error when generate diagram code [message #149476] |
Fri, 07 September 2007 16:45 |
Originally posted by: riververy.yahoo.com
I always got errors when generate diagram code:
Error
Fri Sep 07 11:54:28 CDT 2007
Can't organize imports due to syntax errors in the compilation unit
DesignParserProvider.java
Error
DesignReorientConnectionViewCommand.java
I need help! I'm exhausted:(
Re: error when generate diagram code [message #149478 is a reply to message #149477] |
Fri, 07 September 2007 18:25 |
I just follow the turtorial:
http://wiki.eclipse.org/index.php/GMF_Tutorial_BPMN
and then in step: "Running Diagram with no Domain (optional) " --->
Right-click the bpmn.gmfgen model and select 'Generate diagram code'
I got the error and I can't generate diagram code.
So I don't know where's the body of the method I should post here and I
didn't touch any code at all:(
This is my first time trying gmf, so my question may sound stupid, but I
really need help!
Thanks!
"Boris Blajer" <boris.blajer@borland.com>
??????:fbs0l5$jdv$1@build.eclipse.org...
> Hi very,
> Please build the project and post here the bodies of the methods with
> syntax errors. Otherwise it is impossible to understand what exactly goes
> wrong in your case.
> Thanks in advance and
> Best regards,
> Boris
>> Error
>> Error
Re: error when generate diagram code [message #149485 is a reply to message #149479] |
Sat, 08 September 2007 16:25 |
my friend help me fix it:
since I have to install eclipse3.3 to use gmf2.0, so I download a new
eclipse(I used eclipse3.2 before). I didn't change any default setting of
the new eclipse3.3 platform, then my friend found the default setting of
eclipse3.3 using JDK1.4(I have all JDK1.4,&5,&6 in my computer) as default,
so lots of syntax error come out because of the outdated JDK.
"Richard Gronback" <richard.gronback@borland.com>
??????:C3070833.1AF0B%richard.gronback@borland.com...
> Note that this tutorial uses 1.0 of GMF and has not been updated since.
> The
> mindmap tutorial is probably best to begin with if you're new to GMF and
> using 2.0
> Best,
> Rich
> On 9/7/07 2:25 PM, in article fbs1ir$7ar$1@build.eclipse.org, "very"
>> really need help!
>> Thanks!
>>> Hi very,
>>> goes
>>> wrong in your case.
>>> Best regards,
>>> Boris
>>>> Error
>>>> Error
Re: error when generate diagram code [message #150132 is a reply to message #149485] |
Tue, 11 September 2007 18:43 |
Originally posted by: 5d5.mail.ru
Could you at least post the generated parser class with errors?
>> The
>> using 2.0
>> Best,
>> Rich
>>> really need help!
>>> Thanks!
>>>> Hi very,
>>>> goes
>>>> wrong in your case.
>>>> Best regards,
>>>> Boris
>>>>> Error
>>>>> Error
FUDForum. Page generated in 0.01942 seconds
