200.v20130220-2151
11 ACTIVE org.eclipse.core.databinding.observable_1.4.1.v20130220-2151
12 ACTIVE org.eclipse.core.databinding.property_1.4.200.v20130220-2151
13 ACTIVE org.eclipse.core.expressions_3.4.500.v20130221-0103
14 ACTIVE org.eclipse.core.jobs_3.5.300.v20130221-0103
15 ACTIVE org.eclipse.core.runtime_3.9.0.v20130221-0103
16 ACTIVE org.eclipse.equinox.app_1.3.100.v20130225-1702
17 ACTIVE org.eclipse.equinox.common_3.6.100.v20130225-1702
18 ACTIVE org.eclipse.equinox.console_1.0.100.v20130225-1702
19 INSTALLED org.eclipse.equinox.http.registry_1.1.200.v20130225-1702
20 INSTALLED org.eclipse.equinox.http.servlet_1.1.300.v20130225-1702
21 INSTALLED org.eclipse.equinox.http.servletbridge_1.0.300.v20130225-170
2
22 ACTIVE org.eclipse.equinox.preferences_3.5.0.v20130225-1702
23 ACTIVE org.eclipse.equinox.registry_3.5.300.v20130225-1702
24 INSTALLED org.eclipse.equinox.servletbridge_1.2.200.v20130225-1702
25 ACTIVE org.eclipse.equinox.util_1.0.400.v20130307-2007
26 ACTIVE org.eclipse.help_3.6.0.v20130221-0120
27 ACTIVE org.eclipse.osgi.services_3.3.100.v20130225-1645
28 INSTALLED org.eclipse.rap.clientscripting_0.1.100.201305141337
29 INSTALLED org.eclipse.rap.jface_2.1.0.20130225-1108
30 INSTALLED org.eclipse.rap.jface.databinding_2.1.0.20130220-2001
31 INSTALLED org.eclipse.rap.rwt_2.1.0.20130410-0853
32 INSTALLED org.eclipse.rap.rwt.osgi_2.1.0.20130220-2001
33 INSTALLED org.eclipse.rap.ui_2.1.0.20130220-2001
34 INSTALLED org.eclipse.rap.ui.forms_2.1.0.20130306-1637
35 INSTALLED org.eclipse.rap.ui.views_2.1.0.20130220-2001
36 INSTALLED org.eclipse.rap.ui.workbench_2.1.0.20130225-1531
osgi> start 31
gogo: BundleException: The bundle "org.eclipse.rap.rwt_2.1.0.20130410-0853 [31]"
could not be resolved. Reason: Missing Constraint: Import-Package: javax.servle
t; version="[2.3.0,4.0.0)"
osgi>
If I try to start the various bundles in turn and follow the dependency reported, the final problem appears to be still that RWT needed javax.servlet, similar to previous (before I upgraded to M7).
javax.servlet is listed as an Imported Package in my project, and is required in order for me to run the RAP application within Eclipse.
If I attempt to add javax.servlet into the WAR configuration, and then export, the export is not allowed because javax.servlet is a 'forbidden bundle'... I think this is as expected with the WAR tooling update?
Can you help identify what I have missed, or what extra I need to include to make this exported WAR work?
For info, my RAP Target is 2.1 Nightly from 10th April. I tried using one from 13th May, but couldn't get the RAP application to work at all within Eclipse, so reverted. Hope that's just a transitory problem with the nightly that will go away soon.
Thanks, John
Re: RAP export as WAR using Tooling [message #1058565 is a reply to message #1058554] |
Tue, 14 May 2013 13:20 |
Hi John,
there are still problems with latests WAR Product from Libra. The bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=398780 has been reopened.
I hope that the issue will be fixed in Kepler RC1.
Best,
Ivan
On 5/14/2013 3:59 PM, John Gymer wrote:
> Hi Ivan,
> osgi> ss
> id State Bundle
> 11 ACTIVE
> 12 ACTIVE
> 19 INSTALLED
> 21 INSTALLED
> 2
> 24 INSTALLED
> osgi> start 31
> javax.servle
> osgi>
> update?
> Thanks, John
Ivan Furnadjiev
Re: RAP export as WAR using Tooling [message #1058599 is a reply to message #1058565] |
Tue, 14 May 2013 14:17 |
Hi Ivan,
Fantastic - and thanks for the link to the bug which shows how to workaround it in the meantime!
I've exported the WAR, manually edited the config.ini inside to include "org.eclipse.equinox.servletbridge.extensionbundle,\" and now it works perfectly in WebLogic!
Excellent!
Cheers, John
Current Time: Thu Mar 28 10:41:14 GMT 2024
Powered by FUDForum. Page generated in 0.02800 seconds
